COM-11120
COM-11120
    SPARKFUNELECTRONICS
    插件
    COM-11120
COM-11120 数据手册
深 圳 市 煜 森科 技 有 限 公 司 CHINA YUN SUN LED TECHNOLOGY CO., LTD. TEL: (86) 755-28079401 28079402 FAX: (86) 755-28079407 28079403 28079404 E-mail: info@100LED.com 28079405 Web: www.100LED.com Model No.: YSL-R1047CR4G3BW-F8 RED/GREEN/BLUE Tricolor LED Applications: .Moving Message Display .Banking Board .Digital Display .Full Color Display .Score Boards LED Chip Absolute Maximum Ratings: (Ta=25 ℃) Pararmeter Green Symbol Red IF 20 20 20 mA Peak forward current(Duty Cycle=10,10KHz) IPF 30 30 30 mA Reverse current IR 10 10 10 µA 25~ 85 ℃ -30~85 -30~85 ℃ 520 467.5 nm Forward current 1 (VR=5V) Operating temp TOPR - Storage temp TSTG -30~85 λ PH 625 Peak Emission Wavelength 25~ 85 - Blue 25~ 85 - Unit * Soldering Bath: not more than 5 seconds @260 ℃.The bottom ends of the plastic reflector should be at least 2mm above the solder surface Soldering Iron: not more than 3 seconds @300 ℃ under 30W LED Chip Typical Electircal & Optical Characteristics: (Ta=25 ℃) ITEMS Min. Typ. Max. 1.8 2.0 2.2 3.0 3.2 3.4 Blue 2.9 3.1 3.3 Red 500 550 600 200 250 3000 Blue 650 700 750 Red 620 623 625 515 517.5 520 465 466 467.5 Color Symbol Condition Red Forward Voltage Luminous Intensity Wavelenength Green Green Green Blue Light Degradation after 1000 hours Red VF IV ∆λ IF=20mA IF=20mA IF=20mA Unit V mcd nm -4.68% ~ -8.27% Green -11.37% ~ -15.30% Blue -8.23% ~ -16.81% Address: 5/F, Building B, Anzhilong Indl., Qinghua East Road., Longhua Town, Shenzhen CHINA. 518109 ONE HUNDRED LED PERFECT LED 深 圳 市 煜 森科 技 有 限 公 司 CHINA YUN SUN LED TECHNOLOGY CO., LTD. TEL: (86) 755-28079401 FAX: (86) 755-28079407 28079402 28079403 28079404 E-mail: info@100LED.com 28079405 Web: www.100LED.com Light Degradation in mcd: (I F=20mA) Light Degradation in mcd after Different Hours Hours 216 Hrs 360 Hrs Red 1.52% -1.22% -3.10% Green -8.02% -9.78% Blue 3.13% -0.33% Colors 792 Hrs 1104 Hrs 1992 Hrs 2328 Hrs -4.68% -5.72% -8.27% -10.25% -11.37% -13.79% -15.30% -3.84% -8.23% -14.32% -16.81% Mechanical Dimensions: .All dimension are in mm, tolerance is ±0.2mm unless otherwise noted .An epoxy meniscus may extend about 1.5mm down the leads. .Burr around bottom of epoxy may be 0.5mm Maximum Unit: mm Address: 5/F, Building B, Anzhilong Indl., Qinghua East Road., Longhua Town, Shenzhen CHINA. 518109 ONE HUNDRED LED PERFECT LED
COM-11120 价格&库存
很抱歉,暂时无法提供与“COM-11120”相匹配的价格&库存,您可以联系我们找货
