5SRD
5SRD
    BIVAR
    插件
    发光二极管/LED 红色 插件 40mcd
5SRD 数据手册
5mm 3mm (T1 Package Package Discrete Discrete LED LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER AMBER, RED, Super Bright Bright RED, Super Super Bright B 5SRX-X ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 5mm (T1 ¾) Package RoHS Compliant Water Clear (C), Diffused (D), and Tinted (T) Lenses Available in Flange (F) and Standard (Blank) Lead Frame styles Up to 60 mcd Luminous Intensity at 20 mA Ideal for Status Indication and Display Bivar 5mm T1 ¾ Package Super Bright LED is ideal for those applications where higher ambient lighting exists such as sign boards, security system displays, and medical applications. Bivar offers water clear LED lens for maximum light output, diffused LED lens for uniform light output, and tinted lens to identify the color of the LED. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies and the Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends. Part Number Viewing Angle 5SRC-F Water Clear 35° 5SRD-F Red Diffused 40° Red Tinted 35° Water Clear 35° 5SRD Red Diffused 45° 5SRT Red Tinted 35° 5SRC Emitted Color Peak. Wavelength λp(nm) TYP. Lens Appearance 5SRT-F Material GaAlAs/GaAs RED 645nm Part Number Designation 5 S X X -X LED Body, mm Super Bright Emitted Color Lead Frame & Body Style i.e. -F, Blank for Standard Lens Appearance ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 1 of 5 5mm 3mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER AMBER, GREEN, Super Bright RED, Super Bright Outline Dimensions Flanged “5SXX-F” LED Standard “5SXX” LED Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 2 of 5 5mm 3mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER AMBER, GREEN, Super Bright RED, Super Bright Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 70 mW Forward Current ( DC ) Peak Forward Current 30 mA 1 150 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX Reverse Dominant Current Wavelength (nm)2 (μA) MAX Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 60 / 35 / / / / 40 / 40 5SRT-F / / / / 60 / 35 5SRC / / / / 60 / 35 / / / / 40 / 45 / / / / 60 / 35 5SRC-F 5SRD-F 5SRD / / 1.7 1.7 2.4 2.4 / / 20 20 5SRT Notes: 1. Tolerance of forward voltage : ±0.05V. / / 100 100 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 3 of 5 5mm 3mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER AMBER, GREEN, Super Bright RED, Super Bright Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° 10° 20° 30° Iv 1.0 40° 35° 50° 40° 45° 0.5 60° 70° 80° λ(nm) 0.0 700 600 650 750 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA If (mA) 90° 0.5 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Iv 1000 4.0 100 3.0 10 2.0 1 1.0 0.1 Vf (V) 1.0 0.3 2.0 3.0 4.0 If (mA) 0.0 1 5.0 Fig. 3 Forward Current vs. Forward Voltage 10 100 1000 Fig. 4 Relative Luminous Intensity vs. Forward Current Normalize @ 20 mA Iv Vf (V) 3.0 1.2 1.1 2.0 1.0 1.0 0.9 0.8 -40 T (°C) 0 40 80 Fig. 5 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 6 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 4 of 5 5mm 3mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER AMBER, GREEN, Super Bright RED, Super Bright Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 03/08 Page Page 4 5 of of 4 5
很抱歉,暂时无法提供与“5SRD”相匹配的价格&库存,您可以联系我们找货
5SRD
    • 1+2.45965
    • 10+1.75455
    • 100+1.09864
    • 129+0.88547
    • 354+0.83628
    • 1000+0.80348
    库存:80
    5SRD
      库存:700
      5SRD
      • 1+3.087961+0.39638
      • 10+2.1113510+0.27102
      • 100+1.49334100+0.19169
      • 500+1.21390500+0.15582
      • 1000+1.121741000+0.14399
      • 2000+1.043242000+0.13392
      • 5000+0.957165000+0.12287
      • 10000+0.9033610000+0.11596
      • 25000+0.8446225000+0.10842
      库存:26
