Bridgelux Vero SE 10 Array
Product Data Sheet DS120
1
Vero SE
Introduction
Vero® SE Series is a revolutionary light source system that integrates Bridgelux’s seventh generation COB technology with
poke-in connectivity enabling solder-free installation. Vero SE LED light sources streamline assembly processes, lower
manufacturing cost, simplify luminaire design, improve light quality and increase design flexibility.
Vero SE is available in four different light emitting surface (LES) configurations that operate reliably over a broad current
range. With Vero SE, secondary connector and holder components are not required, allowing for rapid integration of arrays
into fixtures and an efficient field replaceable solution. Vero SE arrays deliver increased lumen density for improved beam
control and precision lighting with 2 and 3 SDCM color control standards for clean and consistent uniform lighting.
Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched
LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor
Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD.
Décor Series™ Class A is based on human response testing, providing color points with a combined GAI and CRI metric.
Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 93, which emphasizes the reds and color
tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums.
Décor Series Ultra is also a good replacement for halogen lamps.
Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps.
Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white
light with enhanced spectrum coverage and higher efficacy.
Features
• Poke-in connectivity
• Efficacy of 150 lm/W typical
• Broad range of CCT options from 2700K to 6500K
• CRI options: minimum 65, 70, 80, and 90
Benefits
• Poke-in connectivity enables solderless, connector
free installation
• Broad application coverage for interior and exterior
lighting
• Color control: 2 and 3 SDCM for 2700K-4000K CCT
• Flexibility for application driven lighting design
requirements
• Reliable operation at up to 2X nominal drive current
• High quality, true color reproduction
• Radial die pattern and improved lumen density
• Uniform consistent white light
• Top side part number markings
• Flexibility in design optimization
• No exposed solder pads or electrical connections
• Enhanced ease of use and assembly
• Vf bin code backside marking
• Ability to configure multiple Vero SE arrays in series
and parallel reduces customer driver cost
• Improved inventory management and quality control
Contents
Product Feature Map
2
Product Nomenclature
2
Product Selection Guide
3
Performance at Commonly Used Drive Currents
10
Electrical Characteristics
19
Eye Safety
Absolute Maximum Ratings
21
Performance Curves
22
Typical Radiation Pattern
25
Typical Color Spectrum
26
Mechanical Dimensions
27
Color Binning Information
28
Packaging and Labeling
29
Design Resources
31
Precautions
31
Disclaimers
31
About Bridgelux
32
1
Product Feature Map
Vero SE 10 is the smallest form factor in the product
family of next generation solid state light sources.
In addition to delivering the performance and light
quality required for many lighting applications,
Vero SE incorporates several features to simplify the
design integration and manufacturing process, accelerate
time to market and reduce system costs. Please visit www.
bridgelux.com for more information on the Vero SE family
of products.
2D Bar code provides full
manufacturing traceability
Polarity indication marks simplify
manufacturing operator instructions
Wire release mechanisms (x4)
Tc Measurement point
Mounting holes
Optic mounting holes
Radial die configuration improves lumen
density and beam control
Top side part number marking improves
inventory management and outgoing
quality control
Test ports for probing
Dual poke-in connectivity
The part number designation for Bridgelux Vero SE LED arrays is explained as follows:
1 2 3 4
5 6 7 8 9 10 11
– 12
– 13 14
– 15 16
BXRC – 30 E 100 0 – C – 7 3 – SE
Product Family
Nominal CCT
20 = 2,000K
27 = 2,700K
30 = 3,000K
35 = 3,500K
40 = 4,000K
50 = 5,000K
57 = 5,700K
65 = 6,500K
Special Edition
CCT Bin Options
Gen. 7
Array Configuration
CRI
B = 65 CRI min.
C = 70 CRI min.
E = 80 CRI min.
G = 90 CRI min.
H = 97 CRI typ.
A = Class A
2 = 2 SDCM
3 = 3 SDCM
4 = 4 SDCM
Color Targeting Designator
0 = Cold Targeted
1 = Hot Targeted
C = Decor Series Showcase
Flux Indicator
100x = 1000 lm
2
The following product configurations are available:
Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C)
Part Number
Nominal
CCT1
(K)
CRI2
Nominal Drive
Current3
(mA)
Typical Pulsed
Flux4,5,6
Tc = 25ºC
(lm)
Minimum
Pulsed Flux6,7
Tc = 25ºC
(lm)
Typical Vf
(V)
Typical
Power
(W)
Typical
Efficacy
(lm/W)
141
BXRC-20B1001-B-73-SE
2000
65
270
1325
1166
34.8
9.4
BXRC-20B1001-D-73-SE
2000
65
350
1283
1129
26.0
9.1
141
BXRC-27E1000-B-7x-SE
2700
80
270
1353
1191
34.8
9.4
144
BXRC-27E1000-C-7x-SE
2700
80
360
1804
1588
34.8
12.5
144
BXRC-27E1000-D-7x-SE
2700
80
350
1310
1153
26.0
9.1
144
BXRC-27G10H0-B-7x-SE
2700
90
270
1165
1025
34.8
9.4
124
124
BXRC-27G10H0-C-7x-SE
2700
90
360
1553
1367
34.8
12.5
BXRC-27G10H0-D-7x-SE
2700
90
350
1128
993
26.0
9.1
124
BXRC-27G1000-B-7x-SE
2700
90
270
1128
992
34.8
9.4
120
120
BXRC-27G1000-C-7x-SE
2700
90
360
1503
1323
34.8
12.5
BXRC-27G1000-D-7x-SE
2700
90
350
1092
961
26.0
9.1
120
BXRC-27H1000-B-7x-SE
2700
97
270
977
860
34.8
9.4
104
104
BXRC-27H1000-C-7x-SE
2700
97
360
1303
1147
34.8
12.5
BXRC-27H1000-D-7x-SE
2700
97
350
946
833
26.0
9.1
104
BXRC-30C1001-B-74-SE
3000
70
270
1550
1364
34.8
9.4
165
165
BXRC-30C1001-C-74-SE
3000
70
360
2067
1819
34.8
12.5
BXRC-30C1001-D-74-SE
3000
70
350
1502
1321
26.0
9.1
165
BXRC-30E1000-B-7x-SE
3000
80
270
1409
1240
34.8
9.4
150
BXRC-30E1000-C-7x-SE
3000
80
360
1879
1654
34.8
12.5
150
BXRC-30E1000-D-7x-SE
3000
80
350
1365
1201
26.0
9.1
150
BXRC-30G10H0-B-7x-SE
3000
90
270
1221
1075
34.8
9.4
130
BXRC-30G10H0-C-7x-SE
3000
90
360
1629
1433
34.8
12.5
130
BXRC-30G10H0-D-7x-SE
3000
90
350
1183
1041
26.0
9.1
130
BXRC-30G1000-B-7x-SE
3000
90
270
1175
1034
34.8
9.4
125
BXRC-30G1000-C-7x-SE
3000
90
360
1566
1378
34.8
12.5
125
BXRC-30G1000-D-7x-SE
3000
90
350
1138
1001
26.0
9.1
125
BXRC-30G100C-B-73-SE
3000
90
270
1090
959
34.8
9.4
116
BXRC-30G100C-D-73-SE
3000
90
350
1056
929
26.0
9.1
116
BXRC-30H1000-B-7x-SE
3000
97
270
1052
926
34.8
9.4
112
BXRC-30H1000-C-7x-SE
3000
97
360
1403
1235
34.8
12.5
112
BXRC-30H1000-D-7x-SE
3000
97
350
1019
897
26.0
9.1
112
BXRC-30A1001-B-73-SE8,9
3000
93
270
1062
934
34.8
9.4
113
BXRC-30A1001-C-73-SE8,9
3000
93
360
1416
1246
34.8
12.5
113
BXRC-30A1001-D-73-SE8,9
3000
93
350
1028
905
26.0
9.1
113
Notes for Table 1:
1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C.
2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products
is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values.
3. Drive current is referred to as nominal drive current.
4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C.
5. Typical performance values are provided as a reference only and are not a guarantee of performance.
6. Bridgelux maintains a ±7% tolerance on flux measurements.
7. Minimum flux values at the nominal test current are guaranteed by 100% test.
8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line.
9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may
vary depending on fixture design and performance.
3
Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued)
Part Number
Nominal
CCT1
(K)
CRI
2
Nominal Drive
Current3
(mA)
Typical Pulsed
Flux4,5,6
Tc = 25ºC
(lm)
Minimum
Pulsed Flux6,7
Tc = 25ºC
(lm)
Typical Vf
(V)
Typical
Power
(W)
Typical
Efficacy
(lm/W)
BXRC-35E1000-B-7x-SE
3500
80
270
1456
1282
34.8
9.4
155
BXRC-35E1000-C-7x-SE
3500
80
360
1942
1709
34.8
12.5
155
BXRC-35E1000-D-7x-SE
3500
80
350
1411
1241
26.0
9.1
155
BXRC-35G1000-B-7x-SE
3500
90
270
1212
1067
34.8
9.4
129
BXRC-35G1000-C-7x-SE
3500
90
360
1616
1422
34.8
12.5
129
BXRC-35G1000-D-7x-SE
3500
90
350
1174
1033
26.0
9.1
129
BXRC-35A1001-B-73-SE8,9
3500
93
270
1146
1009
34.8
9.4
122
BXRC-35A1001-C-73-SE8,9
3500
93
360
1528
1345
34.8
12.5
122
BXRC-35A1001-D-73-SE8,9
3500
93
350
1110
977
26.0
9.1
122
BXRC-40C1001-B-74-SE
4000
70
270
1579
1389
34.8
9.4
168
BXRC-40C1001-C-74-SE
4000
70
360
2105
1852
34.8
12.5
168
BXRC-40C1001-D-74-SE
4000
70
350
1529
1345
26.0
9.1
168
BXRC-40E1000-B-7x-SE
4000
80
270
1466
1290
34.8
9.4
156
BXRC-40E1000-C-7x-SE
4000
80
360
1954
1720
34.8
12.5
156
BXRC-40E1000-D-7x-SE
4000
80
350
1420
1249
26.0
9.1
156
BXRC-40G1000-B-7x-SE
4000
90
270
1259
1108
34.8
9.4
134
BXRC-40G1000-C-7x-SE
4000
90
360
1679
1477
34.8
12.5
134
BXRC-40G1000-D-7x-SE
4000
90
350
1219
1073
26.0
9.1
134
BXRC-40H1000-B-7x-SE
4000
97
270
1081
951
34.8
9.4
115
BXRC-40H1000-C-7x-SE
4000
97
360
1441
1268
34.8
12.5
115
BXRC-40H1000-D-7x-SE
4000
97
350
1047
921
26.0
9.1
115
BXRC-40A1001-B-73-SE
8,9
4000
93
270
1212
1067
34.8
9.4
129
BXRC-40A1001-C-73-SE8,9
4000
93
360
1616
1422
34.8
12.5
129
BXRC-40A1001-D-73-SE8,9
4000
93
350
1174
1033
26.0
9.1
129
BXRC-50C1001-B-7x-SE
5000
70
270
1607
1414
34.8
9.4
171
BXRC-50C1001-C-7x-SE
5000
70
360
2142
1885
34.8
12.5
171
BXRC-50C1001-D-7x-SE
5000
70
350
1556
1369
26.0
9.1
171
BXRC-50E1001-B-7x-SE
5000
80
270
1513
1331
34.8
9.4
161
161
BXRC-50E1001-C-7x-SE
5000
80
360
2017
1775
34.8
12.5
BXRC-50E1001-D-7x-SE
5000
80
350
1465
1289
26.0
9.1
161
BXRC-50G1001-B-7x-SE
5000
90
270
1278
1125
34.8
9.4
136
BXRC-50G1001-C-7x-SE
5000
90
360
1704
1499
34.8
12.5
136
BXRC-50G1001-D-7x-SE
5000
90
350
1238
1089
26.0
9.1
136
Notes for Table 1:
products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values.
4
Part Number
Nominal
CCT1
(K)
CRI
2
Nominal Drive
Current3
(mA)
Typical Pulsed
Flux4,5,6
Tc = 25ºC
(lm)
Minimum
Pulsed Flux6,7
Tc = 25ºC
(lm)
Typical Vf
(V)
Typical
Power
(W)
Typical
Efficacy
(lm/W)
BXRC-57C1001-B-7x-SE
5700
70
270
1550
1364
34.8
9.4
165
BXRC-57C1001-C-7x-SE
5700
70
360
2067
1819
34.8
12.5
165
BXRC-57C1001-D-7x-SE
5700
70
350
1502
1321
26.0
9.1
165
BXRC-57E1001-B-7x-SE
5700
80
270
1494
1315
34.8
9.4
159
BXRC-57E1001-C-7x-SE
5700
80
360
1992
1753
34.8
12.5
159
BXRC-57E1001-D-7x-SE
5700
80
350
1447
1273
26.0
9.1
159
BXRC-65C1001-B-7x-SE
6500
70
270
1579
1389
34.8
9.4
168
BXRC-65C1001-C-7x-SE
6500
70
360
2105
1852
34.8
12.5
168
BXRC-65C1001-D-7x-SE
6500
70
350
1529
1345
26.0
9.1
168
BXRC-65E1001-B-7x-SE
6500
80
270
1522
1339
34.8
9.4
162
BXRC-65E1001-C-7x-SE
6500
80
360
2030
1786
34.8
12.5
162
BXRC-65E1001-D-7x-SE
6500
80
350
1474
1297
26.0
9.1
162
Notes for Table 1:
5
Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8
Part Number
Nominal
CCT1
(K)
GAI2
CRI3
Nominal
Drive
Current4
(mA)
Typical DC
Flux5,6
Tc = 70ºC
(lm)
Minimum DC
Flux6,9
Tc = 70ºC
(lm)
Typical Vf
(V)
Typical
Power
(W)
Typical
Efficacy
(lm/W)
BXRC-30A1001-B-73
3000
80
93
270
987
869
34.3
9.3
107
BXRC-30A1001-C-73
3000
80
93
360
1317
1159
34.3
12.3
107
BXRC-30A1001-D-73
3000
80
93
350
956
842
25.5
8.9
107
BXRC-35A1001-B-73
3500
80
93
270
1066
938
34.3
9.3
115
BXRC-35A1001-C-73
3500
80
93
360
1421
1251
34.3
12.3
115
BXRC-35A1001-D-73
3500
80
93
350
1032
909
25.5
8.9
116
BXRC-40A1001-B-73
4000
80
93
270
1127
992
34.3
9.3
122
BXRC-40A1001-C-73
4000
80
93
360
1503
1323
34.3
12.3
122
BXRC-40A1001-D-73
4000
80
93
350
1092
961
25.5
8.9
122
Notes for Table 2:
1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line.
2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on
3. CRI Values are specified as typical.
4. Drive current is referred to as nominal drive current.
7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance.
8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material
and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the
luminaire and/or the exposed environment to which the product is subjected.
9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test
setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected.
6
Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5
Part Number
Nominal CCT1
(K)
CRI2
Nominal Drive
Current3
(mA)
Typical DC
Flux4,5
Tc = 85ºC
(lm)
Minimum DC
Flux6
Tc = 85ºC
(lm)
Typical Vf
(V)
Typical
Power
(W)
Typical
Efficacy
(lm/W)
2000
65
270
1192
1049
33.8
9.1
131
2000
65
350
1155
1016
25.3
8.9
130
2700
80
270
1218
1072
33.8
9.1
133
2700
80
360
1624
1429
33.8
12.2
133
2700
80
350
1179
1038
25.3
8.9
133
2700
90
270
1049
923
33.8
9.1
115
2700
90
360
1398
1230
33.8
12.2
115
2700
90
350
1016
894
25.3
8.9
115
2700
90
270
1015
893
33.8
9.1
111
2700
90
360
1353
1191
33.8
12.2
111
2700
90
350
983
865
25.3
8.9
111
2700
97
270
879
774
33.8
9.1
96
2700
97
360
1173
1032
33.8
12.2
96
2700
97
350
852
750
25.3
8.9
96
3000
70
270
1395
1228
33.8
9.1
153
153
3000
70
360
1860
1637
33.8
12.2
3000
70
350
1351
1189
25.3
8.9
153
3000
80
270
1268
1116
33.8
9.1
139
139
3000
80
360
1691
1488
33.8
12.2
3000
80
350
1229
1081
25.3
8.9
139
3000
90
270
1099
967
33.8
9.1
120
3000
90
360
1466
1290
33.8
12.2
120
3000
90
350
1065
937
25.3
8.9
120
3000
90
270
1057
930
33.8
9.1
116
3000
90
360
1409
1240
33.8
12.2
116
3000
90
350
1024
901
25.3
8.9
116
3000
90
270
981
863
34.0
9.2
107
3000
90
350
950
836
25.3
8.9
107
3000
97
270
947
833
33.8
9.1
104
3000
97
360
1263
1111
33.8
12.2
104
3000
97
350
917
807
25.3
8.9
104
7,8
3000
93
270
956
841
33.8
9.1
105
BXRC-30A1001-C-73-SE7,8
3000
93
360
1274
1121
33.8
12.2
105
BXRC-30A1001-D-73-SE7,8
3000
93
350
925
814
25.3
8.9
105
Notes for Table 3:
2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A
the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values.
4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance.
5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface
material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the
6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux
test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected.
7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line.
8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may
7
Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued)
Part Number
Nominal CCT1
(K)
CRI2
Nominal Drive
Current3
(mA)
Typical DC
Flux4,5
Tc = 85ºC
(lm)
Minimum DC
Flux6
Tc = 85ºC
(lm)
Typical Vf
(V)
Typical
Power
(W)
Typical
Efficacy
(lm/W)
3500
80
270
1311
1153
33.8
9.1
143
3500
80
360
1748
1538
33.8
12.2
143
3500
80
350
1269
1117
25.3
8.9
143
3500
90
270
1091
960
33.8
9.1
119
3500
90
360
1455
1280
33.8
12.2
119
119
3500
90
350
1057
930
25.3
8.9
BXRC-35A1001-B-73-SE7,8
3500
93
270
1032
908
33.8
9.1
113
BXRC-35A1001-C-73-SE7,8
3500
93
360
1376
1211
33.8
12.2
113
BXRC-35A1001-D-73-SE7,8
3500
93
350
999
879
25.3
8.9
113
4000
70
270
1421
1250
33.8
9.1
156
4000
70
360
1894
1667
33.8
12.2
156
4000
70
350
1376
1211
25.3
8.9
155
7,8
4000
80
270
1319
1161
33.8
9.1
144
4000
80
360
1759
1548
33.8
12.2
144
4000
80
350
1278
1124
25.3
8.9
144
4000
90
270
1133
997
33.8
9.1
124
4000
90
360
1511
1330
33.8
12.2
124
4000
90
350
1097
966
25.3
8.9
124
4000
97
270
972
856
33.8
9.1
106
4000
97
360
1297
1141
33.8
12.2
106
4000
97
350
942
829
25.3
8.9
106
BXRC-40A1001-B-73-SE7,8
4000
93
270
1091
960
33.8
9.1
119
BXRC-40A1001-C-73-SE7,8
4000
93
360
1455
1280
33.8
12.2
119
BXRC-40A1001-D-73-SE7,8
4000
93
350
1057
930
25.3
8.9
119
5000
70
270
1446
1273
33.8
9.1
158
5000
70
360
1928
1697
33.8
12.2
158
5000
70
350
1400
1232
25.3
8.9
158
5000
80
270
1361
1198
33.8
9.1
149
5000
80
360
1815
1597
33.8
12.2
149
5000
80
350
1319
1160
25.3
8.9
149
5000
90
270
1150
1012
33.8
9.1
126
5000
90
360
1533
1349
33.8
12.2
126
5000
90
350
1114
980
25.3
8.9
126
Notes for Table 3:
8
Part Number
Nominal CCT1
(K)
CRI2
Nominal Drive
Current3
(mA)
Typical DC
Flux4,5
Tc = 85ºC
(lm)
Minimum DC
Flux6
Tc = 85ºC
(lm)
Typical Vf
(V)
Typical
Power
(W)
Typical
Efficacy
(lm/W)
5700
70
270
1395
1228
33.8
9.1
153
5700
70
360
1860
1637
33.8
12.2
153
5700
70
350
1351
1189
25.3
8.9
153
5700
80
270
1345
1183
33.8
9.1
147
5700
80
360
1793
1578
33.8
12.2
147
5700
80
350
1302
1146
25.3
8.9
147
6500
70
270
1421
1250
33.8
9.1
156
156
6500
70
360
1894
1667
33.8
12.2
6500
70
350
1376
1211
25.3
8.9
155
6500
80
270
1370
1206
33.8
9.1
150
6500
80
360
1827
1607
33.8
12.2
150
6500
80
350
1327
1168
25.3
8.9
150
Notes for Table 3:
9
Vero SE LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero SE may also
be driven at other drive currents dependent on specific application design requirements. The performance at any
drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current
characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4.
Table 4: Product Performance at Commonly Used Drive Currents
Part Number
CRI
65
65
80
80
80
90
90
90
Drive
Current1
(mA)
Typical Vf
Tc = 25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
DC Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
135
180
270
405
540
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
4.5
6.1
9.4
14.7
20.3
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
706
926
1325
1944
2490
685
899
1283
1889
2420
721
945
1353
1985
2543
959
1257
1804
2627
3356
700
918
1310
1929
2471
621
814
1165
1709
2190
826
1082
1553
2262
2890
602
790
1128
1661
2128
634
830
1192
1729
2204
623
808
1155
1629
2038
648
848
1218
1766
2251
856
1116
1624
2282
2872
636
825
1179
1664
2081
558
730
1268
1521
1938
737
961
1691
1965
2473
548
711
1229
1433
1792
158
153
141
132
123
157
152
141
131
122
162
156
144
135
125
161
156
144
134
124
160
155
144
134
124
139
134
124
116
108
139
134
124
116
107
138
134
124
116
107
Notes for Table 4:
1. Alternate drive currents are provided for reference only and are not a guarantee of performance.
2. Bridgelux maintains a ± 7% tolerance on flux measurements.
3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance.
10
Table 4: Product Performance at Commonly Used Drive Currents (Continued)
Part Number
CRI
90
90
90
97
97
97
BXRC-30C1001-B-7x-SE
70
BXRC-30C1001-C-7x-SE
70
BXRC-30C1001-D-7x-SE
70
Drive
Current1
(mA)
Typical Vf
Tc = 25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
DC Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
601
788
1128
1654
2119
799
1047
1503
2189
2796
583
765
1092
1607
2059
521
683
977
1434
1837
693
908
1303
1897
2423
505
663
946
1393
1785
826
1083
1550
2274
2914
1099
1440
2067
3010
3845
802
1052
1502
2210
2832
540
707
1015
1471
1876
713
930
1353
1902
2394
530
688
983
1386
1734
468
612
879
1275
1626
618
806
1173
1648
2075
459
596
852
1201
1503
742
972
1395
2023
2579
981
1279
1860
2615
3291
729
946
1351
1906
2384
135
130
120
113
105
134
130
120
112
104
134
129
120
112
104
117
113
104
98
91
116
112
104
97
90
116
112
104
97
90
185
179
165
155
144
184
178
165
154
142
184
178
165
154
142
Notes for Table 4:
11
Part Number
CRI
80
80
80
90
90
90
90
90
90
Drive
Current1
(mA)
Typical Vf
Tc = 25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
DC Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
751
985
1409
2068
2649
999
1309
1879
2736
3495
729
956
1365
2009
2574
651
853
1221
1792
2296
866
1134
1629
2372
3029
632
829
1183
1741
2231
626
821
1175
1723
2207
833
1091
1566
2280
2913
607
797
1138
1674
2145
675
883
1268
1839
2345
892
1163
1691
2377
2992
663
860
1229
1733
2168
585
766
1099
1594
2032
773
1008
1466
2060
2593
574
745
1065
1502
1879
562
736
1057
1533
1954
743
969
1409
1981
2493
552
716
1024
1444
1806
168
163
150
141
131
168
162
150
140
129
167
162
150
140
129
146
141
130
122
113
145
141
130
121
112
145
140
130
121
112
140
136
125
117
109
140
135
125
117
108
139
135
125
117
108
Notes for Table 4:
12
Part Number
CRI
90
90
97
97
97
BXRC-30A1001-B-73
93
BXRC-30A1001-C-73
93
BXRC-30A1001-D-73
93
80
Drive
Current1
(mA)
Typical Vf
Tc = 25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
DC Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
135
180
270
405
540
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
4.5
6.1
9.4
14.7
20.3
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
581
762
1090
1599
2049
564
739
1056
1554
1991
561
735
1052
1544
1978
746
977
1403
2043
2610
544
714
1019
1500
1922
566
742
1062
1558
1996
753
986
1416
2061
2633
549
720
1028
1514
1939
776
1018
1456
2137
2737
522
683
981
1422
1813
512
665
950
1340
1676
504
660
947
1373
1751
666
868
1263
1775
2234
495
642
917
1294
1618
508
665
956
1386
1766
672
876
1274
1791
2254
499
648
925
1305
1633
697
913
1311
1901
2423
130
126
116
109
101
129
125
116
108
100
126
121
112
105
98
125
121
112
105
97
125
121
112
104
97
127
123
113
106
98
126
122
113
105
98
126
122
113
105
97
174
168
155
146
135
Notes for Table 4:
13
Part Number
CRI
80
80
90
90
90
93
93
93
BXRC-40C1001-B-7x-SE
70
Drive
Current1
(mA)
Typical Vf
Tc = 25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
DC Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
1032
1353
1942
2828
3612
753
988
1411
2076
2660
646
847
1212
1778
2278
859
1126
1616
2353
3006
627
822
1174
1728
2214
611
801
1146
1682
2154
813
1065
1528
2226
2843
593
778
1110
1634
2094
841
1103
1579
2316
2967
921
1202
1748
2456
3092
685
888
1269
1791
2240
580
760
1091
1582
2016
767
1000
1455
2044
2573
570
739
1057
1490
1864
549
718
1032
1496
1907
725
946
1376
1933
2434
539
699
999
1409
1763
756
989
1421
2060
2626
173
168
155
145
134
173
167
155
144
134
145
140
129
121
112
144
139
129
120
111
144
139
129
120
111
137
132
122
115
106
136
132
122
114
105
136
131
122
114
105
188
182
168
158
146
Notes for Table 4:
14
Part Number
CRI
70
70
80
80
80
BXRC-40G1000-B-7X-SE
90
BXRC-40G1000-C-7X-SE
90
BXRC-40G1000-D-7X-SE
90
97
Drive
Current1
(mA)
Typical Vf
Tc = 25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
DC Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
1119
1466
2105
3065
3915
816
1071
1529
2250
2883
781
1024
1466
2150
2755
1039
1361
1954
2846
3635
758
994
1420
2090
2677
671
880
1259
1847
2366
893
1169
1679
2444
3123
651
854
1219
1795
2300
576
755
1081
1585
2031
999
1302
1894
2662
3351
742
963
1376
1941
2428
702
919
1319
1913
2438
927
1209
1759
2472
3112
689
894
1278
1802
2254
603
789
1133
1643
2094
796
1039
1511
2124
2673
592
768
1097
1548
1936
517
677
972
1410
1797
188
182
168
157
145
187
181
168
157
145
175
169
156
147
136
174
169
156
146
135
174
168
156
145
135
150
145
134
126
117
150
145
134
125
116
149
144
134
125
116
129
125
115
108
100
Notes for Table 4:
15
Part Number
CRI
97
97
93
93
93
70
70
70
80
Drive
Current1
(mA)
Typical Vf
Tc = 25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
DC Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
766
1004
1441
2098
2680
559
733
1047
1540
1973
646
847
1212
1778
2278
859
1126
1616
2353
3006
627
822
1174
1728
2214
856
1123
1607
2357
3020
1139
1492
2142
3119
3985
831
1090
1556
2290
2934
806
1057
1513
2219
2843
684
891
1297
1822
2294
508
659
942
1329
1662
580
760
1091
1582
2016
767
1000
1455
2044
2573
570
739
1057
1490
1864
769
1007
1446
2097
2673
1016
1326
1928
2710
3411
755
980
1400
1975
2471
724
948
1361
1974
2516
129
124
115
107
99
128
124
115
107
99
145
140
129
121
112
144
139
129
120
111
144
139
129
120
111
192
185
171
161
149
191
185
171
160
148
190
184
171
159
148
181
175
161
151
140
Notes for Table 4:
16
Part Number
CRI
80
80
90
90
90
70
70
70
80
Drive
Current1
(mA)
Typical Vf
Tc = 25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
DC Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
1072
1405
2017
2937
3752
782
1026
1465
2157
2763
681
893
1278
1875
2402
906
1187
1704
2481
3169
661
867
1238
1822
2334
826
1083
1550
2274
2914
1099
1440
2067
3010
3845
802
1052
1502
2210
2832
796
1044
1494
2192
2808
957
1248
1815
2551
3212
711
923
1319
1860
2327
612
801
1150
1668
2126
808
1054
1533
2155
2713
601
779
1114
1571
1965
742
972
1395
2023
2579
981
1279
1860
2615
3291
729
946
1351
1906
2384
715
936
1345
1950
2485
180
174
161
150
139
179
173
161
150
139
153
147
136
128
118
152
147
136
127
117
151
146
136
127
117
185
179
165
155
144
184
178
165
154
142
184
178
165
154
142
178
172
159
149
138
Notes for Table 4:
17
Part Number
CRI
80
80
70
70
70
80
80
80
Drive
Current1
(mA)
Typical Vf
Tc = 25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
DC Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
135
180
270
405
540
180
240
360
540
720
175
233
350
525
700
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
33.1
33.6
34.8
36.2
37.5
33.1
33.6
34.8
36.2
37.5
24.9
25.4
26.0
27.4
28.4
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
4.5
6.1
9.4
14.7
20.3
6.0
8.1
12.5
19.5
27.0
4.4
5.9
9.1
14.4
19.9
1059
1387
1992
2901
3705
773
1014
1447
2130
2729
841
1103
1579
2316
2967
1119
1466
2105
3065
3915
816
1071
1529
2250
2883
811
1064
1522
2233
2861
1079
1414
2030
2955
3775
787
1033
1474
2170
2780
945
1233
1793
2520
3172
702
911
1302
1837
2298
756
989
1421
2060
2626
999
1302
1894
2662
3351
742
963
1376
1941
2428
729
954
1370
1987
2532
963
1256
1827
2567
3231
716
928
1327
1871
2341
178
172
159
148
137
177
171
159
148
137
188
182
168
158
146
188
182
168
157
145
187
181
168
157
145
182
176
162
152
141
181
175
162
151
140
180
174
162
151
140
Notes for Table 4:
18
Table 5: Electrical Characteristics
Forward Voltage
Pulsed, Tc = 25ºC (V) 1, 2, 3, 8
Part Number
BXRC-xxx100x-B-7x-SE
BXRC-xxx100x-C-7x-SE
BXRC-xxx100x-D-7x-SE
Drive Current
(mA)
Typical
Coefficient
of Forward
Voltage4
∆Vf/∆Tc
(mV/ºC)
Typical
Thermal
Resistance
Junction
to Case5,6
Rj-c (ºC/W)
Driver Selection
Voltages7
(V)
Vf Min.
Hot
Tc = 105ºC
(V)
Vf Max.
Cold
Tc = -40ºC
(V)
0.49
30.9
38.5
-16.1
0.56
33.4
41.4
37.4
-16.1
0.37
30.9
38.5
37.5
40.3
-16.1
0.45
33.4
41.4
24.1
26.0
28.0
-11.8
0.49
23.1
28.7
26.3
28.4
30.5
-11.8
0.57
25.3
31.3
Minimum
Typical
Maximum
270
32.2
34.8
37.4
-16.1
540
34.7
37.5
40.3
360
32.2
34.8
720
34.7
350
700
Notes for Table 5:
1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms.
2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance.
3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements.
4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current.
5. Thermal resistance values are based from test data of a 3000K 80 CRI product.
6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal
interface material used during testing is not included in the thermal resistance value.
7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design
and selection over the operating range of the product.
8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The
working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product
application.
19
Eye Safety
Table 6: Eye Safety Risk Group (RG) Classifications
Part Number
CCT1,5
Drive
Current 5
(mA)
2700K/3000K
4000K2
5000K3
6500K4
270
RG1
RG1
RG1
RG1
405
RG1
RG1
RG1
RG2
540
RG1
RG1
RG2
RG2
360
RG1
RG1
RG1
RG2
540
RG1
RG1
RG2
RG2
720
RG1
RG2
RG2
RG2
350
RG1
RG1
RG1
RG1
525
RG1
RG1
RG1
RG2
700
RG1
RG1
RG2
RG2
Notes for Table 6:
1. Eye safety classification for the use of Bridgelux Vero SE Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC
62471 for the assessment of blue light hazard to light sources and luminaires.
2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx.
3. For products classified as RG2 at 5000K Ethr= 1315.8 lx.
4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx.
5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed.
Table 7: Maximum Ratings
Parameter
Maximum Rating
LED Junction Temperature (Tj)
150°C
Storage Temperature
-40°C to +105°C
Operating Case Temperature1 (Tc)
105°C
Maximum Drive Current3
540mA
720mA
700mA
Maximum Peak Pulsed Drive Current4
770mA
1030mA
1000mA
Maximum Reverse Voltage5
-60V
-60V
-45V
Notes for Table 7:
1. For IEC 62717 requirement, please consult your Bridgelux sales representative.
2. Refer to Bridgelux Application Note AN120: Assembly Considerations for Bridgelux Vero SE LED Arrays.
3. Arrays may be driven at higher currents however lumen maintenance may be reduced.
4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed
current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures.
5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating
provided for reference only.
21
Performance Curves
Figure 1: Vero SE 10B Drive Current vs. Voltage
Figure 2: Vero SE 10C Drive Current vs. Voltage
600
800
700
400
Forward Current (mA)
500
300
200
100
600
500
400
300
200
100
33
34
35
36
37
32
33
34
35
Forward Voltage (V)
Figure 3: Vero SE 10D Drive Current vs. Voltage
180%
160%
600
Relative Luminous Flux
38
200%
700
500
400
300
200
140%
120%
100%
80%
60%
40%
100
20%
24
25
26
27
28
0%
29
200
Forward Voltage (V)
300
400
500
600
Figure 5: Vero 10C SE Typical Relative Flux vs. Current
Figure 6 Vero 10D SE Typical Relative Flux vs. Current
200%
200%
180%
180%
160%
160%
140%
140%
37
Figure 4: Vero 10B SE Typical Relative Flux vs. Current
800
Forward Voltage (V)
120%
100%
80%
60%
120%
100%
80%
60%
40%
40%
20%
20%
0%
0%
200
300
400
500
600
700
800
200
300
400
500
600
700
800
Notes for Figure 1-6:
1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is
recommended for dimming effects.
2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C.
22
Performance Curves
Figure 8: Typical DC ccy Shift vs. Case Temperature
Figure 7: Typical DC Flux vs. Case Temperature
103%
Neutral White
50
75
100
125
0.000
Cool White
25°C Pulsed
97%
-0.003
ccy Shift
100%
25
0.003
Warm White
94%
91%
-0.006
-0.009
88%
Warm White
-0.012
85%
-0.015
82%
50
75
100
Neutral White
Cool White
25°C Pulsed
125
Case Temperature (°C)
Figure 10: 2000K, 65 CRI Color Shift vs. Case Temperature
Figure 9: Typical DC ccx Shift vs. Case Temperature
0.4101
50
75
100
0.41
125
0.000
0.4099
0.4098
-0.002
Pulsed Center
Point Tc=25°C
15°C
25°C
0.4097
ccy
ccx Shift
-0.004
-0.006
65°C
0.4093
Warm White
-0.012
0.4095
0.4094
-0.008
-0.010
45°C
0.4096
Neutral White
85°C
0.4092
Cool White
25°C Pulsed
105°C
0.4091
0.409
0.525
0.526
0.527
0.528
0.529
0.53
0.531
0.532
ccx
Notes for Figures 7 - 9:
1. Characteristics shown for warm white based on 3000K and 80 CRI.
2. Characteristics shown for neutral white based on 4000K and 80 CRI.
3. Characteristics shown for cool white based on 5000K and 70 CRI.
4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information.
23
Performance Curves
Figure 11: 2700K, 97 CRI Color Shift vs. Case Temperature1
Figure 12: 3000K, 97 CRI Color Shift vs. Case Temperature1
0.4110
0.4050
15°C
Pulsed Center
Point
Tc = 25°C
0.4100
25°C
25°C
0.4090
45°C
0.4010
45°C
ccy
ccy
0.4080
Pulsed Center
Point
Tc = 25°C
15°C
0.4030
0.4070
65°C
70°C
0.3990
0.4060
85°C
85°C
0.4050
0.3970
105°C
0.4040
105°C
0.4030
0.457
0.4572
0.4574
0.4576
0.4578
0.3950
0.4323
0.458
0.4328
0.4333
0.4338
ccx
0.369
15°C
Pulsed Center
Point Tc=25°C
25°C
25°C
0.367
0.366
45°C
ccy
ccy
15°C
0.368
0.401
0.399
0.4353
Figure 14: 3000K Class A Color Shift vs. Case Temperature1
0.403
0.4
0.4348
ccx
Figure 13: 3000K, 90 CRI Color Shift vs. Case Temperature1,3
0.402
0.4343
65°C
0.398
45°C
0.365
0.364
70°C
0.363
85°C
0.397
Pulsed
Center Point
Tc=25°C
85°C
0.362
105°C
0.396
0.395
0.444
0.361
0.4445
0.445
0.4455
0.446
0.4465
105°C
0.36
0.416
0.447
0.4165
0.417
ccx
0.4175
0.418
0.4185
ccx
Figure 15: 3500K Class A Color Shift vs. Case Temperature1
Figure 16: 4000K Class A Color Shift vs. Case Temperature1
0.37
0.3760
15°C
0.368
25°C
0.366
Pulsed
Center Point
Tc=25°C
15°C
0.3740
25°C
0.3720
45°C
45°C
ccy
0.3700
ccy
Pulsed
Center Point
Tc=25°C
0.364
0.3680
70°C
0.362
85°C
0.3660
0.36
85°C
0.3640
105°C
0.358
0.392
70°C
105°C
0.393
0.394
0.395
0.396
0.397
ccx
Note for Figures 10-16:
1. Measurements made under DC test conditions at the nominal drive current.
2. Typical color shift is shown with a tolerance of ±0.002.
3. Characteristics shown for Decor Series Showcase products, BXRC-30G100C-x-73-SE
0.3620
0.373
0.374
0.375
0.376
ccx
0.377
0.378
0.379
24
Figure 17: Typical Spatial Radiation Pattern
Note for Figure 17:
1. Typical viewing angle is 120⁰.
2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value.
Figure 18: Typical Polar Radiation Pattern
25
Figure 19: Typical Color Spectrum
110%
3000K
100%
4000K
5000K
Relative Spectral Power Distribution
90%
6500K
80%
70%
60%
50%
40%
30%
20%
10%
0%
400
450
500
550
600
650
700
750
800
Wavelength (nm)
Note for Figure 19:
1. Color spectra measured at nominal current for Tj = Tc = 25°C.
2. Color spectra shown is 3000K and 80 CRI.
3. Color spectra shown is 4000K and 80 CRI.
4. Color spectra shown is 5000K and 70 CRI.
4. Color spectra shown is 6500K and 70 CRI.
Figure 20: Typical Color Spectrum for Vero SE 10 with Décor Series
1
20B
27H
0.9
30G (Décor Series Showcase)
30H
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
450
500
550
600
Wavelength (nm)
650
700
750
800
Note for Figure 20:
26
Figure 21: Drawing for Vero SE 10 LED Array
Notes for Figure 21:
1. Drawings are not to scale.
2. Dimensions are in mm.
3. Unless otherwise specified, tolerances are ± 0.10mm.
4. Mounting holes (2X) are for M3 screws.
5. Bridgelux recommends two tapped holes for mounting screws with 19.0 ± 0.10mm center-to-center spacing.
6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or
raised head screws.
7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm.
8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array.
27
Figure 22: Warm and Neutral White Test Bins in xy Color
Figure 23: Cool White Test Bins in xy Color Space
Space
0.44
0.39
4 SDCM
3 SDCM
2000K
3SDCM
2 SDCM
0.42
2700K
0.37
3000K
5000K
0.36
3500K
0.4
3 SDCM
0.38
5700K
0.35
Y
Y
4000K
0.34
0.38
6500K
0.33
0.36
0.32
0.31
0.34
0.36
0.39
0.42
0.45
X
0.48
0.51
0.54
0.3
0.3
0.31
0.32
0.33
0.34
0.35
0.36
X
Note: Pulsed Test Conditions, Tc = 25°C
Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT
Bin Code1
2000K
2700K
3000K1
3500K1
4000K1
ANSI Bin
(for reference only)
(2580K - 2870K)
(2870K - 3220K)
(3220K - 3710K)
(3710K - 4260K)
73 (3 SDCM)
(2651K - 2794K)
(2968K - 3136K)
(3369K - 3586K)
(3851K - 4130K)
72 (2 SDCM)
(2674K - 2769K)
(2995K - 3107K)
(3404K - 3548K)
(3895K - 4081K)
Center Point (x,y)
(0.5280, 0.4100)
(0.4578, 0.4101)
(0.4338, 0.403)
(0.4465, 0.4024)2
(0.4073, 0.3917)
(0.3818, 0.3797)
Note for Table 8:
1. Color Binning information excludes Decor Series Class A products. Please contact your Bridgelux Sales Representative for more information.
2. Center Point for Decor Series Showcase.
Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C)
Bin Code
5000K
5700K
6500K
ANSI Bin (for reference only)
(4745K - 5311K)
(5312K - 6022K)
(6022K - 7042K)
74 (4 SDCM)
(4801K - 5282K)
(5481K - 5829K)
(6270K - 6765K)
73 (3 SDCM)
(4835K - 5215K)
(5490K - 5820K)
(6250K - 6745K)
Center Point (x,y)
(0.3447, 0.3553)
(0.3287, 0.3417)
(0.3123, 0.3282)
28
Figure 24: Drawing for Vero SE 10 Packaging Tray
Notes for Figure 24:
1. Dimensions are in millimeters.
2. Drawings are not to scale.
29
Figure 25: Vero SE Series Packaging and Labeling
Notes for Figure 25:
1. Each tray holds 200 COBs.
2. Each tray is vacuum sealed in an anti-static bag and placed in its own box.
3. Each tray, bag and box is to be labeled as shown above.
Figure 26: Vero SE Product Labeling
Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In
addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux
manufacturing use only. The image below shows which markings are for customer use and which ones are for
Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice,
however these will not impact the form, function or performance of the COB array.
Customer Use- 2D Barcode
Scannable barcode provides
product part number, Vf bin
and other Bridgelux internal
production information.
Customer Use- Product part number
30E1000C 72 2F
Customer Use- Vf Bin Code
included to enable greater
luminaire design flexibility.
Refer to AN92 for bin code
definitions.
30
Design Resources
Application Notes
3D CAD Models
Bridgelux has developed a comprehensive set of
application notes and design resources to assist
customers in successfully designing with the Vero
product family of LED array products. For all available
application notes visit www.bridgelux.com.
Three dimensional CAD models depicting the product
outline of all Bridgelux Vero LED arrays are available
in both IGS and STEP formats. Please contact your
Bridgelux sales representative for assistance.
Optical Source Models
LM80
Optical source models and ray set files are available
for all Bridgelux products. For a list of available formats,
LM80 testing has been completed and the LM80 report
is now available. Please contact your Bridgelux sales
representative for LM-80 report.
Precautions
CAUTION: CHEMICAL EXPOSURE HAZARD
Exposure to some chemicals commonly used in
luminaire manufacturing and assembly can cause
damage to the LED array. Please consult Bridgelux
Application Note AN121 for additional information.
CAUTION: RISK OF BURN
Do not touch the Vero LED array during operation. Allow
the array to cool for a sufficient period of time before
handling. The Vero LED array may reach elevated
temperatures such that could burn skin when touched.
CAUTION
CONTACT WITH LIGHT EMITTING SURFACE (LES)
Avoid any contact with the LES. Do not touch the
LES of the LED array or apply stress to the LES
(yellow phosphor resin area). Contact may cause
Optics and reflectors must not be mounted in contact
with the LES (yellow phosphor resin area). Optical
devices may be mounted on the top surface of the
plastic housing of the Vero LED array. Use the
mechanical features of the LED array housing, edges
and/or mounting holes to locate and secure optical
devices as needed.
Disclaimers
MINOR PRODUCT CHANGE POLICY
STANDARD TEST CONDITIONS
The rigorous qualification testing on products offered
by Bridgelux provides performance assurance. Slight
cosmetic changes that do not affect form, fit, or function
may occur as Bridgelux continues product optimization.
Unless otherwise stated, array testing is performed
31
About Bridgelux: Bridging Light and Life™
At Bridgelux, we help companies, industries and people experience the power and possibility
of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient,
cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering
products that create better environments, experiences and returns—both experiential and
financial. And our patented technology drives new platforms for commercial and industrial
luminaires.
For more information about the company, please visit
bridgelux.com
twitter.com/Bridgelux
facebook.com/Bridgelux
youtube.com/user/Bridgelux
linkedin.com/company/bridgelux-inc-_2
WeChat ID: BridgeluxInChina
46430 Fremont Boulevard
Fremont, CA 94538 U.S.A.
Tel (925) 583-8400
www.bridgelux.com
© 2016-2018 Bridgelux, Inc. All rights reserved 2018. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero,
V Series, V Series HD and are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners.
Bridgelux Vero SE 10 Array Series Product Data Sheet DS120 Rev. K (11/2018)
32
