BXRC-20B10K1-D-73
BXRC-20B10K1-D-73
    BRIDGELUX(普瑞)
    BXRC-20B10K1-D-73
BXRC-20B10K1-D-73 数据手册
Bridgelux Gen 7 Vero 29 Array ® ® Product Data Sheet DS93 1 Vero® Series Introduction Vero® Series is a revolutionary advancement in chip on board (COB) light source technology and innovation. Vero LED light sources simplify luminaire design and manufacturing processes Vero Chip on Board (COB) LED arrays are available in four LES configurations, engineered to enable new degrees of flexibility and reliability over a broad range of electrical currents. Vero arrays deliver increased lumen density to enable improved beam control and precision lighting with 2 and 3 SDCM color control standard for clean and consistent uniform lighting. Vero products include an onboard connector port that enables a solder-free electrical interconnect, and simple mounting features for plug-and-play installation. Bridgelux Décor Series™ is our state-of-the-art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and pleasing lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD. Décor Series™ Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and typical R9 value of 98, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is designed as a replacement for halogen lamps Décor Series™ Food products offer color points developed to address the unique requirements of the food, grocery, and restaurant industries. Highlighting the distinctive colors and nuanced patterns found in meats and breads, the Décor Series Food products are a must have for any butcher counter or bakery. Décor Series ™ Entertainment products provide color points developed specifically for the healthcare and entertainment industries. The 5600K cool white color point combined with a CRI of 90 or 97 provides the bright white required by these industries. Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps. Features • Efficacy of 160 lm/W typical • Lumen output performance ranges from 3,850 to 38,400 lumens • Broad range of CCT options from 1750K to 6500K • CRI options include minimum 65, 70, 80, and 90, 2 and 3 SDCM color control for 2700K-4000K CCT Benefits • Broad application coverage for interior and exterior lighting • Flexibility for application driven lighting design requirements • High quality true color reproduction • Uniform consistent white light • Reliable operation at up to 2X nominal drive current • Flexibility in design optimization • Radial die pattern and improved lumen density • Enhanced ease of use and assembly • Thermally isolated solder pads • Solderless connectivity enables plug & play installation and field upgradability • Onboard connector port • Top side part number markings • Vf bin code backside marking • Improved inventory management and quality control Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 8 Electrical Characteristics 16 Eye Safety 17 Absolute Maximum Ratings 18 Performance Curves 19 Typical Radiation Pattern 23 Typical Color Spectrum 24 Mechanical Dimensions 25 Color Binning Information 26 Packaging and Labeling 27 Design Resources 29 Precautions 29 Disclaimers 29 About Bridgelux 30 1 Product Feature Map Vero 29 is the largest form factor in the Vero family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www.bridgelux.com for more information on the Vero Series family of products. Mounting holes Thermally isolated solder pads reduce manufacturing cycle time and complexity Polarity indication marks simplify manufacturing operator instructions Tc Measurement point 2D Bar code provides full manufacturing traceability Top side part number marking improves inventory management and outgoing quality control Radial die configuration improves lumen density and beam control Solderless connector port enables simplified manufacturing processes, reduced inventory carrying costs and can enable field upgradability Optional Molex Pico-EZmate™ connector harness (sold separately) Product Nomenclature The part number designation for Bridgelux Vero LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRC – 30 E 10K 0 – C – 7 3 CCT Bin Options Product Family Nominal CCT 17 = 1,750K 20 = 2,000K 25 = 2,500K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 56 = 5,600K 57 = 5,700K 65 = 6,500K Gen. 7 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Array Configuration CRI B = 65 CRI min. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted Flux Indicator 10Kx = 10,000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-17E10K0-B-74 1750 80 1800 8291 7462 52.0 93.6 89 BXRC-17E10K0-C-74 1750 80 1710 10512 9461 69.4 118.7 89 BXRC-17E10K0-D-74 1750 80 2100 6994 6295 37.6 79.0 89 BXRC-20B10K1-C-73 2000 65 1710 17724 15952 69.4 118.7 149 BXRC-20B10K1-D-73 2000 65 2100 11793 10613 37.6 79.0 149 BXRC-25E10K0-B-74 2500 80 1800 13401 12061 52.0 93.6 143 BXRC-25E10K0-C-74 2500 80 1710 16991 15292 69.4 118.7 143 BXRC-25E10K0-D-74 2500 80 2100 11305 10174 37.6 79.0 143 BXRC-27E10K0-B-7X 2700 80 1800 14365 12928 52.0 93.6 153 BXRC-27E10K0-C-7X 2700 80 1710 18213 16392 69.4 118.7 153 BXRC-27E10K0-D-7X 2700 80 2100 12118 10906 37.6 79.0 153 BXRC-27G10K0-B-7X 2700 90 1800 11955 10759 52.0 93.6 128 BXRC-27G10K0-C-7X 2700 90 1710 15157 13641 69.4 118.7 128 BXRC-27G10K0-D-7X 2700 90 2100 10085 9076 37.6 79.0 128 BXRC-27H10K0-D-74 2700 97 2100 8788 7909 37.6 79.0 111 BXRC-30E10K0-B-7X10 3000 80 1800 14943 13449 52.0 93.6 160 BXRC-30E10K0-C-7X10 3000 80 1710 18946 17052 69.4 118.7 160 BXRC-30E10K0-D-7X10 3000 80 2100 12606 11345 37.6 79.0 160 BXRC-30G10K0-B-7X 3000 90 1800 12437 11193 52.0 93.6 133 BXRC-30G10K0-C-7X 3000 90 1710 15768 14191 69.4 118.7 133 BXRC-30G10K0-D-7X 3000 90 2100 10491 9442 37.6 79.0 133 BXRC-30H10K0-D-7X 3000 97 2100 9353 8418 37.6 79.0 118 BXRC-30A10K1-B-738,9 3000 93 1800 11232 10109 52.0 93.6 120 BXRC-30A10K1-C-738,9 3000 93 1710 14241 12817 69.4 118.7 120 BXRC-30A10K1-D-738,9 3000 93 2100 9475 8528 37.6 79.0 120 BXRC-35E10K0-B-7X10 3500 80 1800 15425 13883 52.0 93.6 165 BXRC-35E10K0-C-7X10 3500 80 1710 19557 17602 69.4 118.7 165 BXRC-35E10K0-D-7X10 3500 80 2100 13013 11711 37.6 79.0 165 BXRC-35G10K0-B-7X 3500 90 1800 12822 11540 52.0 93.6 137 BXRC-35G10K0-C-7X 3500 90 1710 16257 14631 69.4 118.7 137 BXRC-35G10K0-D-7X 3500 90 2100 10817 9735 37.6 79.0 137 BXRC-35A10K1-B-738,9 3500 93 1800 12074 10867 52.0 93.6 129 BXRC-35A10K1-C-738,9 3500 93 1710 15309 13778 69.4 118.7 129 BXRC-35A10K1-D-73 3500 93 2100 10186 9167 37.6 79.0 129 8,9 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Décor Series Class A and Décor Series Ultra products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ±3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3 10. SKUs can meet DLC premium (Outdoor Mid Output) requirements under certain system level conditions. Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI Nominal Drive Current3 (mA) 2 Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-40E10K0-B-7X10 4000 80 1800 15522 13970 52.0 93.6 166 BXRC-40E10K0-C-7X10 4000 80 1710 19680 17712 69.4 118.7 166 BXRC-40E10K0-D-7X10 4000 80 2100 13094 11785 37.6 79.0 166 BXRC-40G10K0-B-7X 4000 90 1800 13304 11974 52.0 93.6 142 BXRC-40G10K0-C-7X 4000 90 1710 16868 15181 69.4 118.7 142 142 BXRC-40G10K0-D-7X 4000 90 2100 11223 10101 37.6 79.0 BXRC-40H10K0-D-7X 4000 97 2100 9633 8670 37.6 79.0 122 BXRC-40A10K1-B-738,9 4000 93 1800 12917 11625 52.0 93.6 138 BXRC-40A10K1-C-738,9 4000 93 1710 16377 14739 69.4 118.7 138 BXRC-40A10K1-D-738,9 4000 93 2100 10896 9807 37.6 79.0 138 BXRC-50C10K1-B-7x10 5000 70 1800 17064 15358 52.0 93.6 182 BXRC-50C10K1-C-7x10 5000 70 1710 21635 19472 69.4 118.7 182 BXRC-50C10K1-D-7x10 5000 70 2100 14395 12956 37.6 79.0 182 BXRC-50E10K1-B-7x10 5000 80 1800 16004 14403 52.0 93.6 171 BXRC-50E10K1-C-7x10 5000 80 1710 20291 18262 69.4 118.7 171 BXRC-50E10K1-D-7x10 5000 80 2100 13501 12151 37.6 79.0 171 BXRC-50G10K1-B-7x 5000 90 1800 13594 12234 52.0 93.6 145 BXRC-50G10K1-C-7x 5000 90 1710 17235 15512 69.4 118.7 145 BXRC-50G10K1-D-7x 5000 90 2100 11467 10321 37.6 79.0 145 BXRC-56G10K0-B-74 5600 90 1800 14268 12842 52.0 93.6 152 BXRC-56G10K0-C-74 5600 90 1710 18091 16282 69.4 118.7 152 BXRC-56G10Kx-D-74 5600 90 2100 12037 10833 37.6 79.0 152 BXRC-56H10K0-D-74 5600 97 2100 10410 9369 37.6 79.0 132 BXRC-57C10K1-B-7x10 5700 70 1800 16486 14837 52.0 93.6 176 BXRC-57C10K1-C-7x10 5700 70 1710 20902 18812 69.4 118.7 176 BXRC-57C10K1-D-7x10 5700 70 2100 13907 12517 37.6 79.0 176 BXRC-57E10K1-B-7x10 5700 80 1800 15818 14237 52.0 93.6 169 BXRC-57E10K1-C-7x10 5700 80 1710 20056 18050 69.4 118.7 169 BXRC-57E10K1-D-7x10 5700 80 2100 13344 12010 37.6 79.0 169 BXRC-65C10K1-B-7x10 6500 70 1800 16775 15097 52.0 93.6 179 BXRC-65C10K1-C-7x10 6500 70 1710 21269 19142 69.4 118.7 179 10 BXRC-65C10K1-D-7x 6500 70 2100 14151 12736 37.6 79.0 179 BXRC-65E10K1-B-7x10 6500 80 1800 16099 14489 52.0 93.6 172 BXRC-65E10K1-C-7x10 6500 80 1710 20412 18371 69.4 118.7 172 BXRC-65E10K1-D-7x10 6500 80 2100 13581 12223 37.6 79.0 172 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Décor Series Class A and Décor Series Ultra products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ±3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 4 10. SKUs can meet DLC premium (Outdoor Mid Output) requirements under certain system level conditions. Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30A10K1-B-73 3000 80 93 1800 10446 9401 50.9 91.6 114 BXRC-30A10K1-C-73 3000 80 93 1710 13244 11920 67.9 116.1 114 BXRC-30A10K1-D-73 3000 80 93 2100 8812 7931 36.8 77.3 114 BXRC-35A10K1-B-73 3500 80 93 1800 11229 10106 50.9 91.6 123 BXRC-35A10K1-C-73 3500 80 93 1710 14237 12814 67.9 116.1 123 BXRC-35A10K1-D-73 3500 80 93 2100 9473 8526 36.8 77.3 122 BXRC-40A10K1-B-73 4000 80 93 1800 12013 10811 50.9 91.6 131 BXRC-40A10K1-C-73 4000 80 93 1710 15231 13708 67.9 116.1 131 BXRC-40A10K1-D-73 4000 80 93 2100 10134 9120 36.8 77.3 131 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 5 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 82 BXRC-17E10K0-B-74 1750 80 1800 7462 6716 50.7 91.2 BXRC-17E10K0-C-74 1750 80 1710 9461 8515 68.1 116.4 81 BXRC-17E10K0-D-74 1750 80 2100 6295 5665 36.6 76.8 82 BXRC-20B10K1-C-73 2000 65 1710 15952 14356 68.1 116.4 137 BXRC-20B10K1-D-73 2000 65 2100 10613 9552 36.6 76.8 138 132 BXRC-25E10K0-B-74 2500 80 1800 12061 10855 50.7 91.2 BXRC-25E10K0-C-74 2500 80 1710 15292 13762 68.1 116.4 131 BXRC-25E10K0-D-74 2500 80 2100 10174 9157 36.6 76.8 133 142 BXRC-27E10K0-B-7X 2700 80 1800 12928 11635 50.7 91.2 BXRC-27E10K0-C-7X 2700 80 1710 16392 14752 68.1 116.4 141 BXRC-27E10K0-D-7X 2700 80 2100 10906 9816 36.6 76.8 142 118 BXRC-27G10K0-B-7X 2700 90 1800 10759 9683 50.7 91.2 BXRC-27G10K0-C-7X 2700 90 1710 13641 12277 68.1 116.4 117 BXRC-27G10K0-D-7X 2700 90 2100 9076 8169 36.6 76.8 118 103 BXRC-27H10K0-D-74 2700 97 2100 7909 7118 36.6 76.8 BXRC-30E10K0-B-7X 3000 80 1800 13449 12104 50.7 91.2 147 BXRC-30E10K0-C-7X 3000 80 1710 17052 15347 68.1 116.4 146 BXRC-30E10K0-D-7X 3000 80 2100 11345 10211 36.6 76.8 148 123 BXRC-30G10K0-B-7X 3000 90 1800 11193 10074 50.7 91.2 BXRC-30G10K0-C-7X 3000 90 1710 14191 12772 68.1 116.4 122 BXRC-30G10K0-D-7X 3000 90 2100 9442 8498 36.6 76.8 123 110 BXRC-30H10K0-D-7X 3000 97 2100 8418 7576 36.6 76.8 BXRC-30A10K1-B-737,8 3000 93 1800 10109 9098 50.7 91.2 111 BXRC-30A10K1-C-737,8 3000 93 1710 12817 11535 68.1 116.4 110 BXRC-30A10K1-D-737,8 3000 93 2100 8528 7675 36.6 76.8 111 152 BXRC-35E10K0-B-7X 3500 80 1800 13883 12494 50.7 91.2 BXRC-35E10K0-C-7X 3500 80 1710 17602 15842 68.1 116.4 151 BXRC-35E10K0-D-7X 3500 80 2100 11711 10540 36.6 76.8 153 BXRC-35G10K0-B-7X 3500 90 1800 11540 10386 50.7 91.2 127 BXRC-35G10K0-C-7X 3500 90 1710 14631 13168 68.1 116.4 126 BXRC-35G10K0-D-7X 3500 90 2100 9735 8762 36.6 76.8 127 7,8 BXRC-35A10K1-B-73 3500 93 1800 10867 9780 50.7 91.2 119 BXRC-35A10K1-C-737,8 3500 93 1710 13778 12400 68.1 116.4 118 BXRC-35A10K1-D-737,8 3500 93 2100 9167 8251 36.6 76.8 119 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Décor Series Class A and Décor Series Ultra products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ±3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 6 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 153 BXRC-40E10K0-B-7X 4000 80 1800 13970 12573 50.7 91.2 BXRC-40E10K0-C-7X 4000 80 1710 17712 15941 68.1 116.4 152 BXRC-40E10K0-D-7X 4000 80 2100 11785 10606 36.6 76.8 154 BXRC-40G10K0-B-7X 4000 90 1800 11974 10776 50.7 91.2 131 BXRC-40G10K0-C-7X 4000 90 1710 15181 13663 68.1 116.4 130 BXRC-40G10K0-D-7X 4000 90 2100 10101 9091 36.6 76.8 132 BXRC-40H10K0-D-7X 4000 97 2100 8670 7803 36.6 76.8 113 7,8 BXRC-40A10K1-B-73 4000 93 1800 11625 10463 50.7 91.2 127 BXRC-40A10K1-C-737,8 4000 93 1710 14739 13265 68.1 116.4 127 BXRC-40A10K1-D-737,8 4000 93 2100 9807 8826 36.6 76.8 128 168 BXRC-50C10K1-B-7x 5000 70 1800 15358 13822 50.7 91.2 BXRC-50C10K1-C-7x 5000 70 1710 19472 17525 68.1 116.4 167 BXRC-50C10K1-D-7x 5000 70 2100 12956 11660 36.6 76.8 169 BXRC-50E10K1-B-7x 5000 80 1800 14403 12963 50.7 91.2 158 BXRC-50E10K1-C-7x 5000 80 1710 18262 16436 68.1 116.4 157 BXRC-50E10K1-D-7x 5000 80 2100 12151 10935 36.6 76.8 158 134 BXRC-50G10K1-B-7x 5000 90 1800 12234 11011 50.7 91.2 BXRC-50G10K1-C-7x 5000 90 1710 15512 13960 68.1 116.4 133 BXRC-50G10K1-D-7x 5000 90 2100 10321 9289 36.6 76.8 134 BXRC-56G10K0-B-74 5600 90 1800 12842 11557 50.7 91.2 141 BXRC-56G10K0-C-74 5600 90 1710 16282 14653 68.1 116.4 140 BXRC-56G10Kx-D-74 5600 90 2100 10833 9750 36.6 76.8 141 BXRC-56H10K0-D-74 5600 97 2100 9369 8432 36.6 76.8 122 163 BXRC-57C10K1-B-7x 5700 70 1800 14837 13353 50.7 91.2 BXRC-57C10K1-C-7x 5700 70 1710 18812 16931 68.1 116.4 162 BXRC-57C10K1-D-7x 5700 70 2100 12517 11265 36.6 76.8 163 BXRC-57E10K1-B-7x 5700 80 1800 14237 12813 50.7 91.2 156 BXRC-57E10K1-C-7x 5700 80 1710 18050 16245 68.1 116.4 155 BXRC-57E10K1-D-7x 5700 80 2100 12010 10809 36.6 76.8 156 166 BXRC-65C10K1-B-7x 6500 70 1800 15097 13588 50.7 91.2 BXRC-65C10K1-C-7x 6500 70 1710 19142 17228 68.1 116.4 164 BXRC-65C10K1-D-7x 6500 70 2100 12736 11462 36.6 76.8 166 BXRC-65E10K1-B-7x 6500 80 1800 14489 13040 50.7 91.2 159 BXRC-65E10K1-C-7x 6500 80 1710 18371 16534 68.1 116.4 158 BXRC-65E10K1-D-7x 6500 80 2100 12223 11001 36.6 76.8 159 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Class A and Décor Series Ultra products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ±3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary 7 depending on fixture design and performance. Performance at Commonly Used Drive Currents Vero LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-17E10K0-B-74 80 BXRC-17E10K0-C-74 80 BXRC-17E10K0-D-74 80 BXRC-20B10K1-C-73 65 BXRC-20B10K1-D-73 65 BXRC-25E10K0-B-74 80 BXRC-25E10K0-C-74 80 BXRC-25E10K0-D-74 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.7 79.0 124.4 173.0 56.6 76.7 118.7 185.0 254.6 37.2 50.7 79.0 124.4 173.0 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.7 79.0 124.4 173.0 4304 5667 8291 11951 15297 5972 7590 10512 14913 18692 3847 4951 6994 9957 12550 10068 12797 17724 25144 31515 6487 8348 11793 16789 21160 6957 9160 13401 19317 24724 9652 12267 16991 24103 30211 6218 8003 11305 16094 20284 3929 5152 7462 10659 13477 5683 7001 9461 12826 15706 3749 4608 6295 8390 10248 9581 11804 15952 21625 26482 6320 7769 10613 14146 17279 6350 8326 12061 17227 21783 9185 11316 15292 20731 25386 6059 7448 10174 13561 16564 96 94 89 82 76 106 99 89 81 73 104 98 89 80 73 178 167 149 136 124 175 165 149 135 122 156 151 143 132 123 171 160 143 130 119 167 158 143 129 117 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27E10K0-B-7X 80 BXRC-27E10K0-C-7X 80 BXRC-27E10K0-D-7X 80 BXRC-27G10K0-B-7X 90 BXRC-27G10K0-C-7X 90 BXRC-27G10K0-D-7X 90 BXRC-27H10K0-D-74 97 BXRC-30E10K0-B-7X 80 BXRC-30E10K0-C-7X 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 7457 9819 14365 20707 26502 10346 13150 18213 25837 32385 6666 8578 12118 17252 21743 6206 8171 11955 17232 22056 8610 10944 15157 21502 26951 5547 7139 10085 14357 18095 4834 6221 8788 12511 15768 7757 10214 14943 21540 27569 10763 13679 18946 26878 33689 6807 8925 12928 18466 23350 9845 12130 16392 22222 27212 6495 7983 10906 14536 17755 5665 7428 10759 15368 19433 8193 10095 13641 18493 22646 5405 6644 9076 12097 14776 4710 5790 7909 10542 12876 7081 9285 13449 19210 24291 10242 12618 17052 23117 28308 167 162 153 142 132 183 171 153 140 127 179 169 153 139 126 139 135 128 118 110 152 143 128 116 106 149 141 128 115 105 130 123 111 101 91 174 169 160 147 137 190 178 160 145 132 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30E10K0-D-7X 80 BXRC-30G10K0-B-7X 90 BXRC-30G10K0-C-7X 90 BXRC-30G10K0-D-7X 90 BXRC-30H10K0-D-7X 97 BXRC-30A10K1-B-73 93 BXRC-30A10K1-C-73 93 BXRC-30A10K1-D-73 93 BXRC-35E10K0-B-7X 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 6934 8924 12606 17946 22619 6456 8501 12437 17927 22945 8957 11385 15768 22369 28038 5771 7427 10491 14936 18825 5145 6621 9353 13315 16782 5831 7678 11232 16191 20722 8090 10282 14241 20202 25322 5212 6707 9475 13489 17001 8008 10544 15425 22235 28459 6756 8305 11345 15121 18470 5893 7727 11193 15988 20216 8524 10502 14191 19239 23559 5623 6912 9442 12585 15372 5013 6162 8418 11219 13704 5322 6979 10109 14439 18258 7698 9485 12817 17376 21277 5078 6242 8528 11366 13883 7310 9584 13883 19830 25074 186 176 160 144 131 145 140 133 123 114 158 148 133 121 110 155 147 133 120 109 138 131 118 107 97 131 127 120 111 103 143 134 120 109 99 140 132 120 108 98 179 174 165 152 142 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-35E10K0-C-7X 80 BXRC-35E10K0-D-7X 80 BXRC-35G10K0-B-7X 90 BXRC-35G10K0-C-7X 90 BXRC-35G10K0-D-7X 90 BXRC-35A10K1-B-73 93 BXRC-35A10K1-C-73 93 BXRC-35A10K1-D-73 93 BXRC-40E10K0-B-7X 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 11110 14121 19557 27745 34775 7158 9212 13013 18525 23349 6656 8765 12822 18483 23656 9235 11738 16257 23063 28907 5950 7657 10817 15399 19408 6268 8253 12074 17405 22277 8697 11053 15309 21718 27221 5603 7211 10186 14501 18276 8058 10610 15522 22374 28637 10572 13026 17602 23863 29221 6974 8573 11711 15609 19066 6076 7967 11540 16484 20843 8788 10827 14631 19836 24290 5797 7126 9735 12975 15849 5722 7502 10867 15522 19627 8276 10196 13778 18679 22873 5459 6710 9167 12218 14924 7355 9644 13970 19954 25231 196 184 165 150 137 192 182 165 149 135 149 145 137 127 118 163 153 137 125 114 160 151 137 124 112 140 136 129 119 111 154 144 129 117 107 151 142 129 117 106 180 175 166 153 142 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40E10K0-C-7X 80 BXRC-40E10K0-D-7X 80 BXRC-40G10K0-B-7X 90 BXRC-40G10K0-C-7X 90 BXRC-40G10K0-D-7X 90 BXRC-40H10K0-D-7X 97 BXRC-40A10K1-B-73 93 BXRC-40A10K1-C-73 93 BXRC-40A10K1-D-73 93 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 11179 14209 19680 27918 34993 7202 9269 13094 18641 23494 6907 9094 13304 19178 24546 9582 12179 16868 23930 29994 6173 7945 11223 15978 20138 5299 6819 9633 13714 17285 6705 8829 12917 18619 23831 9303 11824 16377 23233 29120 5994 7714 10896 15513 19552 10638 13107 17712 24012 29404 7018 8626 11785 15707 19185 6304 8266 11974 17103 21626 9118 11235 15181 20581 25203 6015 7394 10101 13463 16444 5163 6346 8670 11555 14114 6121 8026 11625 16605 20997 8853 10907 14739 19982 24469 5840 7179 9807 13071 15966 198 185 166 151 137 194 183 166 150 136 155 150 142 131 122 169 159 142 129 118 166 157 142 128 116 142 135 122 110 100 150 146 138 127 119 164 154 138 126 114 161 152 138 125 113 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50C10K1-B-7x 70 BXRC-50C10K1-C-7x 70 BXRC-50C10K1-D-7x 70 BXRC-50E10K1-B-7x 80 BXRC-50E10K1-C-7x 80 BXRC-50E10K1-D-7x 80 BXRC-50G10K1-B-7x 90 BXRC-50G10K1-C-7x 90 BXRC-50G10K1-D-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 8858 11664 17064 24598 31482 12290 15621 21635 30693 38470 7918 10190 14395 20494 25829 8308 10939 16004 23069 29526 11527 14650 20291 28785 36079 7426 9557 13501 19220 24224 7057 9292 13594 19595 25079 9791 12444 17235 24450 30646 6308 8118 11467 16326 20576 8086 10603 15358 21937 27738 11695 14409 19472 26398 32326 7715 9484 12956 17268 21092 7584 9944 14403 20573 26014 10969 13514 18262 24757 30317 7236 8894 12151 16195 19781 6442 8446 12234 17475 22097 9317 11479 15512 21029 25751 6146 7555 10321 13756 16802 198 193 182 168 157 217 204 182 166 151 213 201 182 165 149 186 181 171 158 147 204 191 171 156 142 200 189 171 155 140 158 153 145 134 125 173 162 145 132 120 170 160 145 131 119 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-56G10K0-B-7x 90 BXRC-56G10K0-C-7x 90 BXRC-56G10Kx-D-7x 90 BXRC-56H10K0-D-74 97 BXRC-57C10K1-B-7x 70 BXRC-57C10K1-C-7x 70 BXRC-57C10K1-D-7x 70 BXRC-57E10K1-B-7x 80 BXRC-57E10K1-C-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 7407 9753 14268 20568 26324 10277 13062 18091 25664 32167 6621 8521 12037 17136 21597 5726 7369 10410 14820 18679 8558 11269 16486 23764 30415 11874 15092 20902 29652 37166 7650 9845 13907 19799 24954 8212 10812 15818 22802 29184 11393 14481 20056 28452 35662 6761 8866 12842 18343 23194 9779 12049 16282 22073 27029 6451 7930 10833 14439 17636 5579 6858 9369 12487 15253 7812 10243 14837 21193 26798 11299 13921 18812 25503 31230 7454 9162 12517 16682 20377 7496 9829 14237 20335 25713 10842 13357 18050 24471 29966 166 161 152 141 131 182 170 152 139 126 178 168 152 138 125 154 146 132 119 108 192 186 176 163 151 210 197 176 160 146 206 194 176 159 144 184 179 169 156 145 201 189 169 154 140 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57E10K1-D-7x 80 BXRC-65C10K1-B-7x 70 BXRC-65C10K1-C-7x 70 BXRC-65C10K1-D-7x 70 BXRC-65E10K1-B-7x 80 BXRC-65E10K1-C-7x 80 BXRC-65E10K1-D-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 900 1200 1800 2700 3600 855 1140 1710 2565 3420 1050 1400 2100 3150 4200 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 49.6 50.5 52.0 54.1 55.8 66.2 67.3 69.4 72.1 74.4 35.4 36.2 37.6 39.5 41.2 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 44.7 60.6 93.6 146.1 201.0 56.6 76.7 118.7 185.0 254.6 37.2 50.6 79.0 124.4 172.9 7340 9446 13344 18998 23944 8708 11466 16775 24181 30949 12082 15356 21269 30172 37818 7784 10018 14151 20146 25392 8357 11004 16099 23207 29702 11595 14738 20412 28957 36295 7470 9614 13581 19335 24369 7152 8791 12010 16007 19552 7949 10423 15097 21565 27268 11497 14165 19142 25951 31778 7584 9323 12736 16975 20734 7629 10003 14489 20696 26170 11034 13595 18371 24905 30498 7279 8947 12223 16291 19899 197 187 169 153 138 195 189 179 166 154 214 200 179 163 149 209 198 179 162 147 187 182 172 159 148 205 192 172 157 143 201 190 172 155 141 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx10Kx-B-7x BXRC-xxx10Kx-C-7x BXRC-xxx10Kx-D-7x Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.06 46.1 57.5 -24.9 0.07 49.7 61.6 74.6 -33.2 0.04 61.5 76.8 74.4 80.0 -33.2 0.05 66.2 82.2 34.8 37.6 40.4 -17.4 0.06 33.4 41.6 38.1 41.2 44.3 -17.4 0.07 36.7 45.4 Minimum Typical Maximum 1800 48.1 52.0 55.9 -24.9 3600 51.7 55.8 60.0 1710 64.2 69.4 3420 68.8 2100 4200 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 16 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRC-xxx10Kx-B-7x BXRC-xxx10Kx-C-7x BXRC-xxx10Kx-D-7x CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 6500K4 1800 RG1 RG1 RG1 RG1 2700 RG1 RG1 RG2 RG2 3600 RG1 RG1 RG2 RG2 1710 RG1 RG1 RG1 RG2 2565 RG1 RG1 RG2 RG2 3420 RG1 RG2 RG2 RG2 2100 RG1 RG1 RG1 RG1 3150 RG1 RG1 RG1 RG2 4200 RG1 RG1 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux Vero Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed . 17 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 125°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRC-xxx10Kx-B-7x BXRC-xxx10Kx-C-7x BXRC-xxx10Kx-D-7x Maximum Drive Current3 3600mA 3420mA 4200mA Maximum Peak Pulsed Drive Current4,5 5140mA 4890mA 6000mA Maximum Reverse Voltage6 -90V -120V -65V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN31: Assembly Considerations for Bridgelux Vero LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Per IEC 62031, LED Modules for General Lighting - Safety Specifications, the maximum allowable current when using the Molex Pico Connector is 3150mA. 5. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 6. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 18 Performance Curves Figure 2: Vero 29C Drive Current vs. Voltage 4000 4000 3500 3500 3000 3000 Forward Current (mA) Forward Current (mA) Figure 1: Vero 29B Drive Current vs. Voltage 2500 2000 1500 1000 2500 2000 1500 1000 500 0 500 47 48 49 50 51 52 53 54 55 56 57 0 58 63 64 65 66 67 68 Forward Voltage (V) Figure 3: Vero 29D Drive Current vs. Voltage 71 72 73 74 75 76 200% 180% 4000 160% Relative Luminous Flux 3500 Forward Current (mA) 70 Figure 4: Vero 29B Typical Relative Flux vs. Current 4500 3000 2500 2000 1500 1000 140% 120% 100% 80% 60% 40% 500 0 69 Forward Voltage (V) 20% 33 34 35 36 37 38 39 40 41 42 0% 0 Forward Voltage (V) 500 1000 1500 2000 2500 3000 3500 4000 Forward Current (mA) Figure 6: Vero 29D Typical Relative Flux vs. Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux Figure 5: Vero 29C Typical Relative Flux vs. Current 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0 400 800 1200 1600 2000 2400 Forward Current (mA) 2800 3200 3600 4000 0% 0 500 1000 1500 2000 2500 3000 3500 4000 4500 Forward Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 19 Performance Curves Figure 8: Typical DC ccy Shift vs. Case Temperature Figure 7: Typical DC Flux vs. Case Temperature 0 103% Neutral White 50 75 100 125 0.000 Cool White 25°C Pulsed 97% -0.003 ccy Shift Relative Luminous Flux 100% 25 0.003 Warm White 94% 91% -0.006 -0.009 88% Warm White -0.012 85% -0.015 82% 0 25 50 75 100 Neutral White Cool White 25°C Pulsed 125 Case Temperature (°C) Case Temperature (°C) Figure 10: 2000K, 65 CRI Color Shift vs. Case Temperature Figure 9: Typical DC ccx Shift vs. Case Temperature 0.4101 0 25 50 75 100 0.41 125 0.4099 0.000 0.4098 -0.002 Pulsed Center Point Tc=25°C 15°C 25°C 0.4097 ccy ccx Shift -0.004 -0.006 65°C 0.4093 Warm White -0.012 0.4095 0.4094 -0.008 -0.010 45°C 0.4096 Neutral White 85°C 0.4092 Cool White 25°C Pulsed 105°C 0.4091 Case Temperature (°C) 0.409 0.525 0.526 0.527 0.528 0.529 0.53 0.531 0.532 ccx Notes for Figures 7 - 9: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 20 Performance Curves Figure 11: 1750K Color Shift vs. Case Temperature1 Figure 12: 2500K Color Shift vs. Case Temperature1 0.3705 0.4145 Pulsed Center Point Tc = 25°C 15°C 0.37 15°C 0.414 25°C 0.4135 25°C 0.413 0.3695 0.369 ccy ccy 45°C 85°C 0.411 105°C 0.5198 0.52 70°C 85°C 0.4115 0.3685 0.368 0.5196 45°C 0.4125 0.412 70°C 0.5202 0.5204 105°C 0.4105 0.468 0.5206 0.47 0.472 0.474 0.369 15°C 0.342 0.34 0.367 0.332 70°C 0.33 0.365 0.364 70°C 0.363 85°C 0.328 Pulsed Center Point Tc=25°C 45°C 45°C 0.334 ccy ccy 25°C 0.366 0.336 0.326 0.368 Pulsed Center Point Tc = 25°C 25°C 0.338 0.478 Figure 14: 3000K, Class A Color Shift vs. Case Temperature1 0.344 15°C 0.476 ccx ccx Figure 13: 5600K Color Shift vs. Case Temperature1,3 Pulsed Center Point Tc = 25°C 85°C 0.362 105°C 0.361 0.324 0.322 0.32 0.322 0.324 0.326 0.328 105°C 0.36 0.416 0.33 0.4165 0.417 ccx Figure 15: 3500K, Class A Color Shift vs. Case Temperature1 ccx 0.4175 0.418 0.4185 Figure 16: 4000K, Class A Color Shift vs. Case Temperature1 0.37 0.3760 15°C 0.368 Pulsed Center Point Tc=25°C 25°C 0.366 15°C 0.3740 25°C 0.3720 45°C 45°C ccy 0.3700 ccy Pulsed Center Point Tc=25°C 0.364 0.3680 70°C 0.362 85°C 0.36 85°C 0.3640 105°C 0.358 0.392 70°C 0.3660 105°C 0.393 0.394 0.395 0.396 0.397 ccx 0.3620 0.373 0.374 0.375 0.376 ccx 0.377 0.378 0.379 Note for Figures 10-16: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Color shift shown for product hot targeted at Tc=85°C 21 Performance Curves Figure 17: Vero 29D Drive Current Derating Curve 4400 Drive Current (mA) 4200 4000 3960 3800 3600 3400 Max Drive Current LM-80 Max Drive Current 3200 0 10 20 30 40 50 60 70 80 90 100 110 Case Temperature (⁰C) Notes for Figure 17: 1. The maximum allowable drive current for the Vero 29D product is dependent on the operating case temperature. Please refer to the Product Feature Map (page 2) for the location of the Tc Point 2. LM-80 Max Drive Current must not be exceeded in order to meet LM-80 lifetime projections. 3. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these products. Contact your Bridgelux sales representative for LM-80 report. 22 Typical Radiation Pattern Figure 18: Typical Spatial Radiation Pattern Note for Figure 18: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 19: Typical Polar Radiation Pattern 23 Typical Color Spectrum Figure 20: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 20: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 21: Typical Color Spectrum for Vero 29 with Décor Series 1 17E 20B 0.9 25E 27H Relative Spectral Power Distribution 0.8 30H 56G 0.7 56H 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 21: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 24 Mechanical Dimensions Figure 22: Drawing for Vero 29 LED Array Notes for Figure 22: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ± 0.10mm. 4. Mounting holes (4X) are for M3 screws. 5. Bridgelux recommends four tapped holes for mounting screws with 43.0 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. Solder pads and connector port are labeled “+” and “-“ to denote positive and negative, respectively. 8. It is not necessary to provide electrical connections to both the solder pads and the connector port. Either set may be used depending on application specific design requirements. 9. Refer to Application Notes AN30 and AN31 for product handling, mounting and heat sink recommendations. 10. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 11. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 25 Color Binning Information Figure 23: Graph of Warm and Neutral White Test Bins in xy Color Space 0.44 2500K 4SDCM 3 SDCM 4 SDCM 2000K 3SDCM 2700K 0.42 3000K 3500K 0.4 Y 4000K 1750K 4SDCM 0.38 0.36 0.34 0.36 0.39 0.42 0.45 X 0.48 0.51 0.54 Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 1750K 2000K 2500K 2700K ANSI Bin (for reference only) - - - (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) - - - (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) - - - (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.5167, 0.336) (0.5280, 0.4100) (0.4765, 0.4137) (0.4578, 0.4101) 3000K1 (0.4338, 0.403) 3500K1 4000K1 (0.4073, 0.3917) (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Decor Series Class A products. Please contact your Bridgelux Sales Representative for more information. Figure 24: Graph of Cool White Test Bins in xy Color Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5600K1 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5310K - 6020K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5475K - 5830K) (5829K - 5481K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3293, 0.3423) (0.3287, 0.3417) (0.3123, 0.3282) Note for Table 9: 1. Select configurations with a CCT of 5600K are available with center point targets at Tc = 85°C or Tc = 25°C. 26 Packaging and Labeling Figure 25: Drawing for Vero 29 Packaging Tray Notes for Figure 25: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 27 Packaging and Labeling Figure 26: Vero Series Packaging and Labeling Notes for Figure 26: 1. Each tray holds 50 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 27: Gen. 7 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E10K0C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 28 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 29 About Bridgelux: We Build Light That Transforms At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 Tel (925) 583-8400 www.bridgelux.com © 2016-2018 Bridgelux, Inc. All rights reserved 2018. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 7 Vero 29 Array Series Product Data Sheet DS93 Rev. M (04/2018) 30
BXRC-20B10K1-D-73
物料型号:文档中提到了多种型号,例如BXRC-17E10KO-B-74、BXRC-20B10K1-C-73等,这些型号属于Bridgelux的Vero系列LED阵列。
器件简介:Vero系列是芯片级封装(COB)光源技术和创新的重大进步,简化了灯具设计和制造过程。Vero COB LED阵列提供四种不同的配置,以适应广泛的电流范围,提供灵活性和可靠性。
引脚分配:文档中提到了阵列的电气特性和引脚分配,例如正负极标记,以及板上连接器端口,但未提供具体的引脚分配图。
参数特性:Vero系列产品的参数特性包括160 lm/W的典型效率,从3850到38400流明的光输出范围,以及从1750K到6500K的色温选项。CRI选项包括65、70、80和90,以及2和3 SDCM的色控制。
功能详解:Vero系列产品具有多种功能,如热隔离焊盘、板上连接器端口、正面部件编号标记、背面Vf二进制代码标记等。
应用信息:Vero系列产品适用于室内和室外照明的广泛应用,提供高质量的真实色彩再现、统一一致的白光、设计优化的灵活性、简易的使用和组装、无需焊接的连接能力,以及库存管理和质量控制的改进。
封装信息:文档提供了Vero 29 LED阵列的机械尺寸图和封装信息,包括阵列的尺寸、安装孔的位置和尺寸,以及包装和标签的详细信息。
BXRC-20B10K1-D-73 价格&库存
很抱歉,暂时无法提供与“BXRC-20B10K1-D-73”相匹配的价格&库存,您可以联系我们找货
BXRC-20B10K1-D-73
    • 1+411.79320
    • 200+164.31120
    • 500+158.82480
    • 1000+156.10320
