CST-90-WWRM-C12-GK750
    LUMINUS(朗明纳斯)
    BIG CHIP LED HB MOD WM WHT 500LM
CST-90-WWRM-C12-GK750 数据手册
CST-90 Product Datasheet CST-90 LEDs Features: • Extremely high optical output: Over 2,600 lumens from a single chip (White) Table of Contents Technology Overview. . . . . . 2 Test Specifications . . . . . . . . . 2 White Binning Structure. . . . 3 • Extremely high efficiency: Over 100 lumens per watt at 3.15A • High thermal conductivity package - junction to heat sink thermal resistance of only 0.92 ºC/W • Large, monolithic chip with uniform emitting area of 9 mm2 • Lumen maintenance of greater than 70% after 60,000 hours • Environmentally friendly: RoHS compliant Chromaticity Bins. . . . . . . . . . 4 • Variable drive currents: less than 1 A through 13.5 A Product Shipping & Labeling Information. . . . . . . 8 • High reliability Electrical Characteristics. . . 9 Lifetime & Lumen Maintenance. . . . . . . . . . . . . . 10 Spectral Characteristics. . . 10 Radiation Patterns . . . . . . . . 11 Thermal Resistance . . . . . . . 12 Mechanical Dimensions . . . 13 Applications • Architectural Lighting • Spot Lighting • Retail Lighting • High Bay Lighting • Residential Lighting • Wide Area Lighting • Consumer Portable • Street Lighting Ordering Information . . . . . 14 1 PDS-001314Rev 09 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 CST-90 Product Datasheet Technology Overview Luminus Big Chip LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency. Photonic Lattice Technology and longer lifetimes. Luminus’ photonic lattice technology enables large area LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these large monolithic chips enable solutions which replace arc and halogen lamps where arrays of traditional high power LEDs cannot. Reliability For red, green and blue LEDs, the photonic lattice structures extract more light and create radiation patterns that are more collimated than traditional LEDs. Having higher collimation from the source increases optical collection efficiencies and simplifies optical designs. Designed from the ground up, Luminus Big Chip LEDs are one of the most reliable light sources in the world today. Big Chip LEDs have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus Big Chip LEDs are ready for even the most demanding applications. Environmental Benefits Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to heat sink of 0.92º C/W. Luminus CST-90 LEDs have the lowest thermal resistance of any LED on the market. This allows the LED to be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All Big Chip LED products manufactured by Luminus are RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Big Chip LED Test Specifications Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing Temperature Multiple Operating Points (3.15, 13.5 A) Luminus core board products are typically measured in such a way that the characteristics reported agree with how the devices will actually perform when incorporated into a system. This measurement is accomplished by mounting the devices on a 40ºC heat sink and allowing the device to reach thermal equilibrium while fully powered. Only after the device reaches equilibrium are the measurements taken. This method of measurement ensures that Luminus Big Chip LEDs perform in the field just as they are specified. The tables on the following pages provide typical optical and electrical characteristics. Since the LEDs can be operated over a wide range of drive conditions (currents from less than 1.0 A to 13.5 A, and duty cycle from
物料型号:CST-90
器件简介:Luminus Big Chip LEDs™ 以其高亮度和高效率的解决方案而受到照明工程师和设计师的青睐。CST-90 LED具有超过2600流明的极高光输出和超过100流明/瓦的极高效率。
引脚分配:文档中未明确提供引脚分配信息,但提到了电气特性和电气引脚配置。
参数特性: - 电流密度:3.15A时为0.35 A/mm²,13.5A时为1.5 A/mm² - 正向电压:在3.15A时典型值为2.5V,绝对最大额定值为3.9V - 工作温度范围:-40℃ 至 150℃ - 存储温度范围:-40℃ 至 100℃
功能详解: - 光子晶格技术:允许大面积LED芯片在整个LED芯片表面上具有均匀的亮度。 - 封装技术:具有市场上最低的热阻抗,从结到散热器的热阻为0.92℃/W。 - 可靠性:通过了包括机械冲击、振动、温度循环和湿度在内的一系列环境和机械应力测试。 - 环境效益:所有Luminus Big Chip LED产品均符合RoHS标准,不含铅和汞等有害物质。
应用信息: - 建筑照明 - 聚光灯 - 零售照明 - 高棚照明 - 住宅照明 - 广域照明 - 便携式消费产品 - 街道照明
封装信息: - 发光面积:9 mm² - 发光面积尺寸:3x3 mm - 视场角度:95° - 正向电压温度系数:-4.4 mV/°C
CST-90-WWRM-C12-GK750 价格&库存
很抱歉,暂时无法提供与“CST-90-WWRM-C12-GK750”相匹配的价格&库存,您可以联系我们找货
