LTPL-M02520ZS40-T0
LTPL-M02520ZS40-T0
    LITE-ON(光宝)
    SMD
    LED Lighting COBs, Engines, Modules Chip On Board (COB) LTPL-M02 White, Neutral Square
LTPL-M02520ZS40-T0 数据手册
LED HIGH POWER CoB Product Series LED HIGH POWER CoB Product Series Data Sheet Created Date: 02 / 06 / 2013 Revision: 4.0, 03 / 12/ 2014 1 BNC-OD-C131/A4 Created Date : 05/26/2007 Revison : 1.01, 05/26/2008 LED HIGH POWER CoB Product Series 1. Description The LiteON CoB Product series is a revolutionary, energy efficient and ultra compact new light source, combining the lifetime and reliability advantages of Light Emitting Diodes with the brightness of conventional lighting. It gives you total design freedom and unmatched brightness, creating a new opportunities for solid state lighting to displace conventional lighting technologies. 1.1 Features        Compact high flux density light source Uniform high quality illumination Streamlined thermal path MacAdam compliant binning structure More energy efficient than incandescent, halogen and fluorescent lamps Instant light with unlimited dimming RoHS compliant and Pb free 1.2 Benefits Features        Enhanced optical control Clean white light without pixilation Uniform consistent white light Significantly reduced thermal resistance and increased operating temperatures Lower operating costs Reduced maintenance costs ESD rating is 8KV in HBM 1.3 Naming Rule 02 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series 1.4 Product List PN Watt CCT Color Bin CRI 3SDCM LTPL-M02520ZS27-T0 20 2700K 80 LTPL-M02520ZS27-S1 20 2700K 80 LTPL-M02520ZS30-T0 20 3000K 80 LTPL-M02520ZS30-S1 20 3000K 80 LTPL-M02520ZS40-T0 20 4000K 80 LTPL-M02520ZS40-S1 20 4000K 80 LTPL-M02520ZS50-F1 20 5000K 80 LTPL-M02520ZS50-S1 20 5000K 80 LTPL-M02520ZS57-F1 20 5700K 80 LTPL-M02520ZS57-S1 20 5700K 80 LTPL-M02530ZS27-T0 30 2700K 80 LTPL-M02530ZS27-S1 30 2700K 80 LTPL-M02530ZS30-T0 30 3000K 80 LTPL-M02530ZS30-S1 30 3000K 80 LTPL-M02530ZS40-T0 30 4000K 80 LTPL-M02530ZS40-S1 30 4000K 80 LTPL-M02530ZS50-F1 30 5000K 80 LTPL-M02530ZS50-S1 30 5000K 80 LTPL-M02530ZS57-F1 30 5700K 80 LTPL-M02530ZS57-S1 30 5700K 80 5SDCM Lumen Bin 7SDCM ☆ -8%~+8% -15%~+15% ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ ☆ 03 ☆ BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series 2. Outline Dimensions 20W Product 30W Product 1. All dimensions are in millimeters. 2. Tolerance is ±0.2mm (0.008”) unless otherwise noted. 3. LED of equivalent circuit means all series/parallel in CoB package. 04 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series 3. Absolute Maximum Ratings at Ta=25°C Parameter Power Dissipation Forward Current Symbol Po IF Watt Rating 20 32.0 30 44.8 20 800 30 1120 Unit W mA Reverse Voltage VR 45 V Junction Temperature Tj 125 °C Thermal Resistance, Junction-Case Rth, J-C 20 1.20 30 0.80 °C / W Operating Temperature Range Topr -40 to 85 °C Storage Temperature Range Tstg -40 to 100 °C Breakdown Voltage(DC) VB 2.25 KV Electrostatic Discharge ESD 8 KV Notes 1. 2. 3. 4. 5. The pulse mode condition is 1/10 duty cycle with 100 msec pulse width. Forbid to be operated at reverse voltage condition. ESD spec is reference to AEC-Q101-001 HBM. The unit of Rth is °C/W electrical. The M02 CoB is recommended soldering temperature under 350degC and could not over 3.5sec. 05 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series 4. Electro-Optical Characteristics 4.1 Typical Performance Dominant Current VF (V) Flux(lm) VF (V) Flux(lm) Eff.(lm/W) Eff.(lm/W) (mA) @25°C @25°C @85°C @85°C @25°C @85°C 20 480 35.7 2139 34.6 1925 125 116 30 720 35.9 3135 34.8 2822 121 113 20 480 35.7 2252 34.6 2026 131 122 30 720 35.9 3300 34.8 2970 128 118 20 480 35.7 2387 34.6 2148 139 129 30 720 35.9 3498 34.8 3148 135 126 20 480 35.7 2454 34.6 2209 143 133 30 720 35.9 3597 34.8 3237 139 129 20 480 35.7 2285 34.6 2057 133 124 30 720 35.9 3350 34.8 3015 130 120 Watt CCT 2700K 3000K 4000K 5000K 5700K Notes 1. 2. 3. 4. 5. All of VF value are typical, the real range is 33.0-39.8 volt, please refer page 20 ”VF Binning Parameter”. All of Flux value are typical, the real Bin range please refer page 13 ”Flux Binning Parameter”. Tolerance of flux is ±7%, tolerance of CCX/CCY is ±0.007, tolerance of CRI is ±2. Typical viewing angle is 120deg. R9>0 for CRI80 product. 06 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series 4.2 Forward Current vs. Lumen Voltage  20W Series Product Lumen (lm) Current (mA) VF (V) 2700K 3000K 4000K 5000K 5700K 350 34.7 1607 1692 1793 1844 1717 400 35.1 1819 1915 2030 2088 1944 450 35.4 2025 2132 2260 2324 2164 480 35.7 2139 2252 2387 2454 2285 500 35.8 2215 2331 2471 2541 2366 550 36.2 2418 2544 2697 2773 2583 600 36.5 2617 2755 2921 3003 2797 650 36.8 2796 2943 3120 3208 2988 700 37.2 2970 3126 3313 3407 3173 750 37.5 3173 3339 3539 3640 3389 07 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series  30W Series Product Lumen (lm) Current (mA) VF (V) 2700K 3000K 4000K 5000K 5700K 490 34.7 2217 2334 2474 2544 2369 560 35.1 2511 2643 2802 2881 2683 630 35.4 2794 2941 3118 3206 2986 700 35.8 3057 3218 3411 3507 3266 720 35.9 3135 3300 3498 3597 3350 770 36.2 3337 3512 3723 3828 3565 840 36.5 3612 3802 4030 4144 3859 910 36.8 3858 4061 4305 4427 4122 980 37.2 4097 4313 4572 4701 4378 1050 37.5 4378 4608 4884 5023 4677 08 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series 4.3 Relative Spectral Power Distribution at Typical Current 3000K 5000K 25degC 25degC 85degC 85degC 4.4 Radiation Characteristics 0° 100% 90% 30° Relative Intensity (%) 80% 70% 60% 60° 50% 40% 30% 20% 10% 0% 90° 60 30° 0° 50 100 09 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series 4.5 Forward Current vs. Forward Voltage 30W 20W 4.6 Forward Current Degrading Curve Rth, J-C=0.8°C /W Rth, J-C=1.2°C /W 010 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series 4.7 Relative Intensity vs. Case Temperature 011 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series 4.8 Forward Voltage vs. Case Temperature/Junction Temperature 20W Series Product (Typical Current=480mA) Tc(°C) Tj(°C) VF (V) % 25.0 45.5 35.7 100.00% 50.0 70.5 35.1 98.30% 75.0 95.5 34.6 97.00% 85.0 105.5 34.4 96.50% 30W Series Product (Typical Current=720mA) Tc(°C) Tj(°C) VF (V) % 25.0 45.7 35.9 100.00% 50.0 70.7 35.3 98.30% 75.0 95.7 34.9 97.00% 85.0 105.7 34.7 96.50% 012 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series 5. CoB Binning Definition  Example of M02 Series Product Bin (2700K 20W series)  Flux Binning Parameter (25degC) Lumen CODE List of M02 Series Product Parameter Code Unit 2700K Lumen 1830 Bin Range D 1975 CD 1830~1975 E 2130 DF 1975~2300 F 2300 FG 2300~2485 G 2485 2680 I 2890 J 3120 K 3370 L 3640 M 3925 N 4240 Lumen Range Bin Code lm Flux CCT C H Luminous Lumen (lm) Main Bin C D F -15%~-8% -8%~+8% G +8%~+15% Full Bins  20 Series Lumen Bin Lumen (lm) 2700K 3000K 4000K 5000K 5700K Bin Range Bin Range Bin Range Bin Range Bin Range CD 1830~1975 CD 1830~1975 DE 1975~2130 EF 2130~2300 DE 1975~2130 DF 1975~2300 DF 1975~2300 EG 2130~2485 FH 2300~2680 EG 2130~2485 FG 2300~2485 FG 2300~2485 GH 2485~2680 HI 2680~2890 GH 2485~2680  30 Series Lumen Bin Lumen (lm) 2700K 3000K 4000K 5000K 5700K Bin Range Bin Range Bin Range Bin Range Bin Range HI 2680~2890 IJ 2890~3120 JK 3120~3370 JK 3120~3370 IJ 2890~3120 IK 2890~3370 JL 3120~3640 KM 3370~3925 KM 3370~3925 JL 3120~3640 KL 3370~3640 LM 3640~3925 MN 3925~4240 MN 3925~4240 LM 3640~3925 013 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series  Example of LiteOn CoB MacAdam Ellipse Color Definition (EX: 2700K) Solid line in red/blue/black is 3SDCM/5SDCM/ANSI at 25degC. D3 It is shipping Spec. of LiteOn. D2 D1 Dotted line in light gray is 3SDCM/5SDCM/ANSI at 85degC and the CCX/CCY center follows ANSI. CIE Center Point 25degC (LiteOn Spec.) 85degC (ANSI) Hot/Cold Factor CCT CCX CCY CCX CCY CCX CCY 2700 0.4594 0.4147 0.4578 0.4101 -0.0016 -0.0046 3000 0.4369 0.4067 0.4338 0.4030 -0.0031 -0.0037 4000 0.3856 0.3844 0.3818 0.3797 -0.0038 -0.0047 5000 0.3489 0.3603 0.3447 0.3553 -0.0042 -0.0050 5700 0.3322 0.3417 0.3287 0.3417 -0.0035 -0.0054 Notes 1. 2. 3. 4. LiteOn tester and shipping spec follow the color bin with 25degC CCX/CCY center. The Hot/Cold factor means the CCX/CCY shift from 25degC to 85degC. The Hot/Cold shift is measured by LiteOn CAS 140B instrument system. 2 2 0.5 The ellipse equation expression: SDCM = (g11*(x-x0) + 2*g12*(x-x0)*(y-y0) + g22*(y-y0) ) 014 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series  M02 CRI80 2700K PN: LTPL-M025XXZS27-T0 D1 3-Step at 25degC PN: LTPL-M025XXZS27-S1 D3 D2 5-Step at 25degC ANSI at 25degC 015 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series  M02 CRI80 3000K PN: LTPL-M025XXZS30-T0 E1 3-Step at 25degC PN: LTPL-M025XXZS30-S1 E3 E2 5-Step at 25degC ANSI at 25degC 016 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series  M02 CRI80 4000K PN: LTPL-M025XXZS40-T0 G1 3-Step at 25degC PN: LTPL-M025XXZS40-S1 G3 G2 5-Step at 25degC ANSI at 25degC 017 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series  M02 CRI80 5000K PN: LTPL-M025XXZS50-F1 H1 5-Step at 25degC PN: LTPL-M025XXZS50-S1 H2 ANSI at 25degC 018 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series  M02 CRI80 5700K PN: LTPL-M025XXZS57-F1 J1 5-Step at 25degC PN: LTPL-M025XXZS57-S1 J2 ANSI at 25degC 019 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series  Forward Voltage Binning Parameter (25degC) Parameter Forward Voltage Bin Symbol Min Max Unit Condition V1 VF 33.0 39.8 V IF =Typical Current Note: Full Rank on Label Example: V1/DF/D1 Forward Voltage Rank Luminous Flux Rank Color Rank V1 DF D1 020 BNC-OD-C131/A4 Created Date : 02/06/2013 Revision : 4.0, 03/12/2014 LED HIGH POWER CoB Product Series 6. Reliability Test Plan No Test item Condition Duration Result 1 High Temperature Operating Life Tc=85°C, IF=Typical Current 1K hours Pass 2 Wet High Temperature Operating 60°C/90%RH, IF=Typical Current(DC) 1K hours Pass Life 30 min ON/OFF Thermal Shock -40°C to 125°C, 15minutes dwell,
LTPL-M02520ZS40-T0 价格&库存
很抱歉,暂时无法提供与“LTPL-M02520ZS40-T0”相匹配的价格&库存,您可以联系我们找货
