LED HIGH POWER
CoB Product Series
LED HIGH POWER
CoB Product Series
Data Sheet
Created Date: 02 / 06 / 2013
Revision: 4.0, 03 / 12/ 2014
1
BNC-OD-C131/A4
Created Date : 05/26/2007
Revison : 1.01, 05/26/2008
LED HIGH POWER
CoB Product Series
1. Description
The LiteON CoB Product series is a revolutionary, energy efficient and ultra compact new light source, combining the lifetime
and reliability advantages of Light Emitting Diodes with the brightness of conventional lighting. It gives you total design freedom
and unmatched brightness, creating a new opportunities for solid state lighting to displace conventional lighting technologies.
1.1 Features
Compact high flux density light source
Uniform high quality illumination
Streamlined thermal path
MacAdam compliant binning structure
More energy efficient than incandescent, halogen and
fluorescent lamps
Instant light with unlimited dimming
RoHS compliant and Pb free
1.2 Benefits Features
Enhanced optical control
Clean white light without pixilation
Uniform consistent white light
Significantly reduced thermal resistance and increased
operating temperatures
Lower operating costs
Reduced maintenance costs
ESD rating is 8KV in HBM
1.3 Naming Rule
02
BNC-OD-C131/A4
Created Date : 02/06/2013
Revision : 4.0, 03/12/2014
LED HIGH POWER
CoB Product Series
1.4 Product List
PN
Watt
CCT
Color Bin
CRI
3SDCM
LTPL-M02520ZS27-T0
2700K
80
LTPL-M02520ZS27-S1
2700K
80
LTPL-M02520ZS30-T0
3000K
80
LTPL-M02520ZS30-S1
3000K
80
LTPL-M02520ZS40-T0
4000K
80
LTPL-M02520ZS40-S1
4000K
80
LTPL-M02520ZS50-F1
5000K
80
LTPL-M02520ZS50-S1
5000K
80
LTPL-M02520ZS57-F1
5700K
80
LTPL-M02520ZS57-S1
5700K
80
LTPL-M02530ZS27-T0
30
2700K
80
LTPL-M02530ZS27-S1
30
2700K
80
LTPL-M02530ZS30-T0
30
3000K
80
LTPL-M02530ZS30-S1
30
3000K
80
LTPL-M02530ZS40-T0
30
4000K
80
LTPL-M02530ZS40-S1
30
4000K
80
LTPL-M02530ZS50-F1
30
5000K
80
LTPL-M02530ZS50-S1
30
5000K
80
LTPL-M02530ZS57-F1
30
5700K
80
LTPL-M02530ZS57-S1
30
5700K
80
5SDCM
Lumen Bin
7SDCM
-8%~+8%
-15%~+15%
03
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
2. Outline Dimensions
20W Product
30W Product
1. All dimensions are in millimeters.
2. Tolerance is ±0.2mm (0.008”) unless otherwise noted.
3. LED of equivalent circuit means all series/parallel in CoB package.
04
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
3. Absolute Maximum Ratings at Ta=25°C
Parameter
Power Dissipation
Forward Current
Symbol
Po
IF
Watt
Rating
30
44.8
30
1120
Unit
W
mA
Reverse Voltage
VR
45
V
Junction Temperature
Tj
125
°C
Thermal Resistance, Junction-Case
Rth, J-C
30
0.80
°C / W
Operating Temperature Range
Topr
-40 to 85
°C
Storage Temperature Range
Tstg
-40 to 100
°C
Breakdown Voltage(DC)
VB
2.25
KV
Electrostatic Discharge
ESD
8
KV
Notes
1.
2.
3.
4.
5.
The pulse mode condition is 1/10 duty cycle with 100 msec pulse width.
Forbid to be operated at reverse voltage condition.
ESD spec is reference to AEC-Q101-001 HBM.
The unit of Rth is °C/W electrical.
The M02 CoB is recommended soldering temperature under 350degC and could not over 3.5sec.
05
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
4. Electro-Optical Characteristics
4.1 Typical Performance
Dominant
Current
VF (V)
Flux(lm)
VF (V)
Flux(lm)
Eff.(lm/W)
Eff.(lm/W)
(mA)
@25°C
@25°C
@85°C
@85°C
@25°C
@85°C
35.7
2139
34.6
1925
125
116
30
720
35.9
3135
34.8
2822
121
113
35.7
2252
34.6
2026
131
122
30
720
35.9
3300
34.8
2970
128
118
35.7
2387
34.6
2148
139
129
30
720
35.9
3498
34.8
3148
135
126
35.7
2454
34.6
2209
143
133
30
720
35.9
3597
34.8
3237
139
129
35.7
2285
34.6
2057
133
124
30
720
35.9
3350
34.8
3015
130
120
Watt
CCT
2700K
3000K
4000K
5000K
5700K
Notes
1.
2.
3.
4.
5.
All of VF value are typical, the real range is 33.0-39.8 volt, please refer page 20 ”VF Binning Parameter”.
All of Flux value are typical, the real Bin range please refer page 13 ”Flux Binning Parameter”.
Tolerance of flux is ±7%, tolerance of CCX/CCY is ±0.007, tolerance of CRI is ±2.
Typical viewing angle is 120deg.
R9>0 for CRI80 product.
06
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
4.2 Forward Current vs. Lumen Voltage
20W Series Product
Lumen (lm)
Current (mA)
VF (V)
2700K
3000K
4000K
5000K
5700K
350
34.7
1607
1692
1793
1844
1717
400
35.1
1819
1915
2030
2088
1944
450
35.4
2025
2132
2260
2324
2164
480
35.7
2139
2252
2387
2454
2285
500
35.8
2215
2331
2471
2541
2366
550
36.2
2418
2544
2697
2773
2583
600
36.5
2617
2755
2921
3003
2797
650
36.8
2796
2943
3120
3208
2988
700
37.2
2970
3126
3313
3407
3173
750
37.5
3173
3339
3539
3640
3389
07
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
30W Series Product
Lumen (lm)
Current (mA)
VF (V)
2700K
3000K
4000K
5000K
5700K
490
34.7
2217
2334
2474
2544
2369
560
35.1
2511
2643
2802
2881
2683
630
35.4
2794
2941
3118
3206
2986
700
35.8
3057
3218
3411
3507
3266
720
35.9
3135
3300
3498
3597
3350
770
36.2
3337
3512
3723
3828
3565
840
36.5
3612
3802
4030
4144
3859
910
36.8
3858
4061
4305
4427
4122
980
37.2
4097
4313
4572
4701
4378
1050
37.5
4378
4608
4884
5023
4677
08
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
4.3 Relative Spectral Power Distribution at Typical Current
3000K
5000K
25degC
25degC
85degC
85degC
4.4 Radiation Characteristics
0°
100%
90%
30°
Relative Intensity (%)
80%
70%
60%
60°
50%
40%
30%
20%
10%
0%
90°
60
30°
0°
50
100
09
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
4.5 Forward Current vs. Forward Voltage
30W
20W
4.6 Forward Current Degrading Curve
Rth,
J-C=0.8°C
/W
Rth,
J-C=1.2°C
/W
010
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
4.7 Relative Intensity vs. Case Temperature
011
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
4.8 Forward Voltage vs. Case Temperature/Junction Temperature
20W Series Product
(Typical Current=480mA)
Tc(°C)
Tj(°C)
VF (V)
25.0
45.5
35.7
100.00%
50.0
70.5
35.1
98.30%
75.0
95.5
34.6
97.00%
85.0
105.5
34.4
96.50%
30W Series Product
(Typical Current=720mA)
Tc(°C)
Tj(°C)
VF (V)
25.0
45.7
35.9
100.00%
50.0
70.7
35.3
98.30%
75.0
95.7
34.9
97.00%
85.0
105.7
34.7
96.50%
012
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
5. CoB Binning Definition
Example of M02 Series Product Bin (2700K 20W series)
Flux Binning Parameter (25degC)
Lumen CODE List of M02 Series Product
Parameter
Code
Unit
2700K
Lumen
1830
Bin
Range
D
1975
CD
1830~1975
E
2130
DF
1975~2300
F
2300
FG
2300~2485
G
2485
2680
I
2890
J
3120
K
3370
L
3640
M
3925
N
4240
Lumen Range
Bin Code
lm
Flux
CCT
C
H
Luminous
Lumen (lm)
Main Bin
C
D
F
-15%~-8%
-8%~+8%
G
+8%~+15%
Full Bins
20 Series Lumen Bin
Lumen (lm)
2700K
3000K
4000K
5000K
5700K
Bin
Range
Bin
Range
Bin
Range
Bin
Range
Bin
Range
CD
1830~1975
CD
1830~1975
DE
1975~2130
EF
2130~2300
DE
1975~2130
DF
1975~2300
DF
1975~2300
EG
2130~2485
FH
2300~2680
EG
2130~2485
FG
2300~2485
FG
2300~2485
GH
2485~2680
HI
2680~2890
GH
2485~2680
30 Series Lumen Bin
Lumen (lm)
2700K
3000K
4000K
5000K
5700K
Bin
Range
Bin
Range
Bin
Range
Bin
Range
Bin
Range
HI
2680~2890
IJ
2890~3120
JK
3120~3370
JK
3120~3370
IJ
2890~3120
IK
2890~3370
JL
3120~3640
KM
3370~3925
KM
3370~3925
JL
3120~3640
KL
3370~3640
LM
3640~3925
MN
3925~4240
MN
3925~4240
LM
3640~3925
013
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
Example of LiteOn CoB MacAdam Ellipse Color Definition (EX: 2700K)
Solid line in red/blue/black is
3SDCM/5SDCM/ANSI at 25degC.
D3
It is shipping Spec. of LiteOn.
D2
D1
Dotted line in light gray is
3SDCM/5SDCM/ANSI at 85degC and
the CCX/CCY center follows ANSI.
CIE Center Point
25degC (LiteOn Spec.)
85degC (ANSI)
Hot/Cold Factor
CCT
CCX
CCY
CCX
CCY
CCX
CCY
2700
0.4594
0.4147
0.4578
0.4101
-0.0016
-0.0046
3000
0.4369
0.4067
0.4338
0.4030
-0.0031
-0.0037
4000
0.3856
0.3844
0.3818
0.3797
-0.0038
-0.0047
5000
0.3489
0.3603
0.3447
0.3553
-0.0042
-0.0050
5700
0.3322
0.3417
0.3287
0.3417
-0.0035
-0.0054
Notes
1.
2.
3.
4.
LiteOn tester and shipping spec follow the color bin with 25degC CCX/CCY center.
The Hot/Cold factor means the CCX/CCY shift from 25degC to 85degC.
The Hot/Cold shift is measured by LiteOn CAS 140B instrument system.
2
2 0.5
The ellipse equation expression: SDCM = (g11*(x-x0) + 2*g12*(x-x0)*(y-y0) + g22*(y-y0) )
014
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
M02 CRI80 2700K
PN: LTPL-M025XXZS27-T0
D1
3-Step at 25degC
PN: LTPL-M025XXZS27-S1
D3
D2
5-Step at 25degC
ANSI at 25degC
015
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
M02 CRI80 3000K
PN: LTPL-M025XXZS30-T0
E1
3-Step at 25degC
PN: LTPL-M025XXZS30-S1
E3
E2
5-Step at 25degC
ANSI at 25degC
016
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
M02 CRI80 4000K
PN: LTPL-M025XXZS40-T0
G1
3-Step at 25degC
PN: LTPL-M025XXZS40-S1
G3
G2
5-Step at 25degC
ANSI at 25degC
017
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
M02 CRI80 5000K
PN: LTPL-M025XXZS50-F1
H1
5-Step at 25degC
PN: LTPL-M025XXZS50-S1
H2
ANSI at 25degC
018
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
M02 CRI80 5700K
PN: LTPL-M025XXZS57-F1
J1
5-Step at 25degC
PN: LTPL-M025XXZS57-S1
J2
ANSI at 25degC
019
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
Forward Voltage Binning Parameter (25degC)
Parameter
Forward Voltage
Bin
Symbol
Min
Max
Unit
Condition
V1
VF
33.0
39.8
V
IF =Typical Current
Note: Full Rank on Label
Example: V1/DF/D1
Forward Voltage Rank
Luminous Flux Rank
Color Rank
V1
DF
D1
020
BNC-OD-C131/A4
LED HIGH POWER
CoB Product Series
6. Reliability Test Plan
No
Test item
Condition
Duration
Result
1
High Temperature Operating Life
Tc=85°C, IF=Typical Current
1K hours
Pass
2
Wet High Temperature Operating
60°C/90%RH, IF=Typical Current(DC)
1K hours
Pass
Life
30 min ON/OFF
Thermal Shock
-40°C to 125°C, 15minutes dwell,
很抱歉,暂时无法提供与“LTPL-M02530ZS27-T0”相匹配的价格&库存,您可以联系我们找货
