LTPL-M03614ZS50-F1
LTPL-M03614ZS50-F1
    LITE-ON(光宝)
    SMD
    LED CCT 5000K PLCC SMD
LTPL-M03614ZS50-F1 数据手册
LIGHT LED M03 CoB Product Series 1. Description The LiteON CoB Product series is a revolutionary, energy efficient and ultra-compact new light source, combining the lifetime and reliability advantages of Light Emitting Diodes with the brightness of conventional lighting. It gives you total design freedom and unmatched brightness, creating a new opportunities for solid state lighting to displace conventional lighting technologies. 1.1 Features        Compact high flux density light source Uniform high quality illumination Streamlined thermal path MacAdam compliant binning structure More energy efficient than incandescent, halogen and fluorescent lamps Instant light with unlimited dimming RoHS compliant and Pb free 1.2 Benefits Features        Enhanced optical control Clean white light without pixilation Uniform consistent white light Significantly reduced thermal resistance and increased operating temperatures Lower operating costs Reduced maintenance costs ESD rating is 8KV in HBM 1.3 Naming Rule 1/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 1.4 Product List Part Number Product CCT Color Bin CRI Series Lumen Bin 3SDCM 5SDCM ANSI -8%~+8% -15%~+15% LTPL-M03614ZS27-T0 14 2700K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M03614ZS30-T0 14 3000K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M03614ZS40-T0 14 4000K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M03622ZS27-T0 22 2700K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M03622ZS30-T0 22 3000K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M03622ZS40-T0 22 4000K 80 ☆ ☆ ☆ ☆ ☆ 2/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 2. Outline Dimensions 2.1 Form Factor of M036 series CoB Notes 1. All dimensions are in millimeters. 2. Tolerance is ±0.3mm unless otherwise noted. 3. LED of equivalent circuit means all series/parallel in CoB package. 2.2 Internal Equivalent Circuit 14 Series Product 22 Series Product 3/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 3. Absolute Maximum Ratings at Ta=25°C Parameter Power Dissipation Forward Current Symbol Product Series Rating Code 4 PO 14 16 22 24 14 400 22 600 W IF Junction Temperature Thermal Resistance, Junction-Case Unit mA Tj Rth, J-C 125 14 1.7 22 1.2 °C °C/W Operating Temperature Range Topr -40 to 85 °C Storage Temperature Range Tstg -40 to 100 °C Breakdown Voltage(DC) VB 2.25 KV Electrostatic Discharge ESD 8 KV Notes 1. 2. 3. 4. 5. The pulse mode condition is 1/10 duty cycle with 100 msec pulse width. Forbid to be operated at reverse voltage condition. ESD spec is reference to AEC-Q101-001 HBM. The unit of Rth is °C/W electrical. The M03 CoB is recommended soldering temperature under 350degC and could not over 3.5sec. 4/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 4. Electro-Optical Characteristics 4.1 Typical Performance  14 Series Product Dominant Product Current VF (V) Flux(lm) VF (V) Flux(lm) Eff.(lm/W) Eff.(lm/W) CCT Series (mA) @25°C @25°C @85°C @85°C @25°C @85°C 2700K 14 350 38.5 1546 37.7 1391 115 105 3000K 14 350 38.5 1610 37.7 1448 119 110 4000K 14 350 38.5 1707 37.7 1535 127 116  22 Series Product Dominant Product Current VF (V) Flux(lm) VF (V) Flux(lm) Eff.(lm/W) Eff.(lm/W) CCT Series (mA) @25°C @25°C @85°C @85°C @25°C @85°C 2700K 22 500 38.3 2284 37.5 2055 119 110 3000K 22 500 38.3 2360 37.5 2123 123 113 4000K 22 500 38.3 2500 37.5 2249 131 120 Notes 1. 2. 3. 4. All of VF value are typical, the real bin range please refer page 14 ” VF Binning Parameter”. All of flux value are typical, the real bin range please refer page 13 ”Flux Binning Parameter”. Tolerance of flux is ±7%, tolerance of CCX/CCY is ±0.007, tolerance of CRI is ±2, and tolerance of VF is ±3%. Typical viewing angle is 120deg. 5/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 4.2 Forward Current vs. Lumen and Voltage  14 Series Product Flux (lm) Current (mA) VF (V) 2700K 3000K 4000K CRI>80 CRI>80 CRI>80 50 33.0 355 374 390 75 33.5 457 475 506 100 33.9 553 586 613 125 34.4 657 687 732 150 34.9 766 794 847 175 35.3 857 899 955 200 35.8 962 991 1067 225 36.3 1073 1103 1168 250 36.7 1172 1221 1293 275 37.2 1271 1303 1398 300 37.6 1347 1415 1516 325 38.1 1457 1504 1589 350 38.5 1546 1610 1707 375 38.9 1642 1687 1786 400 39.3 1711 1782 1893 6/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series  22 Series Product Flux (lm) Current (mA) VF (V) 2700K 3000K 4000K CRI>80 CRI>80 CRI>80 250 35.2 1248 1311 1381 275 35.6 1369 1423 1490 300 35.9 1483 1538 1610 325 36.2 1530 1629 1704 350 36.5 1676 1748 1853 375 36.8 1772 1867 1953 400 37.1 1872 1977 2087 425 37.4 1980 2086 2185 450 37.7 2096 2190 2289 475 38 2161 2267 2398 500 38.3 2284 2360 2500 525 38.6 2378 2473 2594 550 38.9 2448 2550 2703 575 39.1 2555 2661 2801 600 39.4 2627 2742 2877 7/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 4.3 Relative Spectral Power Distribution at Typical Current 3000K 25degC 85degC 4.4 Radiation Characteristics 0° 100% 90% 30° Relative Intensity (%) 80% 70% 60% 60° 50% 40% 30% 20% 10% 0% 90° 60 30° 0° 50 8/21 100 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 4.5 Forward Current vs. Forward Voltage 9/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 4.6 Forward Voltage vs. Junction Temperature Forward Voltage vs. Junction Temperature 10/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 4.7 Relative Intensity vs. Junction Temperature Relative Intensity vs. Case Temperature 11/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 4.8 Forward Current Degrading Curve 12/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 5. CoB Binning Definition  Example of M03 Series Product Bin (2700K 14 series)  Flux Binning Parameter (25degC) Lumen (lm) Lumen CODE List of M03 Series Product Parameter Code Unit 2700K Lumen CCT I 1345 Bin Range J 1455 IJ 1345~1455 K 1570 JL 1455~1695 L 1695 LM 1695~1830 M 1830 Lumen Range Luminous N lm 1975 Bin Code Flux O 2130 P 2300 Q 2485 R 2680 S 2890 Main Bin I J -15%~-8% L -8%~+8% M +8%~+15% Full Bins  14 Series Lumen Bin Lumen (lm) 2700K 3000K 4000K Bin Range Bin Range Bin Range IJ 1345~1455 IJ 1345~1455 JK 1455~1570 JL 1455~1695 JL 1455~1695 KM 1570~1830 LM 1695~1830 LM 1695~1830 MN 1830~1975 13/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series  22 Series Lumen Bin Lumen (lm) 2700K 3000K 4000K Bin Range Bin Range Bin Range NO 1975~2130 NO 1975~2130 OP 2130~2300 OQ 2130~2485 OQ 2130~2485 PR 2300~2680 QR 2485~2680 QR 2485~2680 RS 2680~2890  Forward Voltage Binning Parameter (25decgC) Parameter Bin Symbol Min Max Unit Condition Forward Voltage V1 VF 33.6 42 V IF=Typical current Note: Full Rank on Label Example: V1/DF/D1 Forward Voltage Rank Luminous Flux Rank Color Rank V1 DF D1 14/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series  Example of LiteOn CoB MacAdam Ellipse Color Definition (Ex: 3000K) Solid line in red/blue/black is E3 3SDCM/5SDCM/ANSI at 25degC. It is shipping Spec. of LiteOn. E2 E1 Dotted line in light gray is 3SDCM/5SDCM/ANSI at 85degC and the CCX/CCY center follows ANSI. follows ANSI C78.377A. CIE Center Point 25degC (LiteOn Spec.) 85degC (ANSI) Hot/Cold Factor CCT CCX CCY CCX CCY CCX CCY 2700 0.4582 0.4150 0.4578 0.4101 -0.0004 -0.0049 3000 0.4352 0.4083 0.4338 0.403 -0.0014 -0.0053 4000 0.3849 0.3856 0.3818 0.3797 -0.0031 -0.0059 Notes     LiteOn tester and shipping spec follow the color bin with 25degC CCX/CCY center. The Hot/Cold factor means the CCX/CCY shift from 25degC to 85degC. The Hot/Cold shift is measured by LiteOn CAS 140B instrument system. 2 2 0.5 The ellipse equation expression: SDCM = (g11*(x-x0) + 2*g12*(x-x0)*(y-y0) + g22*(y-y0) ) 15/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series  M03 CRI80 2700K PN: LTPL-M036xxZS27-T0 D3 5-Step at 25degC D2 ANSI at 25degC D1 3-Step at 25degC 16/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series  M03 CRI80 3000K PN: LTPL-M036xxZS30-T0 E3 5-Step at 25degC ANSI at 25degC E2 E1 3-Step at 25degC  M03 CRI80 4000K PN: LTPL-M036xxZS40-T0 G3 5-Step at 25degC ANSI at 25degC G2 G1 1 3-Step at 25degC 17/21 Part No. : M03 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M03 CoB Product Series 6. Reliability Test Plan Number No Test item Condition Duration Result of Failed High Temperature 1 Tc=85°C, IF =Typical Current 1K hours 0/10 Pass 1K hours 0/10 Pass 500 cycles 0/10 Pass 40K cycles 0/10 Pass Ta=120°C 1K hours 0/10 Pass Ta=-55°C 1K hours 0/10 Pass 0/10 Pass 0/10 Pass Operating Life Wet High 60°C/90%RH, IF =Typical Current(DC) 2 Temperature 30 mins ON/OFF Operating Life -40°C to 125°C, 15minutes dwell, 3 Thermal Shock
LTPL-M03614ZS50-F1 价格&库存
很抱歉,暂时无法提供与“LTPL-M03614ZS50-F1”相匹配的价格&库存,您可以联系我们找货
