BXRE-27G0800-A-03
BXRE-27G0800-A-03
    BRIDGELUX(普瑞)
    LED ARRAY 2700K 800LM WARM WHT
BXRE-27G0800-A-03 数据手册
Bridgelux V8 Array Series Product Data Sheet DS41 BXRE-xxx0800-A, BXRE-xxx0800-B Introduction The Bridgelux V8 LED Array products delivers high quality light in a compact and cost-effective solid-state lighting solution. These products can be efficiently driven at twice the normal current, enabling design flexibility not previously possible. This high flux density light source is designed to enable a wide range of sub 1000 lumen directional luminaires and replacement lamps for commercial and residential applications. The V8 LED Array light engine is available in multiple electrical, CCT and CRI combinations providing considerable design-in flexibility and energy efficiencies. Lighting system designs incorporating these LED Arrays deliver comparable performance to that of 40-75 Watt incandescent and halogen and 7-13 Watt compact fluorescent based luminaires they provide increased system level efficacy and longer service life. Typical applications include replacement lamps, task, accent, spot, track, down light, wide area, security, and wall pack. Features Benefits  Compact high flux density light source  Enhanced optical control  Uniform high quality illumination  Clean white light without pixilation  Minimum 70, 80 and 90 CRI options  High quality true color reproduction  Streamlined thermal path   Significantly reduced thermal resistance and increased operating temperatures Energy Star / ANSI compliant color binning structure with 3SDCM options  Uniform consistent white light  Lower operating costs  UL Recognized  Easy to use with daylight and motion detectors to enable increased energy savings  More energy efficient than incandescent, halogen and fluorescent lamps  Low voltage DC operation  Instant light with unlimited dimming  5-Year warranty  Reduced maintenance costs  RoHS compliant and Pb free  Environmentally friendly, no disposal issue  CEC compliant versions available 101 P ortol a A v enue, Li v erm ore , C A 94551 • T el : (925 ) 583 -84 0 0 • Fa x: (92 5) 58 3 -8 401 • ww w. b ri dgel u x. c om Table of Contents Page Typical Product Features 3 Product Nomenclature 3 Lumen Maintenance Characteristics 4 Environmental Compliance 4 UL Recognition 4 CE Recognition 4 Minor Product Change Policy 4 Case Temperature Measurement Point 4 Cautionary Statements 5 Selection Guide 6 Typical Performance at Alternative Drive Currents 7 Flux Characteristics 9 Electrical Characteristics 10 Absolute Maximum Ratings 11 Current versus Forward Voltage Characteristics 12 Typical Luminous Flux vs. Current 14 Typical Chromaticity Characteristics vs. Temperature 15 Typical Radiation Pattern 17 Mechanical Dimensions 19 Color Binning Information 20 Design Resources 23 About Bridgelux 24 Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 2 of 24 Typical Product Features Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V8 array is the smallest chip-on-board device across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Figure 1: Array Features Polarity symbols Fully engineered substrate for consistent thermal, mechanical and optical properties Yellow phosphor Light Emitting Surface (LES) Solder Pads White ring around LES Case Temperature (Tc) Measurement Point Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux LED Arrays is explained as follows: BXRE – AB C DEFG – H – IJ Where: B X R E – Designates product family A B – Designates the nominal ANSI color temperature; 27 = 2700K; 30 = 3000K, etc. C - Designates minimum CRI; C = 70, E = 80, G = 90 D E F G - Designates Nominal Flux; 0500 = 500lm, 0800 = 800lm, etc. H – Designates configuration I J – Designates CCT color binning 03 = 3SDCM or 3-step 04 = 4SDCM or 4-step Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 3 of 24 Lumen Maintenance Characteristics Bridgelux projects that its family of LED Array products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at the rated forward test current. This performance assumes constant current operation at the nominal drive current with case temperature maintained at or below 85°C. For use beyond these typical operating conditions please consult your Bridgelux sales representative for further assistance. These projections are based on a combination of package test data, semiconductor chip reliability data, a fundamental understanding of package related degradation mechanisms, and performance observed from products installed in the field using Bridgelux die technology. Bridgelux conducts lumen maintenance tests per LM80. Observation of design limits is required in order to achieve this projected lumen maintenance. Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid state lighting market. Bridgelux LED Arrays comply with the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux does not intentionally add the following restricted materials to LED Array products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). UL Recognition Bridgelux secures UL recognition for all the LED Array products. Please refer to the UL file E350613 for the latest list of UL recognized Arrays. Bridgelux uses UL recognized materials with suitable flammability ratings in the LED Array to streamline the process for customers to secure UL listing of the final luminaire product. CE Recognition In accordance with the relevant European Union directives, the family of LED Array products conform to the applicable requirements of the IEC/EN 62031:2008 (LED Modules for General Lighting Safety Specifications) and IEC 62471:2006 (Photobiological Safety of Lamps and Lamp Systems). Bridgelux maintains a CE Declaration of Conformity statement on its website and displays the CE mark on product packing labels. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Case Temperature Measurement Point A case temperature (Tc) measurement point location is included on the top surface of the Bridgelux LED Arrays. The location of this measurement point is indicated in the mechanical dimensions section of this data sheet. The purpose of this measurement point is to allow the user access to a measurement point closely linked to the true case temperature on the back surface of the LED Array. Once the LED Array is installed, it is challenging to measure the back surface of the array, or true case temperature. Bridgelux has provided the case temperature measurement location in a manner which closely ties it to the true case temperature of the LED Array under steady state operation. Deviations between thermal measurements taken at the point indicated and the back of the LED Array differ by less than 1°C, providing a robust method to testing thermal operation once the product is installed. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 4 of 24 Cautionary Statements CAUTION: CONTACT WITH OPTICAL AREA Avoid any contact with the optical area. Do not touch the optical area of the LED Array or apply mechanical stress to the yellow phosphor resin area – it could damage the LED Array. Optics and reflectors must not be mounted in contact with the yellow phosphor resin area (LES) or the white ring that surrounds the yellow phosphor area. Using the white ring to secure optics can result in damage to the LED Array as the ring is not designed to act as a mechanical locating feature. Optical devices may be mounted on the top surface of the LED Array substrate outside of the white ring maximum OD as specified in the product data sheet. Use the mechanical features of the LED Array substrate edges and/or mounting holes to locate and secure the optical device as needed. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux LED Arrays is in accordance with IEC specification EN62471; Photobiological Safety of Lamps and Lamp Systems. Bridgelux LED Arrays are classified as Risk Group 1 (Low Risk) when operated at or below their rated test current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the LED Array or resin area during operation. Allow the LED Array to cool for a sufficient period of time before handling. The LED Array may reach elevated temperatures such that it can burn skin when touched. CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED Array. Please consult Application Note AN11 for additional information. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 5 of 24 Selection Guide The following configurations are available: Table 1: Selection Guide for V8 Arrays [2] Part Number [1] CCT (Kelvin) CRI [3] Test Current (mA) Typical [4] Voltage (V) Typical Flux [5,6] (lm) Tj = 25ºC Tcase = 85ºC Typical [4] Power (W) Typical Efficacy [4] (lm/W) BXRE-27E0800-A-03 2700K 80 175 35.6 705 615 6.2 113 BXRE-27E0800-B-03 2700K 80 350 17.8 705 615 6.2 113 BXRE-27G0800-A-03 2700K 90 175 35.6 565 490 6.2 91 BXRE-27G0800-B-03 2700K 90 350 17.8 565 490 6.2 91 BXRE-30E0800-A-03 3000K 80 175 35.6 730 635 6.2 117 BXRE-30E0800-B-03 3000K 80 350 17.8 730 635 6.2 117 BXRE-30G0800-A-03 3000K 90 175 35.6 595 515 6.2 96 BXRE-30G0800-B-03 3000K 90 350 17.8 595 515 6.2 96 BXRE-40E0800-A-03 4000K 80 175 35.6 770 670 6.2 124 BXRE-40E0800-B-03 4000K 80 350 17.8 770 670 6.2 124 BXRE-50C0800-A-04 5000K 70 175 35.6 850 740 6.2 136 BXRE-50C0800-B-04 5000K 70 350 17.8 850 740 6.2 136 Note for Table 1 through 5 (additional specific notes following Table 2 through 5): 1. 2. 3. 4. 5. 6. The “-xx” suffix refers to color control, “-03” for 3 SDCM or “-04” for 4 SDCM. Nominal CCT as defined by ANSI C78.377-2011. CRI Values are minimum. Minimum R9 value for 90 CRI products is 50. Products tested under pulsed condition (10ms pulse width) at rated test current where Tjunction = Tcase = 25°C. Typical performance values are provided as a reference only and are not a guarantee of performance. Bridgelux maintains a ±7% tolerance on flux measurements. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 6 of 24 Typical Performance at Alternative Drive Currents Customers may drive the LED Arrays at alternative drive currents dependent on the specific application. The typical performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 2 and 3 and from the flux versus current characteristics shown in Figure 8 and 9. The typical performance at common drive currents is summarized in Table 2. Table 2: Typical Product Performance at Alternative Drive Currents Part Number [1] BXRE-27E0800-A-03 BXRE-27E0800-B-03 BXRE-27G0800-A-03 BXRE-27G0800-B-03 BXRE-30E0800-A-03 BXRE-30E0800-B-03 CCT & [2,3] CRI 2700K and 80 CRI 2700K and 80 CRI 2700K and 90 CRI 2700K and 90 CRI 3000K and 80 CRI 3000K and 80 CRI Typical [4] Voltage (V) Typical [4] Power (W) Tj = 25ºC Tj = 25ºC Tj = 25ºC Tcase = 85ºC Tj = 25ºC 175 35.6 6.2 705 615 113 250 37.1 9.3 970 845 105 350 38.8 13.6 1310 1140 96 350 17.8 6.2 705 615 113 500 18.5 9.3 970 845 105 700 19.4 13.6 1310 1140 96 175 35.6 6.2 565 490 91 250 37.1 9.3 775 675 84 350 38.8 13.6 1050 910 77 350 17.8 6.2 565 490 91 500 18.5 9.3 775 675 84 700 19.4 13.6 1050 910 77 175 35.6 6.2 730 635 117 250 37.1 9.3 1005 870 108 350 38.8 13.6 1355 1180 100 350 17.8 6.2 730 635 117 500 18.5 9.3 1005 870 108 700 19.4 13.6 1355 1180 100 Test [7] Current (mA) Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Typical Flux (lm) Typical [4] Efficacy (lm/W) [5,6] Page 7 of 24 Table 2 Continued: Typical Product Performance at Alternative Drive Currents Part Number [1] BXRE-30G0800-A-03 BXRE-30G0800-B-03 BXRE-40E0800-A-03 BXRE-40E0800-B-03 BXRE-50C0800-A-04 BXRE-50C0800-B-04 CCT & [2,3] CRI 3000K and 90 CRI 3000K and 90 CRI 4000K and 80 CRI 4000K and 80 CRI 5000K and 70 CRI 5000K and 70 CRI Test [7] Current (mA) Typical [4] Voltage (V) Typical [4] Power (W) Typical Flux (lm) Typical [4] Efficacy (lm/W) [5,6] Tj = 25ºC Tj = 25ºC Tj = 25ºC Tcase = 85ºC Tj = 25ºC 175 35.6 6.2 595 515 96 250 37.1 9.3 815 705 88 350 38.8 13.6 1105 955 81 350 17.8 6.2 595 515 96 500 18.5 9.3 815 705 88 700 19.4 13.6 1105 955 81 175 35.6 6.2 770 670 124 250 37.1 9.3 1060 920 114 350 38.8 13.6 1430 1245 105 350 17.8 6.2 770 670 124 500 18.5 9.3 1060 920 114 700 19.4 13.6 1430 1245 105 175 35.6 6.2 850 740 136 250 37.1 9.3 1170 1015 126 350 38.8 13.6 1580 1375 116 350 17.8 6.2 850 740 136 500 18.5 9.3 1170 1015 126 700 19.4 13.6 1580 1375 116 Notes for Table 2 (notes 1 through 6 located under Table 1): 7. Values in bold correspond to rated test currents from Table 1. Alternate values are provide for reference only and are not guaranteed. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 8 of 24 Flux Characteristics Table 3: Flux Characteristics [2] Part Number [1] CCT (Kelvin) BXRE-27E0800-A-03 2700K CRI [3] Test Current (mA) Minimum [8] Flux (lm) Minimum [9] Flux (lm) Typical [4] Flux (lm) Typical [4,10] CBCP (cd) Tj = 25ºC Tcase = 85ºC Tcase = 85ºC Tj = 25ºC E 175 635 555 615 225 BXRE-27E0800-B-03 2700K E 350 635 555 615 225 BXRE-27G0800-A-03 2700K G 175 510 440 490 180 BXRE-27G0800-B-03 2700K G 350 510 440 490 180 BXRE-30E0800-A-03 3000K E 175 655 570 635 230 BXRE-30E0800-B-03 3000K E 350 655 570 635 230 BXRE-30G0800-A-03 3000K G 175 540 465 515 190 BXRE-30G0800-B-03 3000K G 350 540 465 515 190 BXRE-40E0800-A-03 4000K E 175 695 605 670 245 BXRE-40E0800-B-03 4000K E 350 695 605 670 245 BXRE-50C0800-A-04 5000K C 175 765 665 740 270 BXRE-50C0800-B-04 5000K C 350 765 665 740 270 Notes for Table 3 (notes 1 through 7 located under Table 1 and 2): 8. Bridgelux maintains a tester tolerance of ± 7% on flux measurements. Minimum flux values at the rated test current are guaranteed by 100% test. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of luminaire and/or the environment in which the product is operated. 10. Center beam candle power is a calculated value based on Lambertian radiation pattern at rated test current. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 9 of 24 Electrical Characteristics Table 4: Electrical Characteristics Part Number [1] Minimum Typical Maximum Typical Coefficient of Forward [12] Voltage (mV/ºC) ∆Vf/∆Tj Operating Voltage [5, 11] Tj = 25°C (V) Test Current (mA) Typical Thermal Resistance Junction to Case (ºC/W) Rθj-c BXRE-27E0800-A-03 175 32.4 35.6 39.2 -12 to -36 2.70 BXRE-27E0800-B-03 350 16.2 17.8 19.6 -6 to -18 2.70 BXRE-27G0800-A-03 175 32.4 35.6 39.2 -12 to -36 2.70 BXRE-27G0800-B-03 350 16.2 17.8 19.6 -6 to -18 2.70 BXRE-30E0800-A-03 175 32.4 35.6 39.2 -12 to -36 2.70 BXRE-30E0800-B-03 350 16.2 17.8 19.6 -6 to -18 2.70 BXRE-30G0800-A-03 175 32.4 35.6 39.2 -12 to -36 2.70 BXRE-30G0800-B-03 350 16.2 17.8 19.6 -6 to -18 2.70 BXRE-40E0800-A-03 175 32.4 35.6 39.2 -12 to -36 2.70 BXRE-40E0800-B-03 350 16.2 17.8 19.6 -6 to -18 2.70 BXRE-50C0800-A-04 175 32.4 35.6 39.2 -12 to -36 2.70 BXRE-50C0800-B-04 350 16.2 17.8 19.6 -6 to -18 2.70 Notes for Table 4 (notes 1 through 10 located under Table 1 through 3): 11. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. Voltage minimum and maximum values at the rated test current are guaranteed by 100% test. 12. Typical Coefficient of Forward Voltage tolerance of ±0.1 from nominal current. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 10 of 24 Absolute Maximum Ratings Table 5: Maximum Current and Reverse Voltage Ratings [18] DC Forward Current for [16,17,18] LM-80 (mA) Maximum Peak Pulsed Current [13, 15] (mA) Maximum Reverse Voltage [14] (Vr) BXRE-xxx0500-A-xx 350 500 -40 BXRE-xxx0800-A-xx 350 500 -60 BXRE-xxx0800-B-xx 700 1000 -30 Part Number [1] Notes for Table 5 (notes 1 through 12 located under Table 1 through 4) : 13. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. 14. Light emitting diodes are not designed to be driven in reverse voltage. 15. Maximum peak pulsed currents are values at which the LED Array can be driven without catastrophic failures. 16. DC Forward Current for LM-80 are the maximum drive currents for which LM-80 data is currently available. 17. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these arrays. 18. Arrays may be driven at higher currents but lumen maintenance may be reduced. Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 150°C Storage Temperature -40°C to +105°C Operating Case Temperature 105°C Soldering Temperature [1] [2] 350°C or lower for a maximum of 3.5 seconds Note for Table 6: 1. Refer to Bridgelux Application Note AN41: Assembly Considerations for Bridgelux LED Arrays. 2. For IEC 62717 requirement, please consult your Bridgelux sales representative. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 11 of 24 Current versus Forward Voltage Characteristics Figure 2: Typical Current vs. Voltage – BXRE-xxx0800-A-xx Tc=85C MIN MIN 500 TYP MAX 450 Tc=-40C MAX 400 Current (mA) 350 300 250 200 150 100 50 0 10 26 28 30 32 34 36 38 40 42 44 Forward Voltage (V) Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 12 of 24 Current versus Forward Voltage Characteristics Continued Figure 3: Typical Current vs. Voltage – BXRE-xxx0800-B-xx Tc=85C MIN MIN 1000 TYP MAX 900 Tc=-40C MAX 800 Current (mA) 700 600 500 400 300 200 100 100 13 15 17 19 21 23 Forward Voltage (V) Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 13 of 24 Typical Luminous Flux vs. Current Typical performance at any drive current can be derived from the current versus voltage characteristics shown in Figures 2, 3 and 4 and the flux versus current characteristics shown in Figures 5 and 6. Normalized typical flux corresponds to LED tested under pulsed conditions where junction temperature = case temperature = 25°C. Figure 4: Typical Flux vs. Current – BXRE-xxx-0800-A-xx 200% 180% Normalized Flux 160% 140% 120% 100% 80% 60% 40% 20% 0% 0 50 100 150 200 250 300 350 Current (mA) Figure 5: Typical Flux vs. Current – BXRE-xxx-0800-B-xx 200% 180% Normalized Flux 160% 140% 120% 100% 80% 60% 40% 20% 0% 0 100 200 300 400 500 600 700 Current (mA) Note: Bridgelux does not recommend driving high power LED Arrays at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 14 of 24 Typical Chromaticity Characteristics vs. Temperature Figure 6: Typical Flux vs. Junction Temperature Figure 9: Typical Flux vs. Junction Temperature 1.2 Normalized Luminous Flux Neutral White 1.0 0.8 Warm White Cool White 0.6 Warm White 0.4 Cool White Neutral White 0.2 0.0 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, °C 90 100 110 120 130 Note for figures 6, 7 and 8: 1. Characteristics shown for Warm White 3000K 80CRI 2. Characteristics shown for Neutral White 4000K 80CRI 3. Characteristics shown for Neutral White 4000K 80CRI Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 15 of 24 Typical Chromaticity Characteristics versus Temperature (continued) Figure 7: Typical ccy Shift vs. Junction Temperature 0.02 Neutral White 0.01 Warm White 0.00 Δy -0.01 -0.02 Cool White -0.03 Warm White Cool White -0.04 Neutral White -0.05 -0.06 -10 0 10 20 30 40 50 60 Junction Temperature, °C 70 80 90 100 110 Figure 8: Typical ccx Shift vs. Junction Temperature 0.02 Neutral White 0.01 Warm White 0.00 Δx -0.01 Cool White -0.02 -0.03 Warm White -0.04 Cool White -0.05 Neutral White -0.06 -10 0 10 20 30 40 50 60 Junction Temperature, °C Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) 70 80 90 100 110 Page 16 of 24 Typical Radiation Pattern Figure 9: Typical Spatial Radiation Pattern 100% 90% Relative Intensity (%) 80% 70% 60% 50% 40% 30% 20% 10% 0% -90° -80° -70° -60° -50° -40° -30° -20° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° Angular Displacement (°) Notes for figure 9: 1. 2. Typical viewing angle is 120⁰. The viewing angle is defined as the off axis angle form the centerline where Iv is ½ of the peak value. Figure 10: Typical Polar Radiation Pattern Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 17 of 24 Typical Radiation Pattern Figure 11: Typical Color Spectrum Relative Intensity (%) 3000K 4000K 5000K 110% 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Notes for Figure 11: 1. 2. 3. 4. Color spectra measured at rated current and Tj = 25°C. Color spectrum shown for warm white is 3000K and 80 CRI. Color spectrum shown for neutral white is 4000K and 80 CRI. Color spectrum shown for cool white is 5000K and 70 CRI. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 18 of 24 Mechanical Dimensions Figure 12: Drawing for V8 Arrays Tc Point Notes for Figure 12: 1. Mounting holes are for M2.5 or #4 screws. 2. Solder pads are labeled “+” and “-“ to denote positive and negative, respectively. 3. It is not necessary to provide electrical connections to both sets of solder pads. Either set may be used depending on application specific design requirements. 4. Drawings are not to scale. 5. Drawing dimensions are in millimeters. 6. Unless otherwise specified, tolerances are ± 0.10mm. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array. The light emitting surface (LES) is centered on the mechanical center of the array to a tolerance of ± 0.45 mm 8. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes AN40 and AN41 for product handling, mounting and heat sink recommendations. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 19 of 24 Color Binning Information Figure 13: Graph of Warm White Test Bins in xy Color Space Planckian Locus (BBL) ANSI Bin 3SDCM 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.41 0.42 0.43 0.44 0.45 0.46 0.47 0.48 Note: 3SDCM bins are shown inside standard ANSI bins for comparison purposes. Table 7: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) 03 (3SDCM) (2651K - 2794K) (2968K - 3136K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 20 of 24 Color Binning Information (continued) Figure 14: Graph of Neutral White Test Bins in xy Color Space Planckian Locus (BBL) ANSI Bin 3SDCM 0.41 0.40 4000K 3SDCM 0.39 0.38 0.37 0.36 0.35 0.36 0.365 0.37 0.375 0.38 0.385 0.39 0.395 0.4 0.405 0.41 Note: 3SDCM bin is shown inside standard ANSI bins for comparison purposes. Table 8: Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 4000K ANSI Bin (for reference only) (3710K - 4260K) 03 (3SDCM) (3851K - 4130K) Center Point (x,y) (0.3818, 0.3797) Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 21 of 24 Color Binning Information (continued) Figure 15: Graph of Cool White Test Bins in xy Color Space Planckian Locus (BBL) ANSI Bin 4SDCM 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.33 0.34 0.35 0.36 Note: 4SDCM bin is shown inside standard ANSI bins for comparison purposes. Table 9: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K ANSI Bin (for reference only) (4745K - 5311K) 04 (4SDCM) (4801K - 5282K) Center Point (x,y) (0.3447, 0.3553) Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 22 of 24 Design Resources Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with Bridgelux LED Array products. Included below is a list of available resources which can be downloaded from the Bridgelux web site under the Design Resources section. These documents are updated regularly as new information becomes available, including complimentary infrastructure products such as commercially available secondary optics and electronic driver solutions. Application Notes      AN40: AN41: AN42: AN44: AN46: Effective Thermal Management of Bridgelux LED Arrays Assembly Considerations for Bridgelux LED Arrays Electrical Drive Considerations for Bridgelux LED Arrays Reliability Data Sheet for Bridgelux LED Arrays Optical Considerations for Bridgelux LED Arrays Optical Source Models Optical source models and ray set files are available for all Bridgelux LED Array products, and can be downloaded directly from the Bridgelux web site. The list below contains the formats currently available. If you require a specific format not included in this list, please contact your Bridgelux sales representative for assistance.          Zemax ASAP IESNA LightTools LucidShape OPTIS SPEOS PHOTOPIA TracePro Radiant Imaging Source Model 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux LED Arrays are available in both SAT and STEP formats. These CAD files can be downloaded directly from the Bridgelux web site. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 23 of 24 About Bridgelux Bridgelux is a leading developer and manufacturer of technologies and solutions transforming the $40 billion global lighting industry into a $100 billion market opportunity. Based in Livermore, California, Bridgelux is a pioneer in solid-state lighting (SSL), expanding the market for light-emitting diode (LED) technologies by driving down the cost of LED lighting systems. Bridgelux’s patented light source technology replaces traditional technologies (such as incandescent, halogen, fluorescent and high intensity discharge lighting) with integrated, solid-state lighting solutions that enable lamp and luminaire manufacturers to provide high performance and energy-efficient white light for the rapidly growing interior and exterior lighting markets, including street lights, commercial lighting and consumer applications. With more than 550 patent applications filed or granted worldwide, Bridgelux is the only vertically integrated LED manufacturer and developer of solid-state light sources that designs its solutions specifically for the lighting industry. For more information about the company, please visit www.bridgelux.com © 2013 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux V8 Array Product Data Sheet DS41 (10/11/2013) Page 24 of 24
BXRE-27G0800-A-03
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
BXRE-27G0800-A-03 价格&库存
很抱歉,暂时无法提供与“BXRE-27G0800-A-03”相匹配的价格&库存,您可以联系我们找货
BXRE-27G0800-A-03
  • 1+42.08516
  • 10+37.48154
  • 25+34.12374
  • 50+31.86939
  • 100+29.31842
  • 500+28.16751
