PLCC4 SMD Top View Package LED
SMTL4-SRGY, RED/GREEN/YELLOW
SMTL4-SRGY
Industry Standard PLCC4 Footprint
3 Super Bright Chips in One Low Profile Package
High Luminous Intensity
Wide Viewing Angle
High Power Efficiency
Bivar SMTL4 Super Bright Tri-Color LED combines three chips in a single package and is offered in an industry standard PLCC4 footprint. The SMTL4 LED has a water clear lens for high luminous intensity and
wide viewing angle making them ideal for outdoor illumination applications where higher ambient lighting
conditions exist. The flexible three chip design allows for a wide variety of lighting options where the chips
can be individually driven or mixed to create different color combinations. The robust package is ideal for
harsh working environments and can be clustered in LED arrays for high luminous applications. Low power
consumption and excellent long life reliability are suitable for battery powered equipment. Bivar SMTL4 LED
is packaged in standard tape and reels for pick and place assemblies.
Part Number
Material
Emitted Color
Lumen Typ. mcd
AlGaInP
Red
180
InGaN
Green
1450
AlGaInP
Yellow
180
SMTL4-SRGY
Lens Color
Viewing Angle
Water Clear
120°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 4
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision B 09/16
Page 1 of 5
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
Red, Yellow - 78 mW
Green - 78 mW
Continuous Forward Current
Red, Yellow - 30 mA
Green - 30 mA
Peak Forward Current 1
100 mA
Reverse Voltage
5V
Electrostatic Discharge Classification (HBM)
2000 V
Derating Linear From 25°C
0.4 mA/°C
Operating Temperature Range
-40 ~ +85°C
Storage Temperature Range
-40 ~ +100°C
Soldering Temperature2
260°C
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2. Solder time less than 5 seconds at temperature extreme.
Electrical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Emitting
Color
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
Reverse
Current (µA)
VR=5V
Dominant
Wavelength (nm)2
Luminous
Intensity (mcd)3
TYP
MAX
TYP
MAX
TYP
MIN
TYP
Red
1.9
2.6
625
115
180
Green
3.3
4.5
525
1050
1450
Yellow
1.9
2.4
591
115
180
Viewing
Angle
2 Ө ½ (deg)
TYP
120
Notes: 1. Tolerance of Forward Voltage : ±0.05V.
2. Tolerance of Dominant Wavelength : ±0.1nm.
3. Tolerance of Luminous Intensity : ±15%.
Directivity Radiation
Radiation Diagram
Revision B 09/16
Page 2 of 5
Typical Electrical / Optical Characteristics Curves
Yellow
Green
Red
Red, Green, Yellow
Green
Red, Yellow
Red
Yellow
Green
Revision B 09/16
Page 3 of 5
Recommended Soldering Conditions
Tape and Reel Dimensions
Note: 2000 pcs/Reel
Revision B 09/16
Page 4 of 5
0.63 [16.0mm]
Packaging and Labeling Plan
Note: 1 Reel / Bag
Sealed ESD and Moisture Barrier Bag
Internal Quality Control Label
X.XXX
Humidity Indicator Card
Desiccant
X.XXX
Bivar Standard Packaging Label
Revision B 09/16
Page 5 of 5
很抱歉,暂时无法提供与“SMTL4-SRGY”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+23.649671+3.04337
- 10+17.1053610+2.20121
- 100+13.20640100+1.69947
- 500+11.49306500+1.47899
- 1000+10.934531000+1.40712
