TRAB24/49003P
TRAB24/49003P
    LAIRD(莱尔德)
    OMNIPH2.4+4.9GHZBK3DBI60W
TRAB24/49003P 数据手册
Phantom® Antennas TRA(B)24/49003(P) Dual-Band Phantom® antenna is ideal for Wlan and 4.9 Ghz public safety applications Laird Technologies’ unique patented Phantom® dual-band antenna operates simultaneously at 2.4 GHz and 4.9 GHz and is a tough antenna for outdoor or indoor applications. The revolutionary design measures only 2.3” and features both vertical and horizontal polarization. This gives the antenna diversity, frequency agility, low visibility, wide bandwidth and a low angle radiation pattern that is superior to traditional gain antennas in most applications. The industry standard NMO mounting socket mates with all Laird Technologies’ magnetic, trunk lid, and hole mounts. A threaded permanent stud mount model is also available for vandal resistant mounting on brackets, panels, ceilings or any other kind of housing. Features Markets • Cross-polarization design ensures uninterrupted transmissions in urban canyons and rural drop-off areas • Public safety • Phantom® outperforms a 3dB whip in many applications • U.S. Patent Nos. 5,977,931 – 6,292,156 and 7,209,096 Americas: +1.847 839.6907 IAS-AmericasEastSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: +86.21.5855.0827.127 IAS-AsiaSales@lairdtech.com www.lairdtech.com • Transportation • Utility • Military mobile • Fixed radio applications Phantom® Antennas TRA(B)24/49003(P) SPECIFICATIONS MODEL AND ORDERING INFORMATION MODEL ELECTRICAL DESCRIPTION ISM, 2.4-2.5 GHz / 4.9-5.85 GHz TRA24/49003 NMO Mount, White Radome 2400 MHz 4900 MHz TRAB24/49003 NMO Mount, Black Radome TRA24/49003P P-Mount, White Radome Peak Gain (dBi) Azimuth Cut, Phi=0° 0.7 0.9 TRAB24/49003P P-Mount, Black Radome Peak Gain (dBi) Elevation Cut, Phi=90° 0.6 5.7 Elevation Beamwidth at Half-Power 30° 65° Azimuth Beamwidth at Half-Power 130° 230° Frequency Band Frequency Range (Test Frequency at Peak) Max Gain: 0.7 dBi Average Gain: -3.9 dBi Max Angle: 325.0° Mechanical Antenna Dimensions Weight (Mass) 1.44”(36.5 mm)dia x 2.3”(58.4 mm)H 0.25 lb (113.4 g) TECHNICAL DATA Pattern Omni-Directional Maximum Power 100W Nominal Impedance 50 ohm Polarization VSWR Termination F/B Ratio Vertical and Horizontal
TRAB24/49003P 价格&库存
很抱歉,暂时无法提供与“TRAB24/49003P”相匹配的价格&库存,您可以联系我们找货
