SMP6-RGB
SMP6-RGB
    BIVAR
    PLCC-6
    发光二极管/LED PLCC-6
SMP6-RGB 数据手册
PLCC6 SMD Top View Package LED SMP6-RGB, RED/GREEN/BLUE SMP6-RGB      Industry Standard PLCC6 Footprint 3 Chips in One Low Profile Package High Luminous Intensity Wide Viewing Angle High Power Efficiency Bivar SMP6 RGB LED is offered in an industry standard PLCC6 package with high luminous intensity and wide viewing angles. The miniature package is ideal for small scale applications such as illumination, general indication, and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment. The flexible three chip design allows for a wide variety of lighting options where the chips can be individually driven or mixed to create numerous color and intensity combinations. Bivar SMP6 LED is packaged in standard tape and reels for pick and place assemblies. Emitted Color Material Emitted Color Lumen Typ. mcd AlGaInP Red 600 InGaN Green 800 InGaN Blue 350 SMP6-RGB Lens Color Viewing Angle Water Clear 140° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 1 of 5 PLCC6 SMD Top View Package LED SMP6-RGB, RED/GREEN/BLUE Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 100 mW Continuous Forward Current 30 mA Peak Forward Current 1 100 mA Electrostatic Discharge Classification (HBM) 2000 V Reverse Voltage 5V Derating Linear From 25°C 0.4 mA/°C Operating Temperature Range -30 ~ +85°C Storage Temperature Range -40 ~ +100°C Soldering Temperature 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Emitting Color Forward Voltage (V)1 Recommend Forward Current (mA) Reverse Current (µA) VR=5V TYP MAX MIN MAX MIN MAX TYP Dominant Wavelength (nm)2 Luminous Intensity (mcd)3 Viewing Angle 2 Ө ½ (deg) MIN TYP MAX Red 1.8 2.1 2.4 20 10 620 632 500 700 140 Green 3.0 3.3 3.6 20 10 520 532 700 900 140 Blue 3.0 3.3 3.6 20 10 465 477 200 500 140 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Dominant Wavelength : ±0.1nm. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Radiation Diagram Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 2 of 5 PLCC6 SMD Top View Package LED SMP6-RGB, RED/GREEN/BLUE Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Red Blue Blue Green Green Red Blue Red Green Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 3 of 5 PLCC6 SMD Top View Package LED SMP6-RGB, RED/GREEN/BLUE Recommended Soldering Conditions Tape and Reel Dimensions Note: 1000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 4 of 5 PLCC6 SMD Top View Package LED SMP6-RGB, RED/GREEN/BLUE Packaging and Labeling Plan Note: 1 Reel / Bag Vacuum and Heat Sealed Clear AntiStatic Poly Bag Internal Quality Control Label X.XXX Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 5 of 5
SMP6-RGB 价格&库存
很抱歉,暂时无法提供与“SMP6-RGB”相匹配的价格&库存,您可以联系我们找货
