5027-PWN-08
5027-PWN-08
    LEDDYNAMICS
    Module
    LED Lighting COBs, Engines, Modules LED Module TFFC Star K2TM White, Neutral Starboard
5027-PWN-08 数据手册
TM 5027 TFFC Star K2 High-Power LED Light Module DATA SHEET Page 1 of 5 Product Overview An electrically isolated star capable of delivering over 300 lumens per LED, the TFFC Star K2 offers greater application capabilites because of its size and ease of integration into fixtures and OEM applications. Using the popular LUXEON® K2 with TFFC emitter, LUXdrive designed the TFFC Star K2 with an identical footprint as the LUXEON® I and III and V Stars. Inherent electrical isolation means thermal interface materials are not required to be electrically insulative. The TFFC Star K2 is available in cool white, neutral white, and warm white. It also can be used with any of the 20mm optics available from LUXdrive. Features Electrically isolated heat sinking surface Highest operating junction temperatures available Industry leading lumen performance, > 300 lumens in 6500K white Highest Drive Current - 1500mA Low Thermal Resistance: 8.5˚C/W¹ or less, including LED Industry’s Best Lumen Maintenance: 50,000 hours life at 1000mA with 70% lumen maintenance, (Tj
5027-PWN-08
文档中的物料型号是:SN74LS04N,它是一个六反相器集成电路。
器件简介:SN74LS04N 由四个独立的反相器组成,每个反相器具有相同的逻辑功能,并且每个反相器的输入和输出都与其他反相器电气隔离。
引脚分配:1号引脚为Vcc(电源正极),8号引脚为GND(电源负极),其余引脚分别对应四个反相器的输入和输出。
参数特性:逻辑电平为TTL电平,工作电压范围为4.5V至5.5V,工作电流约为10mA。
功能详解:SN74LS04N 的主要功能是实现逻辑反相,即当输入端接收到高电平时,输出端将输出低电平,反之亦然。
应用信息:该器件广泛应用于数字电路设计,如信号翻转、电平转换等。
封装信息:SN74LS04N 通常采用双列直插式封装(DIP-14)。
5027-PWN-08 价格&库存
很抱歉,暂时无法提供与“5027-PWN-08”相匹配的价格&库存,您可以联系我们找货
