SMTL6-UWDN
SMTL6-UWDN
    BIVAR
    PLCC-6
    SMTL6-UWDN
SMTL6-UWDN 数据手册
PLCC6 SMD Top View Package LED SMTL6-UWDN, NEUTRAL WHITE SMTL6-UWDN ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard PLCC6 Footprint Low Profile Package High Luminous Intensity Wide Viewing Angle High Power Efficiency Equipped with Protective Zener Diode Bivar SMTL6 LED is offered in an industry standard PLCC6 package with high luminous intensity and wide viewing angles. The miniature package is ideal for small scale applications such as illumination, general indication, and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment. The flexible three chip design allows for a wide variety of lighting options where the chips can be individually driven or in combinations. Bivar SMTL6 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Lumen Typ. mcd Lens Color Viewing Angle SMTL6-UWDN InGaN Neutral White 4000 Diffused 140° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision A 02/16 Page 1 of 5 PLCC6 SMD Top View Package LED SMTL6-UWDN, NEUTRAL WHITE Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 100 mW Continuous Forward Current 30 mA Peak Forward Current 1 75 mA Electrostatic Discharge Classification (HBM) 2000 V Reverse Voltage 5V Derating Linear From 25°C 0.4 mA/°C Operating Temperature Range -30 ~ +85°C Storage Temperature Range -40 ~ +100°C Soldering Temperature 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 60 mA unless otherwise noted Emitting Color Neutral White Recommend Forward Current (mA) Forward Voltage (V)1 MIN TYP MAX 3.0 3.3 3.6 Reverse Viewing Chromaticity Luminous Current (µA) Coordinates (XY)2 / Angle Intensity (mcd)3 VR=5V 2 Ө ½ (deg) CCT (Kelvin) TYP MAX TYP MIN MAX TYP 60 10 X=0.30 , Y=0.30 5500K 3000 5000 140 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Chromaticity Coordinates : ±0.02. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Radiation Diagram Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision A 02/16 Page 2 of 5 PLCC6 SMD Top View Package LED SMTL6-UWDN, NEUTRAL WHITE Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision A 02/16 Page 3 of 5 PLCC6 SMD Top View Package LED SMTL6-UWDN, NEUTRAL WHITE Recommended Soldering Conditions Tape and Reel Dimensions Note: 1000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision A 02/16 Page 4 of 5 PLCC6 SMD Top View Package LED SMTL6-UWDN, NEUTRAL WHITE Packaging and Labeling Plan Note: 1 Reel / Bag Sealed ESD and Moisture Barrier Bag Internal Quality Control Label X.XXX Humidity Indicator Card Desiccant X.XXX Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision A 02/16 Page 5 of 5
SMTL6-UWDN 价格&库存
很抱歉,暂时无法提供与“SMTL6-UWDN”相匹配的价格&库存,您可以联系我们找货
SMTL6-UWDN
  • 1+33.336121+4.31064
  • 10+24.4290210+3.15888
  • 100+19.17351100+2.47929
  • 500+16.86912500+2.18132
库存:614
SMTL6-UWDN
  • 1000+16.119091000+2.08433
  • 2000+15.484502000+2.00228
  • 3000+15.159653000+1.96027
  • 5000+14.793225000+1.91289
库存:614
