BXRA-35H2000-B-03
BXRA-35H2000-B-03
    BRIDGELUX(普瑞)
    LED Lighting COBs, Engines, Modules Chip On Board (COB) ES White, Warm Rectangle
BXRA-35H2000-B-03 数据手册
Bridgelux Décor Ultra High CRI Array Series Product Data Sheet DS28 BXRA-xxH0740-A, BXRA-xxH2000-B, BXRA-xxH4000-H, BXRA-xxH7000-J Introduction Bridgelux Décor Ultra High CRI LED Array products deliver high performance, compact, and cost-effective solid state lighting solutions to serve the specialized designer lighting market. These products combine the higher efficacy, lifetime, and reliability benefits of LEDs with the high quality of light and color rendering demanded for high end hospitality, retail and architectural projects. Bridgelux Décor product options deliver outstanding light quality with a very high Color Rendering Index (CRI), enabling lighting designers to realistically render a full palette of colors over a wide range of light levels to create stunning and sophisticated lighting effects for retail, hospitality, and architectural lighting applications. Features Benefits  High CRI with R9 value greater than 95  Enhanced color rendering  Compact high flux density light source  Enhanced optical control  Uniform high quality illumination  Clean white light without pixilation  Streamlined thermal path   Energy Star / ANSI compliant binning structure Significantly reduced thermal resistance and increased operating temperatures   Uniform and consistent white light Standard 3SDCM color control   Lower operating costs More energy efficient than incandescent, halogen and fluorescent lamps  UL recognized  Low voltage DC operation  Easy to use with daylight and motion detectors enabling increased energy savings  Instant light with unlimited dimming  Reduced maintenance costs  5-year warranty  Environmentally friendly, no disposal issues  RoHS compliant and Pb free 101 P ortol a A v enue , Li v erm ore , C A 94551 • T el : (925 ) 583 -84 0 0 • Fa x: (92 5) 58 3 -8 401 • ww w. b ri dgel u x. c om Table of Contents Page Typical Product Features 3 Product Nomenclature 3 Lumen Maintenance Characteristics 4 Environmental Compliance 4 UL Recognition 4 CE Recognition 4 Minor Product Change Policy 4 Case Temperature Measurement Point 4 Cautionary Statements 5 Product Selection Guide 6 Typical Performance at Alternative Drive Currents 7 Flux Characteristics 9 Electrical Characteristics 10 Absolute Minimum and Maximum Ratings 11 Forward Current vs. Voltage Characteristics 12 Normalized Luminous Flux vs. Current (Tj = 25°C) Characteristics 14 Normalized Luminous Flux vs. Junction Temperature 16 Typical Chromaticity vs. Temperature Characteristics 17 Typical Radiation Pattern 18 Wavelength and CRI Characteristics at Rated Test Current (Tj = 25°C) 19 Mechanical Dimensions 20 Color Binning Information 22 Design Resources 23 Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 2 of 24 Typical Product Features Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The arrays incorporate several features to simplify design integration and assembly. Figure 1: Array Features (RS array used as example) Fully engineered substrate for consistent thermal, mechanical and optical properties Manufacturer: genuine Bridgelux Solder pad White ring around LES Yellow phosphor light emitting surface (LES) Index features assist accurate orientation during assembly Solder pad Mounting holes Polarity indication simplifies assembly instructions Case temperature measurement point (Tcase) Note: Part number and lot codes are scribed on back of array Form Factors  Décor available on ES Star, ES Rectangle and RS form factors  RS array used to show typical features above ES Star array ES Rectangle array Product Nomenclature The part number designation for Bridgelux LED Arrays is as follows: BXRA – AB C DEFG – H – IJ Where: BXRA – Designates product family AB – Designates the nominal ANSI color temperature; 27 = 2700K; 30 = 3000K, etc. C- Designates CRI range, H = 97 typical DEFG - Designates nominal flux at 80 CRI; 2000 = 2000lm, 4000 = 4000lm, etc. H– Designates array configuration IJ– Designates CCT bin 03 = 3 SDCM Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 3 of 24 Lumen Maintenance Characteristics Bridgelux projects that its family of LED Array products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at the rated forward test current. This performance assumes constant current operation at the nominal drive current with case temperature maintained at or below 85°C. For use beyond these typical operating conditions please consult your Bridgelux sales representative for further assistance. These projections are based on a combination of package test data, semiconductor chip reliability data, a fundamental understanding of package related degradation mechanisms, and performance observed from products installed in the field using Bridgelux die technology. Bridgelux conducts lumen maintenance tests per LM80. Observation of design limits is required in order to achieve this projected lumen maintenance. Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid state lighting market. Bridgelux LED Arrays comply with the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux does not intentionally add the following restricted materials to LED Array products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). UL Recognition Bridgelux secures UL recognition for all the LED Array products. Please refer to the UL file E350613 for the latest list of UL recognized Arrays. Bridgelux uses UL recognized materials with suitable flammability ratings in the LED Array to streamline the process for customers to secure UL listing of the final luminaire product. Bridgelux recommends that luminaires are designed with a Class 2 driver to facilitate the UL listing process. CE Recognition In accordance with the relevant European Union directives, the family of LED Array products conform to the applicable requirements of the IEC/EN 62031:2008 (LED Modules for General Lighting Safety Specifications) and IEC 62471:2006 (Photobiological Safety of Lamps and Lamp Systems). Bridgelux maintains a CE Declaration of Conformity statement on its website and displays the CE mark on product packing labels. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Case Temperature Measurement Point A case temperature (Tc) measurement point location is included on the top surface of the Bridgelux LED Arrays. The location of this measurement point is indicated in the mechanical dimensions section of this data sheet. The purpose of this measurement point is to allow the user access to a measurement point closely linked to the true case temperature on the back surface of the LED Array. Once the LED Array is installed, it is challenging to measure the back surface of the array, or true case temperature. Bridgelux has provided the case temperature measurement location in a manner which closely ties it to the true case temperature of the LED Array under steady state operation. Deviations between thermal measurements taken at the point indicated and the back of the LED Array differ by less than 1°C, providing a robust method to testing thermal operation once the product is installed. Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 4 of 24 Cautionary Statements CAUTION: CONTACT WITH OPTICAL AREA Avoid any contact with the optical area. Do not touch the optical area of the LED Array or apply mechanical stress to the yellow phosphor resin area – it could damage the LED Array. Optics and reflectors must not be mounted in contact with the yellow phosphor resin area (LES) or the white ring that surrounds the yellow phosphor area. Using the white ring to secure optics can result in damage to the LED Array as the ring is not designed to act as a mechanical locating feature. Optical devices may be mounted on the top surface of the LED Array substrate outside of the white ring maximum OD as specified in the product data sheet. Use the mechanical features of the LED Array substrate edges and/or mounting holes to locate and secure the optical device as needed. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux LED Arrays is in accordance with IEC specification EN62471; Photobiological Safety of Lamps and Lamp Systems. Bridgelux LED Arrays are classified as Risk Group 1 (Low Risk) when operated at or below their rated test current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the LED Array or resin area during operation. Allow the LED Array to cool for a sufficient period of time before handling. The LED Array may reach elevated temperatures such that it can burn skin when touched. CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED Array. Please consult Application Note AN11 for additional information. Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 5 of 24 Product Selection Guide Bridgelux LED Arrays are tested to the specifications shown in Tables 1, 3 and 4. Typical performance at alternate drive currents are shown in Table 2. Typical performance at any drive current can be derived from the current versus voltage characteristics shown in Figures 2, 3, 4, 5 and from the flux versus current characteristics shown in Figures 6, 7, 8, and 9. The following configurations are available: Table 1: Available Products Typical Flux Tj = 25ºC [1,2] (lm) Typical Flux Tcase = 85ºC [3] (lm) Vf (V) 350 570 510 700 1585 97 2100 3140 2700 97 2800 BXRA-30H0740-A-03 3000 97 Part Number CCT (Kelvin) BXRA-27H0740-A-03 2700 97 BXRA-27H2000-B-03 2700 97 BXRA-27H4000-H-03 2700 BXRA-27H7000-J-03 CRI [4] Test Current (mA) Typical [4] Power (W) Typical [4] Efficacy (lm/W) 27.3 9.6 60 1410 36.2 25.3 63 2795 23.5 49.3 64 4935 4390 29.4 82.2 60 350 595 530 27.3 9.6 62 [4] BXRA-30H2000-B-03 3000 97 700 1675 1490 36.2 25.3 66 BXRA-30H4000-H-03 3000 97 2100 3495 3110 23.5 49.3 71 BXRA-30H7000-J-03 3000 97 2800 5350 4760 29.4 82.2 65 BXRA-35H0740-A-03 3500 97 350 655 585 27.3 9.6 69 BXRA-35H2000-B-03 3500 97 700 1730 1540 36.2 25.3 68 BXRA-35H4000-H-03 3500 97 2100 3760 3345 23.5 49.3 76 BXRA-35H7000-J-03 3500 97 2800 5530 4920 29.4 82.2 67 Notes for Table 1: 1. Bridgelux maintains a ±7% tolerance on flux measurements. 2. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10ms at rated test current. 3. Typical performance when driven at DC (direct current) test current with LED Array case temperature maintained at 85°C. Performance values are provided as reference only and are not a guarantee of performance. 4. Values are typical. Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 6 of 24 Typical Performance at Alternative Drive Currents Arrays may also be driven at alternative drive currents. Typical performance at common drive currents is summarized in Table 2. (See notes for Table 2 on following page.) Table 2: Performance at Alternative Drive Currents Part Number[2] CRI BXRA-27H0740-A-03 97 BXRA-27H2000-B-03 BXRA-27H4000-H-03 97 97 Current (mA) Typical Vf Tj = 25ºC (V) Typical Watt Tj = 25ºC (W) Typical Flux Tj = 25ºC (lm)[3] Typical Flux Tcase = 85ºC (lm)[4] Typical Efficacy Tj = 25ºC (lm/W) 250 26.4 6.6 425 375 64 [1] 350 27.3 9.6 570 510 60 350 33.6 11.7 840 750 72 500 34.7 17.4 1180 1040 68 [1] 700 36.2 25.3 1585 1410 63 1400 22.8 31.9 2170 1950 68 1750 23.2 40.5 2675 2410 66 23.5 49.3 3140 2795 64 1750 27.9 48.9 3415 3000 70 [1] 2100 BXRA-27H7000-J-03 BXRA-30H0740-A-03 BXRA-30H2000-B-03 BXRA-30H4000-H-03 97 97 97 97 2100 28.4 59.6 4030 3540 68 2800[1] 29.4 82.2 4935 4390 60 250 26.4 6.6 445 390 67 [1] 350 27.3 9.6 595 530 62 350 33.6 11.7 890 795 76 500 34.7 17.4 1245 1115 72 [1] 700 36.2 25.3 1675 1490 66 1400 22.8 31.9 2415 2170 76 1750 23.2 40.5 2975 2675 73 23.5 49.3 3495 3110 71 1750 27.9 48.9 3700 3260 76 [1] 2100 BXRA-30H7000-J-03 BXRA-35H0740-A-03 BXRA-35H2000-B-03 BXRA-35H4000-H-03 97 97 97 97 2100 28.4 59.6 4370 3845 73 2800[1] 29.4 82.2 5350 4760 65 250 26.4 6.6 490 440 74 [1] 350 27.3 9.6 655 585 69 350 33.6 11.7 920 820 78 500 34.7 17.4 1285 1140 74 [1] 700 36.2 25.3 1730 1540 68 1400 22.8 31.9 2595 2335 81 1750 23.2 40.5 3200 2885 79 23.5 49.3 3760 3345 76 1750 27.9 48.9 3825 3365 78 2100 28.4 59.6 4515 3970 76 29.4 82.2 5530 4920 67 [1] 2100 BXRA-35H7000-J-03 97 [1] 2800 Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 7 of 24 Notes for Table 2: 1. Product is tested and binned at the specified drive current (indicated in bold). 2. Operating these LED Arrays at or below the drive currents listed in Table 1; with a case temperature maintained at or below 85°C, will enable the average lumen maintenance projection outlined earlier in this Product Data Sheet. 3. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10ms at rated nominal test current. 4. Typical performance when driven at DC (direct current) test current with LED Array case temperature maintained at 85°C. Performance values are provided as reference only and are not a guarantee of performance. Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 8 of 24 Flux Characteristics Table 3: Flux Characteristics CCT (K) Test Current (mA) Typical Pulsed Flux Tj = 25ºC [1,2] (lm) Minimum Flux Tj = 25ºC [1,2] (lm) Typical Center Beam Candle Power Tj = 25ºC [4] (cd) Typical DC Flux Tcase = 85ºC [5,6] (lm) Minimum DC Flux Tcase = 85ºC [7] (lm) Part Number Array Form Factor BXRA-27H0740-A-03 ES Star 97 98 350 570 510 170 510 455 BXRA-27H2000-B-03 ES Rectangle 97 98 700 1585 1430 480 1410 1275 97 98 2100 3140 2825 980 2795 2515 97 98 2800 4935 4445 1560 4390 3955 2700 BXRA-27H4000-H-03 CRI [6] R9 [6] RS BXRA-27H7000-J-03 BXRA-30H0740-A-03 ES Star 97 98 350 595 535 185 530 480 BXRA-30H2000-B-03 ES Rectangle 97 98 700 1675 1510 510 1490 1345 97 98 2100 3495 3150 1050 3110 2800 97 98 2800 5350 4815 1675 4760 4280 3000 BXRA-30H4000-H-03 RS BXRA-30H7000-J-03 BXRA-35H0740-A-03 ES Star 97 98 350 655 590 190 585 525 BXRA-35H2000-B-03 ES Rectangle 97 98 700 1730 1560 545 1540 1390 97 98 2100 3760 3385 1130 3345 3010 97 98 2800 5530 4975 1790 4920 4425 3500 BXRA-35H4000-H-03 RS BXRA-35H7000-J-03 Notes for Table 3: 1. Bridgelux maintains a ± 7% tolerance on flux measurements. 2. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 3. Center beam candle power is a calculated value based on Lambertian radiation pattern at normal test current. 4. Typical performance when driven at DC (direct current) test current with LED Array case temperature maintained at 70°C. Performance values are provided as reference only and are not a guarantee of performance. 5. Minimum flux values at steady state and Tcase = 85°C are provided for reference only and are not a parameter guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of luminaire and/or the environment in which the product is operated. 6. Values are typical. Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 9 of 24 Electrical Characteristics Table 4: Electrical Characteristics BXRA-27H0740-A-03 350 24.6 27.3 30.0 -9 to -27 Typical Thermal Resistance Junction to Case (°C/W) RѲ j-c 1.75 BXRA-27H2000-B-03 BXRA-27H4000-H-03 BXRA-27H7000-J-03 BXRA-30H0740-A-03 BXRA-30H2000-B-03 BXRA-30H4000-H-03 BXRA-30H7000-J-03 BXRA-35H0740-A-03 BXRA-35H2000-B-03 BXRA-35H4000-H-03 BXRA-35H7000-J-03 700 2100 2800 350 700 2100 2800 350 700 2100 2800 32.6 21.1 26.4 24.6 32.6 21.1 26.4 24.6 32.6 21.1 26.4 36.2 23.5 29.4 27.3 36.2 23.5 29.4 27.3 36.2 23.5 29.4 39.8 25.8 32.3 30.0 39.8 25.8 32.3 30.0 39.8 25.8 32.3 -12 to -36 -8 to -24 -10 to -30 -9 to -27 -12 to -36 -8 to -24 -10 to -30 -9 to -27 -12 to -36 -8 to -24 -10 to -30 0.65 0.31 0.26 1.75 0.65 0.31 0.26 1.75 0.65 0.31 0.26 Part Number Test Current (mA) Forward Voltage Pulsed, Tj = 25°C [1,2,3] (V) Vf Min Vf Typ Vf Max Typical Coefficient of Forward Voltage [3] (mV/°C) ΔVf/ΔTj Notes for Table 4: 1. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. 2. Forward voltage minimum and maximum values at the rated test current are guaranteed by 100% test. Values provided at alternative drive currents are provided for reference only and are not guaranteed by 100% test. 3. Bridgelux maintains a tolerance of ± 10% on the Coefficient of Forward Voltage at nominal current. Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 10 of 24 Absolute Minimum and Maximum Ratings Table 5: Maximum Current and Reverse Voltage Ratings Part Number Maximum Direct Current (mA) Maximum Peak Pulsed Current [1,3,4] (mA) Maximum Reverse Voltage [2] (Vr) BXRA-27H0740-A-03 BXRA-27H2000-B-03 BXRA-27H4000-H-03 BXRA-27H7000-J-03 BXRA-30H0740-A-03 BXRA-30H2000-B-03 BXRA-30H4000-H-03 BXRA-30H7000-J-03 BXRA-35H0740-A-03 BXRA-35H2000-B-03 BXRA-35H4000-H-03 BXRA-35H7000-J-03 500 1000 3000 3750 500 1000 3000 3750 500 1000 3000 3750 700 1400 4000 5000 700 1400 4000 5000 700 1400 4000 5000 -45 Volts -60 Volts -40 Volts -50 Volts -45 Volts -60 Volts -40 Volts -50 Volts -45 Volts -60 Volts -40 Volts -50 Volts Notes for Table 5: 1. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. 2. Light emitting diodes are not designed to be driven in reverse voltage. 3. Maximum peak pulsed currents are values at which the LED Array can be driven without catastrophic failures. 4. Arrays can be driven at higher currents but lumen maintenance may be reduced. Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 150°C Storage Temperature -40°C to +105°C Operating Case Temperature 105°C Soldering Temperature (2) (1) 350°C or lower for a maximum of 3.5 seconds Note for Table 6: 1. 2. A maximum case temperature of 95°C must be observed to achieve EcoDesign EU compliance. See Bridgelux Application Note AN15: Reflow soldering of Bridgelux LED Arrays for solder procedure (www.Bridgelux.com) Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 11 of 24 Forward Current vs. Voltage Characteristics Typical performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 2, 3, 4, 5 and the flux vs. current characteristics in Figures 6, 7, 8 and 9. Figure 2: Current vs. Voltage - ES Star Part Numbers BXRA-xxH0740-A-03 0.7 0.6 MIN Vf Tc=25°C Current (A) 0.5 MAX Vf Tc=25°C 0.4 0.3 0.2 MIN MAX TYP MIN Tc=70 TYP Vf Tc=25°C MIN Vf Tc=70°C 0.1 0.0 20.0 22.5 25.0 27.5 30.0 32.5 35.0 Forward Voltage (V) Figure 3: Current vs. Voltage - ES Rectangle Part Numbers BXRA-xxH2000-B-03 MIN Vf Tc=25°C MIN Vf Tc=70°C MAX Vf Tc=25°C TYP Vf Tc=25°C Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 12 of 24 Forward Current vs. Voltage Characteristics (continued) Figure 4: Current vs. Voltage - RS Part Numbers BXRA-xxH4000-H-03 MIN Vf Tc=25°C MIN Vf Tc=70°C MAX Vf Tc=25°C TYP Vf Tc=25°C Figure 5: Current vs. Voltage - RS Part Numbers BXRA-xxH7000-J-03 MIN Vf Tc=25°C MAX Vf Tc=25°C MIN Vf Tc=70°C TYP Vf Tc=25°C Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 13 of 24 Normalized Luminous Flux vs. Current (Tj = 25°C) Characteristics Figure 6: Typical Flux vs. Current BXRA-xxH0740-A-03 2.0 1.8 1.6 Normalized Flux 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 0 50 100 150 200 250 300 350 400 450 500 550 600 650 700 Current (mA) Figure 7: Typical Flux vs. Current BXRA-XXH2000-B-03 1.6 1.4 Normalized Flux 1.2 1 0.8 0.6 0.4 0.2 0 0 100 200 300 400 500 600 Current (mA) Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 700 8/12/2013 800 900 1000 Page 14 of 24 Normalized Luminous Flux vs. Currrent (Tj = 25°C) Characteristics (continued) Figure 8: Typical Flux vs. Current BXRA-XXH4000-H-03 1.8 1.6 Normalized Flux 1.4 1.2 1 0.8 0.6 0.4 0.2 0 0 500 1000 1500 2000 2500 3000 3500 Current (mA) Figure 9: Typical Flux vs. Current BXRA-XXH7000-J-03 1.6 1.4 Normalized Flux 1.2 1 0.8 0.6 0.4 0.2 0 0 500 1000 1500 2000 2500 3000 3500 4000 4500 Current (mA) Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 15 of 24 Normalized Luminous Flux vs. Junction Temperature Figure 10: Normalized Luminous Flux vs. Junction Temperature 1.2 Normalized Flux 1.0 0.8 0.6 0.4 0.2 0.0 -10 0 10 20 30 40 50 60 70 Junction Temperature (°C) Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 80 90 100 110 Page 16 of 24 Typical Chromaticity vs. Temperature Characteristics Figure 11: Typical ccx Shift vs. Junction Temperature 0.02 0.01 0.00 Δx -0.01 -0.02 -0.03 -0.04 -0.05 -0.06 -10 0 10 20 30 40 50 60 70 80 90 100 110 90 100 Junction Temperature (°C) Figure 12: Typical ccy Shift vs. Junction Temperature 0.02 0.01 0.00 Δy -0.01 -0.02 -0.03 -0.04 -0.05 -0.06 -10 0 10 20 30 40 50 60 70 Junction Temperature (°C) Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 80 110 Page 17 of 24 Typical Radiation Pattern Figure 13: Typical Spatial Radiation Pattern Notes for Figure 13: 1. Typical viewing angle is 120°. 2. Viewing angle is defined as the off axis angle from the centerline where intensity is ½ of peak value. Figure 14: Typical Polar Radiation Pattern Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 18 of 24 Wavelength and CRI Characteristics at Rated Test Current (Tj=25°C) The high CRI light delivered by the Bridgelux Décor products reproduces colors faithfully compared with natural light. Figure 15 displays the spectral curve of Décor compared to a halogen curve. Table 7 compares CRI R values of Décor to other light sources. The typical overall CRI (Ra) of 97 results in excellent color representation - especially of the colors to which the human eye is particularly sensitive. Décor delivers high typical values of R9 (98) and R15 (98). These are important attributes for the perception of realistic colors. R9 enhances red colors and R15 enables realistic rendering of human skin tones. Spectral Power Density Figure 15: Typical Spectral Power Density and R x Values for Décor Products 1.00 0.80 3000KBridgelux Bridgelux 3000K Décor Spectrum Ultra CRI Spectrum 0.60 0.40 3000KHalogen Halogen 3000K Spectrum Lamp Spectrum 0.20 0.00 350 400 450 500 550 600 650 700 750 Wavelength (nm) Table 7: CRI Spectra for Décor Products vs. Other Light Sources Ra R1 R2 R3 R4 R5 R6 R7 R8 R9 R10 R11 R12 R13 R14 R15 Bridgelux Décor 97 97 100 96 96 98 98 99 98 98 99 92 87 98 97 98 Typical Halogen 98 98 99 99 99 98 98 99 97 92 97 98 97 98 99 97 Typical Metal Halide 82 90 94 69 82 81 81 87 71 27 59 62 55 93 78 88 Typical Compact Fluorescent 87 91 93 86 91 89 90 88 70 17 76 91 81 93 92 81 Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 19 of 24 Mechanical Dimensions Figure 16: Drawing for ES Star Part Number BXRA-xxH0740-A-03 Case Temperature Measurement Location (Tc) Figure 17: Drawing for ES Rectangle Part Number BXRA-xxH2000-B-03 Case Temperature Measurement Location (Tc) TOP VIEW Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 SIDE VIEW 8/12/2013 Page 20 of 24 Mechanical Dimensions (continued) Figure 18: Drawing for RS Part Numbers BXRA-xxH4000-H-03 and BXRA-xxH7000-J-03 Case Temperature Measurement Location (Tc) TOP VIEW SIDE VIEW Notes for Figures 16, 17 and 18: 1. Mounting holes are for M2.5 or #4 screws. 2. Solder pads are labeled “+” and “-” to denote positive and negative, respectively. 3. It is not necessary to provide electrical connections to both sets of solder pads. Either set may be used depending on application specific design requirements. 4. Drawings are not to scale. 5. Drawing dimensions are in millimeters. 6. Unless otherwise specified, tolerances are ± 0.10mm. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array. The light emitting surface (LES) is centered on the mechanical center of the array to a tolerance of ± 0.45 mm. 8. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 21 of 24 Color Binning Information 37 10 K 0.41 Y T3 R3 Q3 N3 2700K 3SDCM T4 S4 R4 0.39 Q4 P4 0.38 S3 P3 3500K 3SDCM 0.4 32 20 K 3000K 3SDC 0.42 34 65 K 0.43 30 45 K 3000K 3SDCM 0.44 28 70 K Figure 19: Graph of Warm White Test Bins in xy Color Space 27 25 K 25 80 K N4 0.37 0.36 0.35 0.38 0.4 0.42 0.44 0.46 0.48 X Note: 3SDCM bins are shown inside standard ANSI bins for comparison purposes. Table 9: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code x y X3 (3SDCM) 0.4148 0.4047 0.4012 0.4098 0.4148 0.4000 0.3950 0.3841 0.3883 0.4000 CCT (K) 3500 Bin Code x y X3 (3SDCM) 0.4413 0.4325 0.4274 0.4350 0.4413 0.4107 0.4075 0.3958 0.3984 0.4107 Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 CCT (K) 3000 8/12/2013 Bin Code x y CCT (K) X3 (3SDCM) 0.4665 0.4557 0.4500 0.4595 0.4665 0.4175 0.4145 0.4026 0.4050 0.4175 2700 Page 22 of 24 Design Resources Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with Bridgelux LED Array products. Included below is a list of available resources which can be downloaded from the Bridgelux web site under the Design Resources section. These documents are updated regularly as new information becomes available, including complimentary infrastructure products such as commercially available secondary optics and electronic driver solutions. Application Notes       AN10: AN11: AN12: AN14: AN15: AN16: Effective Thermal Management of Bridgelux LED Arrays Assembly Considerations for Bridgelux LED Arrays Electrical Drive Considerations for Bridgelux LED Arrays Reliability Data Sheet for Bridgelux LED Arrays Reflow Soldering of Bridgelux LED Arrays Optical Considerations for Bridgelux LED Arrays Optical Source Models Optical source models and ray set files are available for all Bridgelux LED Array products, and can be downloaded directly from the Bridgelux web site. The list below contains the formats currently available. If you require a specific format not included in this list, please contact your Bridgelux sales representative for assistance.          Zemax ASAP IESNA LightTools LucidShape OPTIS SPEOS PHOTOPIA TracePro Radiant Imaging Source Model 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux LED Arrays are available in both SAT and STEP formats. These CAD files can be downloaded directly from the Bridgelux web site. Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 23 of 24 About Bridgelux Bridgelux is a leading developer and manufacturer of technologies and solutions transforming the $40 billion global lighting industry into a $100 billion market opportunity. Based in Livermore, California, Bridgelux is a pioneer in solid-state lighting (SSL), expanding the market for light-emitting diode (LED) technologies by driving down the cost of LED lighting systems. Bridgelux’s patented light source technology replaces traditional technologies (such as incandescent, halogen, fluorescent and high intensity discharge lighting) with integrated, solid-state lighting solutions that enable lamp and luminaire manufacturers to provide high performance and energy-efficient white light for the rapidly growing interior and exterior lighting markets, including street lights, commercial lighting and consumer applications. With more than 550 patent applications filed or granted worldwide, Bridgelux is the only vertically integrated LED manufacturer and developer of solid-state light sources that designs its solutions specifically for the lighting industry. For more information about the company, please visit www.bridgelux.com © 2013 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux Décor Ultra High CRI LED Array Data Sheet DS28 8/12/2013 Page 24 of 24
BXRA-35H2000-B-03 价格&库存
很抱歉,暂时无法提供与“BXRA-35H2000-B-03”相匹配的价格&库存,您可以联系我们找货
