VAOL-10GDE4
VAOL-10GDE4
    VCC
    径向
    LED GREEN CLEAR 10MM ROUND T/H
VAOL-10GDE4 数据手册
LED LAMP VAOL-10GDE4 Feature § § § Package Dimension Low Power Consumption High Intensity I.C. compatible Applications § § § § Commercial Outdoor Sign Board Front Panel Indicator Dot-Matrix Module LED Bulb Description § § § These High Intensity LEDs are Based on GaP/GaP Material Technology Emitted color:Green Water Clean Lens *Tolerance:± 0.01 0.25 inch mm Un Absolute Maximum Ratings at Ta=25℃ Symbol Parameter Max. Unit 100 mW PD Power Dissipation VR Reverse Voltage 5 V IAF Average Forward Current 25 mA IPF Peak Forward Current(Duty=0.1,1kHz) 85 mA ― Derating Linear Form 25℃ 0.4 mA∕℃ Topr Operating Temperature Range –40 to + 80 ℃ Tstg Storage Temperature Range –40 to + 100 ℃ Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260℃ For 5 Seconds. Electrical / Optical Characteristics and Curves at Ta=25℃ Symbol Parameter VF Forward Voltage IR Reverse Current △θ IV λd Half Intensity Angle Luminous Intensity Dominant Wavelength Test Condition IF= 20 mA Min. Typ. Max. Unit 2.0 2.4 V 100 μA VR= 5 V IF= 20 mA 30 Deg. IF= 20 mA 350 mcd. IF= 20 mA 570 nm Electrical Characteristics at Ta=25℃ Symbol Iv VF λD Parameter Luminous Intensity Forward Voltage Dominant Wavelength Condition IF=20mA IF=20mA IF=20mA Unit mcd V nm Grade Range Grade Range Grade Range BIN 13 345~485 B 1.8~1.9 G8 567~569 C 1.9~2.0 G9 569~571 D 2.0~2.1 G10 571~573 E 2.1~2.2 F 2.2~2.3 G 2.3~2.4 Binning Intensity: Tolerance of minimum and maximum = ± 15% Vf: Tolerance of minimum and maximum = ± 0.05v NOTE: 1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery must be properly grounded. 2. Specific binning requirements –please contact our home office Radiation Diagram IF=20 mA 50% Power Angle Angle =30∘ GREEN Typical Electro-optical Characteristic Curves (25°C Free Air Temperature Unless Otherwise Specified) λ
VAOL-10GDE4 价格&库存
很抱歉,暂时无法提供与“VAOL-10GDE4”相匹配的价格&库存,您可以联系我们找货
