SMP4-SRGB
SMP4-SRGB
    BIVAR
    PLCC-4
    发光二极管/LED PLCC-4
SMP4-SRGB 数据手册
PLCC4 SMD Top View Package LED SMP4-SRGB, RED/GREEN/BLUE SMP4-SRGB ♦ ♦ ♦ ♦ ♦ Industry Standard PLCC4 Footprint 3 Super Bright Chips in One Low Profile Package High Luminous Intensity Wide Viewing Angle High Power Efficiency Bivar SMP4 Super Bright Tri-Color LED combines three chips in a single package and is offered in an industry standard PLCC4 footprint. The SMP4 LED has a water clear lens for high luminous intensity and wide viewing angle making them ideal for outdoor illumination applications where higher ambient lighting conditions exist. The flexible three chip design allows for a wide variety of lighting options where the chips can be individually driven or mixed to create different color combinations. The robust package is ideal for harsh working environments and can be clustered in LED arrays for high luminous applications. Low power consumption and excellent long life reliability are suitable for battery powered equipment. Bivar SMP4 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Lumen Typ. mcd AlGaInP Red 180 InGaN Green 1450 InGaN Blue 285 SMP4-SRGB Lens Color Viewing Angle Water Clear 120° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision E 08/15 Page 1 of 5 PLCC4 SMD Top View Package LED SMP4-SRGB, RED/GREEN/BLUE Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation Red, Green - 78 mW Blue - 80 mW Continuous Forward Current Red, Green - 30 mA Blue - 25 mA Peak Forward Current 1 100 mA Reverse Voltage 5V Electrostatic Discharge Classification (HBM) 2000 V Derating Linear From 25°C 0.4 mA/°C Operating Temperature Range -40 ~ +85°C Storage Temperature Range -40 ~ +100°C Soldering Temperature2 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Emitting Color Forward Voltage (V)1 Recommend Forward Current (mA) Reverse Current (µA) VR=5V Dominant Wavelength (nm)2 Luminous Intensity (mcd)3 TYP MAX TYP MAX TYP MIN TYP Red 1.9 2.6 20 10 625 115 180 Green 3.3 4.5 20 10 525 1050 1450 Blue 3.3 4.3 20 10 470 115 285 Viewing Angle 2 Ө ½ (deg) TYP 120 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Dominant Wavelength : ±0.1nm. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Radiation Diagram Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision E 08/15 Page 2 of 5 PLCC4 SMD Top View Package LED SMP4-SRGB, RED/GREEN/BLUE Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Blue Red Green Red, Green, Blue Green, Blue Red Blue Red Green Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision E 08/15 Page 3 of 5 PLCC4 SMD Top View Package LED SMP4-SRGB, RED/GREEN/BLUE Recommended Soldering Conditions Tape and Reel Dimensions Note: 2000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision E 08/15 Page 4 of 5 PLCC4 SMD Top View Package LED SMP4-SRGB, RED/GREEN/BLUE 0.63 [16.0mm] Packaging and Labeling Plan Note: 1 Reel / Bag Sealed ESD and Moisture Barrier Bag Internal Quality Control Label X.XXX Humidity Indicator Card Desiccant X.XXX Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision E 08/15 Page 5 of 5
SMP4-SRGB
物料型号:SMP4-SRGB
器件简介:BIVAR SMP4-SRGB是一款三色LED,在一个封装内集成了三个芯片,采用行业标准的PLCC4引脚布局。具有高亮度、宽视角,适合户外照明等高环境光条件下的应用。三个芯片设计灵活,可以单独驱动或混合产生不同的颜色组合。坚固的封装适合恶劣工作环境,可以用于高亮度应用的LED阵列。低功耗和长寿命特性适合电池供电设备。SMP4 LED采用标准胶带和卷轴包装,便于自动贴装。
引脚分配:共有四个引脚,其中三个为阳极(Anode),一个为阴极(Cathode),分别对应红、绿、蓝三种颜色。
参数特性: - 发光颜色:红、绿、蓝 - 典型光通量(mcd):红180、绿1450、蓝285 - 透镜颜色:水清透镜 - 视角:120°
功能详解:SMP4 LED具有高功率效率,可以在低功耗下实现高亮度照明。其设计允许在不同的应用中灵活使用,例如单独驱动或混合驱动以产生不同的颜色效果。
应用信息:适用于户外照明、LED阵列等高亮度应用。
封装信息:PLCC4 SMD封装,具有低轮廓设计,适合自动贴装。
电气特性:包括正向电压、推荐正向电流、反向电流、主波长和发光强度等参数。
环境特性:包括绝对最大额定值、存储温度范围、焊接温度等。
SMP4-SRGB 价格&库存
很抱歉,暂时无法提供与“SMP4-SRGB”相匹配的价格&库存,您可以联系我们找货
