BXRC-50E2000-C-04
BXRC-50E2000-C-04
    BRIDGELUX(普瑞)
    模块
    LED COB VERO13 COOL WHITE ROUND
BXRC-50E2000-C-04 数据手册
Bridgelux Vero 13 Array Series Product Data Sheet DS31– Published April 16th 2013 BXRC-27x2000, BXRC-30x2000, BXRC-35E2000, BXRC-40E2000, BXRC-50C2000 Introduction VeroTM represents a revolutionary advancement in chip on board (COB) light source technology and innovation. These new LED light sources simplify luminaire design and manufacturing processes, improve light quality, and define a platform for future functionality integration. Vero is available in four different LES (light emitting surface) configurations and has been engineered to reliably operate over a broad current range, enabling new degrees of flexibility in luminaire design optimization. These new arrays deliver increased lumen density to enable improved beam control and precision lighting with 3 SDCM color control standard for clean and consistent uniform lighting. Vero includes an on board connector port to enable solder free electrical interconnect and simple easy to use mounting features to enable plug-and-play installation. Features Benefits  Vero 13 lumen output performance ranges from 400 to as much as 3,800 lumens  Broad application coverage for interior and exterior lighting  Broad range of CCT options from 2700K to 5000K   CRI options include; minimum 70, 80, 90 for standard and 97 typical for Decor products Flexibility to respond to application driven lighting design requirements  High quality true color reproduction  3SDCM standard for 2700K-4000K CCT options  Uniform consistent white light  Reliable operation at up to 2X nominal drive current  Flexibility in design optimization   Improved optical control Radial die pattern and improved lumen density   Enhanced ease of use and manufacturability Thermally isolated solder pads   Onboard connector port Solder-less connectivity enables plug & play installation and field upgradability  Top side part number markings  Improved inventory management and quality control 101 P ortol a A v enue, Li v erm ore, C A 94551 • T el : (925 ) 583 -840 0 • Fa x: (925 ) 583 -84 01 • w w w . bri dgel u x. c om Table of Contents Page Product Feature Map 3 Product Nomenclature 3 Top Side Part Number Markings 4 Enhanced Connectivity Options 4 Lumen Maintenance Characteristics 4 Environmental Compliance 4 UL Recognition 5 CE Recognition 5 Minor Product Change Policy 5 Cautionary Statements 5 Case Temperature Measurement Point 6 Product Selection Guide 7 Product Selection Guide (continued) 8 Typical Performance at Alternative Drive Currents 8 Flux Characteristics 10 Electrical Characteristics 11 Absolute Minimum and Maximum Ratings 12 Typical Forward Current Characteristics 13 Typical Relative Luminous Flux vs. Current, Tj=25°C 14 Typical Light Output Characteristics vs. Temperature 15 Typical Chromaticity Characteristics vs. Temperature 16 Optical Characteristics 17 Wavelength Characteristics at Rated Test Current, Tj=25°C 18 Mechanical Dimensions 19 Color Control Information 20 Design Resources 23 Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 2 of 24 Product Feature Map Vero 13 is the second smallest form factor in the exciting new Vero family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applicaitons, Vero incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please consult the Bridgelux Vero Array Series Product Brief for more information on the Vero family of products. Thermally isolated solder pads reduce manufacturing cycle time and complexity 2D Bar code provides full manufacturing traceability Polarity indication marks simplify manufacturing operator instructions Tc Measurement point Optics location / mounting features Radial die configuration improves lumen density and beam control Mounting holes Top side part number marking improves inventory management and outgoing quality control Solderless connector port enables simplified manufacturing processes, reduced inventory carrying costs and can enable field upgradability TM Optional Molex Pico-EZmate connector harness (sold separately) Product Nomenclature The part number designation for Bridgelux Vero LED arrays is explained as follows: BXRC – AB C DEFG – H – IJ Where: BXRC – Designates product family AB – Designates the nominal color temperature; 27 = 2700K; 30 = 3000K, etc. C – Designates minimum CRI; C = 70, E = 80, G = 90, H = 95 DEFG – Designates nominal flux; 1000 = 1000 lm, 2000 = 2000 lm, etc. H – Designates array configuration IJ – Designates CCT Bin options 03 = 3 SDCM 04 = 4 SDCM Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 3 of 24 Top Side Part Number Markings Vero includes a top side part number marking to help simplify inventory management and increase opportunities for production quality control. Any Vero product can be quickly identified to determine the product configuration, color or CRI by simply looking at its top side markings. Unlike previous product generations where markings were included only on the back side of the array, no longer is it necessary to handle (turnover), uninstall the array in an infield application or guess which product it is by the color of the phosphor area. The Vero line of LED array products also has a 2D bar code which provides additional information and full product traceability for quality control purposes. Enhanced Connectivity Options Vero’s thermally isolated solder pads have been designed to make soldering fast and secure. For those who prefer an even faster solderless installation, Vero has a connector port that can be used to further simplify your manufacturing process, reduce inventory cost and allow for field upgradability. The connector port mates to the Molex Pico-EZmate connector harness, sold separately by Molex and through their distribution network. The Molex connector harnesses come in a variety of wire lengths and wire gauge options and can also be custom engineered to meet your specific design requirements. Please consult your local Molex sales representative or visit www.molex.com for more information. Lumen Maintenance Characteristics Bridgelux projects that the Vero family of LED array products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at the rated forward test current. This performance assumes constant current operation at the nominal test current (1X drive current as is indicated in Table 4) with case temperature maintained at or below 85°C. For use beyond these typical operating conditions please consult your Bridgelux sales representative for further assistance. Bridgelux conducts lumen maintenance tests per LM80. Observation of design limits is required in order to achieve this projected lumen maintenance. Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid-state lighting market. Vero LED Arrays comply with the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux does not intentionally add the following restricted materials to any LED array products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 4 of 24 UL Recognition Bridgelux secures UL Recognition for all of its LED array products. Please refer to the UL file 357031 for the latest list of UL Recognized Bridgelux LED arrays. The Vero series of LED arrays are currently undergoing UL testing, and the UL file will be updated as tests are complete to satisfy UL recognition requirements. Bridgelux uses UL Recognized materials with suitable flammability ratings in the Vero LED array products to streamline the process for customers to secure UL listing of the final luminaire product. Bridgelux recommends that luminaires are designed with a Class 2 driver to facilitate the UL listing process. CE Recognition In accordance with the relevant European Union Directives, the BXRC series LED array products conform to the applicable requirements of the IEC/EN 62031:2008 (LED Modules for General Lighting Safety Specifications) and IEC 62471:2006 (Photobiological Safety of Lamps and Lamp Systems). The Vero series of LED arrays are currently undergoing UL and CE testing and are expected to be completed shortly. Bridgelux maintains a CE Declaration of Conformity statement on its website and displays the CE mark on product packing labels. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Cautionary Statements CAUTION: CONTACT WITH OPTICAL AREA Avoid any contact with the optical area. Do not touch the optical area of the Vero LED array or apply stress to the yellow phosphor resin area. Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the yellow phosphor resin area. Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux Vero LED arrays is in accordance with IEC specification EN62471:Photobiological Safety of Lamps and Lamp Systems. Vero LED arrays are classified as Risk Group 1 (Low Risk) when operated at or below the maximum DC forward current (2x the nominal rated test current as is defined in Table 6 of this data sheet). Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the Vero LED array or yellow resin area during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 5 of 24 CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. Case Temperature Measurement Point A case temperature measurement point location is included on the top surface of the Vero LED arrays. The location of this measurement point is indicated in the mechanical dimensions section of this data sheet. The purpose of this measurement point is to allow the user access to a measurement point correlates to the true case temperature on the back surface of the LED array. Once the LED array is installed, it is challenging to measure the back surface of the array, or true case temperature. For consistent and repeatable temperature measurements can be correlated to the data sheet performance specifications and to published LM-80 reliability data. The use of case temperature measurements point is more fully explained in AN30. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 6 of 24 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = 25°C, Tc = 25°C) Part Number Nominal CCT CRI (K) Color Control Test Current [1,2] (mA) Typical Pulsed Flux Tj = 25ºC Typical Vf Typical Power Typical Efficacy (V) (W) (lm/W ) (lm) BXRC-27E2000-C-03 2700 80 3 SDCM 500 1740 32.7 16.4 106 BXRC-27G2000-C-03 2700 90 3 SDCM 500 1390 32.7 16.4 85 BXRC-27H2000-C-03 2700 97 3 SDCM 500 1120 32.7 16.4 68 BXRC-30E2000-C-03 3000 80 3 SDCM 500 1800 32.7 16.4 110 BXRC-30G2000-C-03 3000 90 3 SDCM 500 1480 32.7 16.4 90 BXRC-30H2000-C-03 3000 97 3 SDCM 500 1210 32.7 16.4 74 BXRC-35E2000-C-03 3500 80 3 SDCM 500 1870 32.7 16.4 114 BXRC-40E2000-C-03 4000 80 3 SDCM 500 1900 32.7 16.4 116 BXRC-50C2000-C-04 5000 70 4 SDCM 500 2100 32.7 16.4 128 Notes for Table 1: 1. 2. 3. 4. 3SDCM (3-Step) Color control standard on 2700K, 3000K, 3500K and 4000K configurations. 4SDCM (4-Step) Color control standard on 5000K configurations. Bridgelux maintains a ± 7% tolerance on flux measurements. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 7 of 24 Product Selection Guide (continued) Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) Part Number Nominal CCT CRI (K) Test Current (mA) Typical DC Flux Tc = 85ºC Typical Vf Typical Power Typical Efficacy (V) (W) (lm/W ) (lm) [1,2] BXRC-27E2000-C-03 2700 80 500 1510 30.7 15.4 98 BXRC-27G2000-C-03 2700 90 500 1210 30.7 15.4 79 BXRC-27H2000-C-03 2700 97 500 970 30.7 15.4 63 BXRC-30E2000-C-03 3000 80 500 1570 30.7 15.4 102 BXRC-30G2000-C-03 3000 90 500 1290 30.7 15.4 84 BXRC-30H2000-C-03 3000 97 500 1050 30.7 15.4 68 BXRC-35E2000-C-03 3500 80 500 1650 30.7 15.4 107 BXRC-40E2000-C-03 4000 80 500 1670 30.7 15.4 109 BXRC-50C2000-C-04 5000 70 500 1830 30.7 15.4 119 Notes for Table 2: 1. 2. 3. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. Typical performance when driven under DC (direct current) at test current with LED array case temperature maintained at 85°C, mounted to heat sink with thermal interface material. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. Bridgelux maintains a ± 7% tolerance on flux measurements. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. Typical Performance at Alternative Drive Currents Vero LED arrays are tested to the specifications shown in Tables 4 and 5. Vero may also be driven at alternative drive currents dependent on specific application design requirements. Typical performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 1 and the flux vs. current characteristics shown in Figure 2. Typical performance at common drive currents is summarized in Table 3. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 8 of 24 Table 3: Typical Product Performance at Alternative Drive Currents Part Number CRI Current (mA) [1] BXRC-27E2000-C-03 80 BXRC-27G2000-C-03 90 BXRC-27H2000-C-03 97 BXRC-30E2000-C-03 80 BXRC-30G2000-C-03 90 BXRC-30H2000-C-03 97 BXRC-35E2000-C-03 80 BXRC-40E2000-C-03 80 BXRC-50C2000-C-04 70 165 350 500 700 1050 165 350 500 700 1050 165 350 500 700 1050 165 350 500 700 1050 165 350 500 700 1050 165 350 500 700 1050 165 350 500 700 1050 165 350 500 700 1050 165 350 500 700 1050 Typical Typical Vf Watt Tj = 25ºC Tj = 25ºC (V) (W) 30.2 31.3 32.7 33.9 36.1 30.2 31.3 32.7 33.9 36.1 30.2 31.3 32.7 33.9 36.1 30.2 31.3 32.7 33.9 36.1 30.2 31.3 32.7 33.9 36.1 30.2 31.3 32.7 33.9 36.1 30.2 31.3 32.7 33.9 36.1 30.2 31.3 32.7 33.9 36.1 30.2 31.3 32.7 33.9 36.1 5.0 11.0 16.4 23.7 37.9 5.0 11.0 16.4 23.7 37.9 5.0 11.0 16.4 23.7 37.9 5.0 11.0 16.4 23.7 37.9 5.0 11.0 16.4 23.7 37.9 5.0 11.0 16.4 23.7 37.9 5.0 11.0 16.4 23.7 37.9 5.0 11.0 16.4 23.7 37.9 5.0 11.0 16.4 23.7 37.9 Typical Flux Tj = 25ºC (lm) [2,3] 610 1220 1740 2260 3140 490 990 1390 1810 2510 400 800 1120 1470 2030 640 1290 1800 2355 3260 530 1060 1480 1940 2690 430 860 1210 1580 2180 660 1330 1870 2440 3370 680 1370 1900 2490 3450 740 1495 2100 2745 3810 Typical Typical DC Flux Efficacy Tc = 85ºC Tj = 25ºC (lm) [2,3] 540 1070 1510 1940 2610 440 870 1210 1560 2080 360 700 970 1260 1680 570 1140 1570 2030 2710 470 930 1290 1670 2230 380 760 1050 1360 1810 590 1180 1650 2120 2830 610 1220 1670 2170 2900 650 1320 1830 2330 3120 (lm/W) 122 111 106 95 83 98 90 85 76 66 80 73 68 62 54 128 118 110 99 86 106 97 90 82 71 86 78 74 67 58 132 121 114 103 89 136 125 116 105 91 148 136 128 116 101 Notes for Table 3: 1. 2. 3. Product is tested and binned at the rated (nominal) test current included in Table 4 and indicated in bold font and blue highlighted rows in the table above. Bridgelux maintains a ± 7% tolerance on flux measurements. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 9 of 24 Flux Characteristics Table 4: Flux Characteristics Part Number CRI (min) Test Current (mA) [1] Typical Pulsed Flux Tj = 25ºC (lm) [1] Minimum Pulsed Flux Tj = 25ºC (lm) [1,2,8] Typical Center Beam Candle Power Tj = 25ºC (cd) [4] Typical DC Flux Tc = 85ºC (lm) [5,6] Minimum DC Flux Tc = 85ºC (lm) (7) BXRC-27E2000-C-03 80 500 1740 1550 550 1510 1350 BXRC-27G2000-C-03 90 500 1390 1210 440 1210 1050 BXRC-27H2000-C-03 95 500 1120 1005 360 970 870 BXRC-30E2000-C-03 80 500 1800 1595 570 1570 1390 BXRC-30G2000-C-03 90 500 1480 1350 470 1290 1170 BXRC-30H2000-C-03 95 500 1210 1090 390 1050 950 3500 BXRC-35E2000-C-03 80 500 1870 1720 595 1650 1510 4000 BXRC-40E2000-C-03 80 500 1900 1730 600 1670 1520 5000 BXRC-50C2000-C-04 70 500 2100 1870 670 1830 1630 CCT (K) 2700 3000 [3] Notes for Table 4: 1. 2. 3. 4. 5. 6. 7. 8. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. Bridgelux maintains a ± 7% tolerance on flux measurements. Typical R9 value for 90 CRI product options is 70. Typical CRI for Decor products is 97 with a minimum R9 of 95. Center beam candle power is a calculated value based on Lambertian radiation pattern at nominal test current. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. Typical performance when driven under DC (direct current) at test current with LED array case temperature maintained at 85°C, mounted to heat sink with thermal interface material. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the environment in which the product is operated. Minimum DC Flux values are provided for reference only and are not a parameter guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. Refer to Table 3 for typical performance at other driver currents (including those commonly commercially available). Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 10 of 24 Electrical Characteristics Table 5: Electrical Characteristics and Driver Selection Voltages Forward Voltage [1,2,3] Pulsed, Tj = 25ºC Current (mA) [1] Min. Typ. Max. (V) (V) (V) (mV/°C) Typical Thermal Resistance Junction to Case RƟ j-c Typical Coefficient of Forward Voltage [5] ΔVf / ΔTj (C/W) Driver Selection [4] Voltages Vf Min. Hot Tc = 105ºC Vf Max. Cold Tc = - 40ºC (V) (V) 165 27.8 30.2 32.6 -24 0.80 25.9 34.1 350 28.8 31.3 33.8 -24 0.85 26.8 35.3 500 30.1 32.7 35.3 -24 0.88 27.8 36.5 700 31.2 33.9 36.6 -24 0.90 29.1 38.2 1050 33.2 36.1 39.0 -24 0.99 31.1 40.6 Notes for Table 5: 1. 2. 3. 4. 5. Parts are tested in pulsed conditions at the rated test current (indicated in bold font), Tj = 25°C. Pulse width is 10 ms. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. Forward voltage minimum and maximum values at the rated test current are guaranteed by 100% test. Values provided at alternative drive currents are provided for reference only and are not guaranteed by test. Vf Min hot and Vf max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. Typical Coefficient of Forward Voltage tolerance of ± 10% from nominal current. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 11 of 24 Absolute Minimum and Maximum Ratings Table 6: Maximum Current and Reverse Voltage Ratings Maximum Reverse Voltage (mA) Maximum Peak Pulsed Current 1050 1500 -55 1050 1500 -55 1050 1500 -55 1050 1500 -55 1050 1500 -55 1050 1500 -55 1050 1500 -55 1050 1500 -55 1050 1500 -55 Maximum DC Forward Current Part Number BXRC-27E2000-C-03 BXRC-27G2000-C-03 BXRC-27H2000-C-03 BXRC-30E2000-C-03 BXRC-30G2000-C-03 BXRC-30H2000-C-03 BXRC-35E2000-C-03 BXRC-40E2000-C-03 BXRC-50C2000-C-04 (mA) [1] (Vr) [2] Notes for Table 6: 1. 2. 3. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where the LED array can be driven without catastrophic failures. Light emitting diodes are not designed to be driven in reverse voltage. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these products. Vero LED arrays can be driven at higher currents but lumen maintenance may be reduced, however, the luminaire design may need to design in lower Tc values to meet lumen maintenance capabilities equal to lower drive current operations. Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 150°C Storage Temperature -40°C to +105°C Operating Case Temperature 105°C Soldering Temperature [1] 350°C for a maximum of 10 seconds Notes for Table 7: 1. See Bridgelux Application Note AN31, Assembly Considerations for Vero LED arrays, for more information. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 12 of 24 Typical Forward Current Characteristics Figure 1: Electrical Characteristics Max Vf Tc = - 40°C Max Vf Tj = 25°C Typ Vf Tj = 25°C MIN Vf Tj = 25°C MIN Vf Tc = 85°C Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 13 of 24 Typical Relative Luminous Flux vs. Current, Tj=25°C Figure 2: Typical Flux vs. Current, T j = 25°C 200% 180% 160% Relative Intensity 140% 120% 100% 80% 60% 40% 20% 0% 0 200 400 600 800 1000 Current (mA) Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 14 of 24 1200 Typical Light Output Characteristics vs. Temperature Figure 3: Typical Flux vs. Junction Temperature Warm White 110% Nuetral White Cool White Normalized Luminous Flux 100% Neutral White 90% Warm White 80% Cool White 70% -10 0 10 20 30 40 50 60 70 80 90 100 110 Junction Temperature, °C Notes for Figure 3: 1. 2. 3. Characteristics shown for warm white reflect 3000K 80 CRI. Characteristics shown for neutral white reflect 4000K 80 CRI. Characteristics shown for cool white reflect 5000K 70 CRI. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 15 of 24 120 130 Typical Chromaticity Characteristics vs. Temperature Figure 4: Typical ccx Shift vs. Junction Temperature 0.02 Warm White Cool White 0.01 Δy Neutral White Neutral White 0.00 Cool White Warm White -0.01 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, °C 90 100 110 120 130 Figure 5: Typical ccy Shift vs. Junction Temperature Warm White 0.02 Cool White Neutral White Δy 0.01 Neutral White 0.00 Warm White Cool White -0.01 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, °C 90 100 110 120 130 Notes for Figures 4 and 5: 1. 2. 3. Characteristics shown for warm white reflect 3000K 80 CRI. Characteristics shown for neutral white reflect 4000K 80 CRI. Characteristics shown for cool white reflect 5000K 70 CRI. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 16 of 24 Optical Characteristics Figure 6: Typical Spatial Radiation Pattern Notes for Figure 6: 1. 2. The typical viewing angle for the Vero 13 LED arrays is 120°. The viewing angle is defined as the off axis angle form the centerline where Iv is ½ of the peak value. Figure 7: Typical Polar Radiation Pattern Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 17 of 24 Wavelength Characteristics at Rated Test Current, Tj=25°C Figure 8: Typical Color Spectrum Notes for Figure 8: 1. 2. 3. Color spectrum shown for warm white is 3000K 80 CRI. Color spectrum shown for neutral white is 4000K 80 CRI. Color spectrum shown for cool white is 5000K 70 CRI. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 18 of 24 Mechanical Dimensions Figure 9: Drawing for Vero 13 LED Array TOP VIEW SIDE VIEW Notes for Figure 9: 1. 2. 3. Mounting holes (2X) are for M2.5 screws. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 4. Solder pads and connector port are labeled “+” and “-“ to denote positive and negative, respectively. 5. It is not necessary to provide electrical connections to both the solder pads and the connector port. Either set may be used depending on application specific design requirements. 6. Drawings are not to scale. 7. Drawing dimensions are in millimeters. 8. Unless otherwise specified, tolerances are ± 0.10mm. 9. Refer to Application Notes AN30 and AN31 for product handling, mounting and heat sink recommendations. 10. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.45mm. 11. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 12. Bridgelux Vero 13 LED arrays are packaged in trays of 20 units with a maximum planar dimension of 215.mm x 279.4 mm (8.5 x 11 inches) per tray. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 19 of 24 Color Control Information Figure 10: Graph of Warm White Test Bins in xy Color Space (Pulsed Test Conditions, Tj = 25°C) Table 10: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code X Y 03 (3SDCM) 0.415 0.405 0.401 0.410 0.400 0.395 0.384 0.388 Center point 0.407 0.392 CCT (K) Bin Code X Y 3500 03 (3SDCM) 0.441 0.433 0.427 0.435 0.411 0.408 0.396 0.398 Center point 0.434 0.403 Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) CCT (K) Bin Code X Y CCT (K) 3000 03 (3SDCM) 0.467 0.456 0.450 0.460 0.418 0.415 0.403 0.405 2700 Center point 0.458 0.410 Page 20 of 24 Color Binning Information (continued) Figure 11: Graph of Neutral White Test Bins in xy Color Space (Pulsed Test Conditions, Tj = 25°C) Table 11: Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code X Y CCT (K) 03 3SDCM 0.388 0.379 0.377 0.385 0.388 0.382 0.372 0.377 4000 Center point 0.382 0.380 Notes for Figures 10 and 11: 1. 2. 3. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. Typical performance when driven at DC (direct current) test current with LED array case temperature maintained at 85°C, mounted to heat sink with thermal interface material. Please contact a Bridgelux sales representative for additional details. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 21 of 24 Color Binning Information (continued) Figure 12: Graph of Cool White Test Bins in xy Color Space (Pulsed Test Conditions, Tj = 25°C) Table12: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code X Y CCT (K) 04 4SDCM 0.350 0.341 0.341 0.348 0.366 0.359 0.346 0.352 5000 Center point 0.345 Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) 0.355 Page 22 of 24 Design Resources Bridgelux is developing a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. Included below is a list of resources under development which will be downloaded from the Bridgelux web site under the Design Resources section. Application Notes      AN30: AN31: AN32: AN34: AN36: Effective Thermal Management of BridgeluxVero LED Arrays Assembly Considerations for BridgeluxVeroLED Arrays Electrical Drive Considerations for Bridgelux Vero LED Arrays Reliability Data Sheet for Bridgelux Vero LED Arrays Optical Considerations for Bridgelux Vero LED Arrays Optical Source Models Optical source models and ray set files are available for all BridgeluxVero LED array products. The list below contains the formats currently available. If you require a specific format not included in this list, please contact your Bridgelux sales representative for assistance.          Zemax ASAP IESNA LightTools LucidShape OPTIS SPEOS PHOTOPIA TracePro Radiant Imaging Source Model 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both SAT and STEP formats. Please contact your Bridgelux sales representative for assistance. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 23 of 24 About Bridgelux Bridgelux is a leading developer and manufacturer of technologies and solutions transforming the $40 billion global lighting industry into a $100 billion market opportunity. Based in Livermore, California, Bridgelux is a pioneer in solid-state lighting (SSL), expanding the market for light-emitting diode (LED) technologies by driving down the cost of LED lighting systems. Bridgelux’s patented light source technology replaces traditional technologies (such as incandescent, halogen, fluorescent and high intensity discharge lighting) with integrated, solid-state lighting solutions that enable lamp and luminaire manufacturers to provide high performance and energy-efficient white light for the rapidly growing interior and exterior lighting markets, including street lights, commercial lighting and consumer applications. With more than 550 patent applications filed or granted worldwide, Bridgelux is the only vertically integrated LED manufacturer and developer of solid-state light sources that designs its solutions specifically for the lighting industry. For more information about the company, please visit www.bridgelux.com © 2013 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux Vero 13 Array Series Product Data Sheet DS31 (04/16/13) Page 24 of 24
BXRC-50E2000-C-04 价格&库存
很抱歉,暂时无法提供与“BXRC-50E2000-C-04”相匹配的价格&库存,您可以联系我们找货
