SMP2-SGC
SMP2-SGC
    BIVAR
    PLCC-2
    发光二极管/LED PLCC-2
SMP2-SGC 数据手册
PLCC2 SMD Top View Package LED SMP2-SGC, SUPER GREEN SMP2-SGC      Industry Standard PLCC2 Footprint Low Profile Package High Luminous Intensity Wide Viewing Angle High Power Efficiency Bivar SMP2 LED is offered in an industry standard PLCC2 package with high luminous intensity and wide viewing angles. The miniature package is ideal for small scale applications such as illumination, general indication, and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment. The robust package is ideal for harsh working environments and can be used in clusters for high luminous applications. Wide variety of color and intensity combinations are available to meet any illumination needs. Bivar SMP2 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Lumen Typ. mcd Lens Color Viewing Angle SMP2-SGC AlGaInP Super Green 115 Water Clear 120° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 1 of 5 PLCC2 SMD Top View Package LED SMP2-SGC, SUPER GREEN Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 72 mW Continuous Forward Current 30 mA Peak Forward Current 1 100 mA Reverse Voltage 5V Derating Linear From 25°C 0.4 mA/°C Operating Temperature Range -40 ~ +85°C Storage Temperature Range -40 ~ +100°C Lead Soldering Temperature ( 1.6 mm from body ) 2 260°C Electrostatic Discharge (HBM) 2000 V Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Emitting Color Super Green Forward Voltage (V)1 Recommend Forward Current (mA) Reverse Current (µA) VR=5V Dominant Wavelength (nm)2 Luminous Intensity (mcd)3 Viewing Angle 2 Ө ½ (deg) TYP MAX TYP MAX MIN TYP MAX MIN TYP TYP 1.9 2.4 20 100 568 574 578 57 115 120 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Dominant Wavelength : ±0.1nm. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Radiation Diagram Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 2 of 5 PLCC2 SMD Top View Package LED SMP2-SGC, SUPER GREEN Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 3 of 5 PLCC2 SMD Top View Package LED SMP2-SGC, SUPER GREEN Recommended Soldering Conditions Tape and Reel Dimensions Note: 2000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 4 of 5 PLCC2 SMD Top View Package LED SMP2-SGC, SUPER GREEN 0.35 [9.0mm] 0.47 [12.0mm] Packaging and Labeling Plan Note: 1 Reel / Bag Vacuum and Heat Sealed Clear AntiStatic Poly Bag Internal Quality Control Label X.XXX Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 02/15 Page 5 of 5
SMP2-SGC 价格&库存
很抱歉,暂时无法提供与“SMP2-SGC”相匹配的价格&库存,您可以联系我们找货
