Page 1 of 2
LEDS / BARE LEDS
Diffused 'Piranha' Super-flux RGB (tri-color)
LED (10 pack)
PRODUCT ID: 1451
Page 2 of 2
DESCRIPTION
Dffused 5mm tri-color LEDs with separate red, green and blue LED chips inside!
Ultra bright indicator or illuminator, and fun to color-swirl. 90 degree viewing
angle. You can plug these into a breadboard diagonally.
These are Common-Anode type which means you connect one pin to 5V or so and
then tie the other three legs to ground through a resistor. We carry and use CA
more than CC because multi-LED driver chips (such as the TLC5940/TLC5941) are
often designed exclusively for CA and can't be used with Common-Cathode.
Each order comes with 10 LEDs.
• 0.3"/7.6mm on each side, square. Sometimes called 'Super flux' or 'Piranha'
• Diffused lens, 90 degree viewing angle
• Red: 620 nm wavelength, Green: 517 nm, Blue: 460 nm
• Red: 1.8-2.2V Forward Voltage, at 20mA current, Green: 3.0-3.3V, Blue:
3.0-3.3V
• Red: 800 mcd typical brightness, Green: 1500 mcd, Blue: 700 mcd (3000 mcd
total)
• FD-115TRGB-A2 Datasheet
If you need some help using LEDs, please read our "Introduction to using LEDs"
tutorial for any electronics project.
http://www.adafruit.com/products/1451
7/16/2015
很抱歉,暂时无法提供与“1451”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+72.916101+9.45420
- 国内价格 香港价格
- 1+87.386781+11.32015
