VAOL-5LCE2
VAOL-5LCE2
    VCC
    插件
    发光二极管/LED 插件
VAOL-5LCE2 数据手册
LED LAMP VAOL-5LCE2 Feature § § Package Dimension Low Power Consumption I.C. compatible Applications § § § § Commercial Outdoor Sign Board Front Panel Indicator Dot-Matrix Module LED Bulb Description § § § These LEDs are Based on GaAsP/GaP Material Technology Emitted color:Yellow Yellow Diffusion Lens *Tolerance:± 0.01 0.25 Unit:± inch mm Absolute Maximum Ratings at Ta=25℃ Symbol Parameter Max. Unit 100 mW PD Power Dissipation VR Reverse Voltage 5 V IAF Average Forward Current 30 mA IPF Peak Forward Current(Duty=0.1,1kHz) 100 mA ― Derating Linear Form 25℃ 0.4 mA∕℃ Topr Operating Temperature Range –20 to + 80 ℃ Tstg Storage Temperature Range –20 to + 100 ℃ Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260℃ For 5 Seconds. Electrical / Optical Characteristics and Curves at Ta=25℃ Symbol Parameter VF Forward Voltage IF= 20 mA IR Reverse Current VR= 5 △θ Half Intensity Angle IF= 20 mA 60 Deg. IV Luminous Intensity IF= 20 mA 80 mcd. λd Dominant Wavelength IF= 20 mA 590 nm engineered to light up your design Test Condition Min. Typ. 2.0 V www.vcclite.com Max. Unit 2.4 V 100 μA 1.800.522.5546 02/15 Rev 1 Electrical Characteristics at Ta=25℃ Symbol Iv VF λD Parameter Luminous Intensity Forward Voltage Dominant Wavelength Condition IF=20mA IF=20mA IF=20mA Unit mcd V nm Binning Grade Range Grade Range Grade Range -- -80 C 1.9~2.0 Y4 589~591 -- -- D 2.0~2.1 Y5 591~593 -- -- E 2.1~2.2 Y6 593~595 F 2.2~2.3 G 2.3~2.4 Intensity: Tolerance of minimum and maximum = ± 15% Vf: Tolerance of minimum and maximum = ± 0.025v NOTE: 1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery must be properly grounded. 2. Specific binning requirements –please contact our home office Radiation Diagram IF=20 mA 50% Power Angle engineered to light up your design Angle Y=60° www.vcclite.com 1.800.522.5546 02/15 Rev 1 YELLOW Typical Electro-optical Characteristic Curves (25°C Free Air Temperature Unless Otherwise Specified) λ engineered to light up your design www.vcclite.com 1.800.522.5546 02/15 Rev 1
VAOL-5LCE2 价格&库存
很抱歉,暂时无法提供与“VAOL-5LCE2”相匹配的价格&库存,您可以联系我们找货
