TR-SS1-E36P
TR-SS1-E36P
    THOMASRESEARCHPRODUCTS
    LED CORE TYPE V SHT 41W 4115 LM
TR-SS1-E36P 数据手册
Thomas Research Products SSL Solutions Faster Than The Speed Of Light ® TR-SS1 LED Core™ • Die-cast single piece aluminum body • UV stabilized polycarbonate lens with injection-molded frame • Universal voltage (100-277Vac) • Patented design is robust, for superb durability • Modular: Key components can be refurbished • Type V short Integrated LED Canopy Module Patented Design, with 0-10V Dimming TR-SS1 Integrated LED Canopy Module is designed to seamlessly integrate into just about any canopy fixture. We have taken the tedious engineering task out of designing an LED solution. Combining cutting-edge optical characteristics and integrated LED driver, it’s simpler than ever. We can provide your engineering staff a full set of CAD files to speed along the integration process. Includes 0-10V Dimming as standard. Electrical: Class 1 and 2 power supplies accommodate an input voltage range of 100-277V 50/60Hz. All power supplies provide Class A EMI rating with high power factor of 90% typical. Mounting: Custom fixture mount only. CAD and Step files available to streamline integration. Fixture cut out pattern show on next page. Exterior Surface Finish: Powder coated die-cast aluminum. Testing and Compliance: The TR-SS1 meets UL8750 specifications. Contact our engineering staff for assistance in certifying your fixture. Lumen Maintenance: Lumen maintenance will vary substantially based upon fixture in which the TR-SS1 is mounted. Additional heat dissipating capacity from fixture is highly recommended to maximize lumen maintenance. Lumen maintenance to be determined by using LM80, in situ thermal data in accordance with DOE/EPA standards and reliability data supplied by LED Manufacturer. • Maintains a tolerance of ± 7% on flux measurements. • Published output measurements using 4500K. • Typical CRI for Neutral White (5000K) is 75. • Output lumens will vary depending on factors involved with fixture integration. • 5 year limited warranty with validation of fixture. Environmental Impact • RoHS Compliant • No mercury • Reduction in Kw load by as much as 60% SS1 Series LED Canopy Module Replaces HID lamp* Energy Savings† 71* 70W HPS 50W 71* 100W HPS 75W 71* 150W MH 128W Model Number System Power Initial Delivered Lumens Lumens Per Watt TR-SS1-e36C 41W 2925 TR-SS1-e48C 55W 3900 TR-SS1-e72C 75W 5848 * Based on Mean Lumens † Compares LED Core™ system wattage to avg. HID ballast input wattage Specifications subject to change without notice. Thomas Research Products • 11548 Smith Dr. • Huntley, IL 60142 • T: 847-515-3057 • F: 847-515-3047 • www.trpssl.com 7-09-13 Thomas Research Products SSL Solutions Faster Than The Speed Of Light ® TR-SS1-C Pg 2 of 2 Photometrics Dimensions TR-SS1 Canopy Type V Short: Tested to IESNA LM-79 standard by an indepedent testing laboratory. Page 1 of 2 2.51” TR-SS1-72C Photometric Data 10.00” 334 2.5° 10.00” Mounting R.10, 4 places 8.50” 0.10” Flood Summary Efficiency Lumens Horizontal Spread Vertical Spread Mounting Examples: Field (10%): 97.9% Canopy Luminaires Beam (50%): 80.4% 5,411.2 159.9 160.4 4,442.9 113.6 117.8 Total: 5,523.2 100% Lumens Per Zone Zone Lumens % Total Zone 2.90” 3.00” 8.50” 2.90” Lumens % Total 0-10 103.0 1.9% 90-100 16.6 10-20 279.8 5.1% 100-110 0.8 0.3% 0% 20-30 541.6 9.8% 110-120 0 0% 30-40 1,003.0 18.2% 120-130 0 0% 40-50 1,201.1 21.7% 130-140 0 0% 50-60 1,108.0 20.1% 140-150 0 0% 60-70 763.1 13.8% 150-160 0 0% 70-80 381.7 6.9% 160-170 0 0% 80-90 126.6 2.3% 170-180 0 0% R.20, 4 places 2.90” 3.00” 2.90” Material to be 0.1" Aluminum Application Notes: 1) T  he LED Core™ is intended to be mounted to a flange of the fixture, situated between the LED Core™ module’s lens frame/lens/ gasket and aluminum body in order to qualify for IP rating. (See detail.) 2) The LED Core™ module can be mounted to the fixture flange on the backside of the module’s body. Mounting holes are not provided. This is not recommended as it will not achieve an IP rating. Thomas Research Products • 11548 Smith Dr. • Huntley, IL 60142 • T: 847-515-3057 • F: 847-515-3047 • www.trpssl.com
TR-SS1-E36P 价格&库存
很抱歉,暂时无法提供与“TR-SS1-E36P”相匹配的价格&库存,您可以联系我们找货
