BXRE-20B1001-B-73
BXRE-20B1001-B-73
    BRIDGELUX(普瑞)
    BXRE-20B1001-B-73
BXRE-20B1001-B-73 数据手册
Bridgelux Gen 7 V10 Array Series ® Product Data Sheet DS100 1 V Series Introduction The V Series™ LED Array products deliver high quality light in a compact and cost-effective solid-state lighting package. These chip on board (CoB) arrays can be efficiently driven at twice the nominal drive current, enabling design flexibility not previously possible. This high flux density light source is designed to support a wide range of high quality, low cost directional luminaires and replacement lamps for commercial and residential applications. The V10 LED array is available in a variety of electrical, CCT and CRI combinations providing substantial design flexibility and energy efficiencies. Lighting system designs incorporating these LED arrays deliver increased system level efficacy and longer service life. Typical applications include, replacement lamps, and task, accent, spot, track, wide area, security, wall pack and down lights. Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and H Series™. Décor Series Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 93, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is designed as a replacement for halogen. Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features Benefits • Efficacy of 155 lm/W typical • Enhanced optical control • Compact high flux density light source • Clean white light without pixilation • Uniform high quality illumination • High quality true color reproduction • Minimum 65, 70, 80 and 90 and 95 CRI options • Significantly reduced thermal resistance and increased operating temperatures • Streamlined thermal path • ENERGY STAR® / ANSI compliant color binning structure with 2, 3 and 4 SDCM options • Uniform consistent white light • Lower operating costs • More energy efficient than incandescent, halogen and fluorescent lamps • Easy to use with daylight and motion detectors to enable increased energy savings • Low voltage DC operation • Reduced maintenance costs • Instant light with unlimited dimming • Environmentally friendly, no disposal issue • Vf bin code backside marking Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 8 Electrical Characteristics 14 Eye Safety 15 Absolute Maximum Ratings 16 Performance Curves 17 Typical Radiation Pattern 20 Typical Color Spectrum 21 Mechanical Dimensions 22 Color Binning Information 23 Packaging and Labeling 24 Design Resources 26 Precautions 26 Disclaimers 26 About Bridgelux 25 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series family of products. Polarity symbols Designed to comply with global safety standards for creepage and clearance distances Fully engineered substrate for consistent thermal, mechanical and optical properties White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point Solder Pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 E 100 0 – C – 7 3 CCT Bin Options Product Family Nominal CCT 20 = 2,000K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen. 7 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Array Configuration CRI B = 63 CRI typ. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Décor Series Showcase Target Flux Indicator 100x = 1000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) BXRE-20B1000-B-73 2000 65 BXRE-27E1000-B-7x 2700 80 CRI2 Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) 270 1372 1208 34.8 9.5 145 270 1394 1226 34.8 9.4 148 Nominal Drive Current3 (mA) Typical Efficacy (lm/W) BXRE-27E1000-C-7x 2700 80 360 1858 1635 34.8 12.5 148 BXRE-27G10H0-B-7x 2700 90 270 1203 1058 34.8 9.4 128 BXRE-27G10H0-C-7x 2700 90 360 1604 1411 34.8 12.5 128 BXRE-27G1000-B-7x 2700 90 270 1161 1022 34.8 9.4 124 BXRE-27G1000-C-7x 2700 90 360 1548 1363 34.8 12.5 124 BXRE-27H1000-B-7x 2700 97 270 1006 886 34.8 9.4 107 171 BXRE-30C1001-B-74 3000 70 270 1607 1414 34.8 9.4 BXRE-30C1001-C-74 3000 70 360 2142 1885 34.8 12.5 171 BXRE-30E1000-B-7x 3000 80 270 1452 1277 34.8 9.4 155 BXRE-30E1000-C-7x 3000 80 360 1936 1703 34.8 12.5 155 135 BXRE-30G10H0-B-7x 3000 90 270 1268 1116 34.8 9.4 BXRE-30G10H0-C-7x 3000 90 360 1691 1488 34.8 12.5 135 BXRE-30G1000-B-7x 3000 90 270 1210 1065 34.8 9.4 129 BXRE-30G1000-C-7x 3000 90 360 1613 1419 34.8 12.5 129 BXRE-30G100C-B-73 3000 90 270 1123 988 34.8 9.4 119 BXRE-30G100C-C-73 3000 90 360 1497 1317 34.8 12.5 119 BXRE-30A1001-B-738,9 3000 93 270 1090 959 34.8 9.4 116 BXRE-30A1001-C-738,9 3000 93 360 1453 1279 34.8 12.5 116 BXRE-30H1000-B-7x 3000 97 270 1084 954 34.8 9.4 115 BXRE-35E1000-B-7x 3500 80 270 1500 1320 34.8 9.4 160 BXRE-35E1000-C-7x 3500 80 360 2000 1760 34.8 12.5 160 BXRE-35G1000-B-7x 3500 90 270 1248 1099 34.8 9.4 133 BXRE-35G1000-C-7x 3500 90 360 1665 1465 34.8 12.5 133 BXRE-35A1001-B-738,9 3500 93 270 1175 1034 34.8 9.4 125 BXRE-35A1001-C-738,9 3500 93 360 1566 1378 34.8 12.5 125 BXRE-40C1001-B-74 4000 70 270 1635 1439 34.8 9.4 174 BXRE-40C1001-C-74 4000 70 360 2180 1918 34.8 12.5 174 BXRE-40E1000-B-7x 4000 80 270 1510 1329 34.8 9.4 161 BXRE-40E1000-C-7x 4000 80 360 2013 1771 34.8 12.5 161 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-40G1000-B-7x 4000 90 270 1297 1141 34.8 9.4 138 BXRE-40G1000-C-7x 4000 90 360 1729 1522 34.8 12.5 138 176 BXRE-50C1001-B-7x 5000 70 270 1655 1456 34.8 9.4 BXRE-50C1001-C-7x 5000 70 360 2207 1942 34.8 12.5 176 BXRE-50E1001-B-7x 5000 80 270 1558 1371 34.8 9.4 166 BXRE-50E1001-C-7x 5000 80 360 2078 1828 34.8 12.5 166 BXRE-50G1001-B-7x 5000 90 270 1316 1158 34.8 9.4 140 BXRE-50G1001-C-7x 5000 90 360 1755 1544 34.8 12.5 140 BXRE-57C1001-B-7x 5700 70 270 1597 1405 34.8 9.4 170 BXRE-57C1001-C-7x 5700 70 360 2129 1874 34.8 12.5 170 BXRE-57E1001-B-7x 5700 80 270 1541 1356 34.8 9.4 164 BXRE-57E1001-C-7x 5700 80 360 2055 1808 34.8 12.5 164 BXRE-65C1001-B-7x 6500 70 270 1626 1431 34.8 9.4 173 BXRE-65C1001-C-7x 6500 70 360 2168 1908 34.8 12.5 173 BXRE-65E1001-B-7x 6500 80 270 1569 1381 34.8 9.4 167 BXRE-65E1001-C-7x 6500 80 360 2092 1841 34.8 12.5 167 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 4 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-30A1001-B-73 3000 80 93 270 1014 892 34.3 9.3 109 BXRE-30A1001-C-73 3000 80 93 360 1352 1189 34.3 12.3 109 BXRE-35A1001-B-73 3500 80 93 270 1092 961 34.3 9.3 118 BXRE-35A1001-C-73 3500 80 93 360 1456 1282 34.3 12.3 118 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. All CRI values are measured at Tj = Tc = 25°C. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 5 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-20B1001-B-73 2000 65 270 1235 1087 33.8 9.1 135 BXRE-27E1000-B-7x 2700 80 270 1254 1104 33.8 9.1 137 BXRE-27E1000-C-7x 2700 80 360 1672 1472 33.8 12.2 137 BXRE-27G10H0-B-7x 2700 90 270 1082 953 33.8 9.1 118 BXRE-27G10H0-C-7x 2700 90 360 1443 1270 33.8 12.2 118 BXRE-27G1000-B-7x 2700 90 270 1045 920 33.8 9.1 114 BXRE-27G1000-C-7x 2700 90 360 1394 1226 33.8 12.2 114 BXRE-27H1000-B-7x 2700 97 270 906 797 33.8 9.1 99 BXRE-30C1001-B-74 3000 70 270 1446 1273 33.8 9.1 158 BXRE-30C1001-C-74 3000 70 360 1928 1697 33.8 12.2 158 BXRE-30E1000-B-7x 3000 80 270 1307 1150 33.8 9.1 143 BXRE-30E1000-C-7x 3000 80 360 1742 1533 33.8 12.2 143 BXRE-30G10H0-B-7x 3000 90 270 1142 1005 33.8 9.1 125 BXRE-30G10H0-C-7x 3000 90 360 1522 1339 33.8 12.2 125 BXRE-30G1000-B-7x 3000 90 270 1089 958 33.8 9.1 119 BXRE-30G1000-C-7x 3000 90 360 1452 1277 33.8 12.2 119 BXRE-30G100C-B-73 3000 90 270 1010 889 33.8 9.1 111 BXRE-30G100C-C-73 3000 90 360 1347 1186 33.8 12.2 111 BXRE-30A1001-B-737,8 3000 93 270 981 863 33.8 9.1 107 BXRE-30A1001-C-737,8 3000 93 360 1308 1151 33.8 12.2 107 BXRE-30H1000-B-7x 3000 97 270 976 858 33.8 9.1 107 BXRE-35E1000-B-7x 3500 80 270 1350 1188 33.8 9.1 148 BXRE-35E1000-C-7x 3500 80 360 1800 1584 33.8 12.2 148 BXRE-35G1000-B-7x 3500 90 270 1124 989 33.8 9.1 123 BXRE-35G1000-C-7x 3500 90 360 1498 1318 33.8 12.2 123 BXRE-35A1001-B-737,8 3500 93 270 1057 930 33.8 9.1 116 BXRE-35A1001-C-737,8 3500 93 360 1409 1240 33.8 12.2 116 BXRE-40C1001-B-74 4000 70 270 1471 1295 33.8 9.1 161 BXRE-40C1001-C-74 4000 70 360 1962 1726 33.8 12.2 161 BXRE-40E1000-B-7x 4000 80 270 1359 1196 33.8 9.1 149 BXRE-40E1000-C-7x 4000 80 360 1812 1594 33.8 12.2 149 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 6 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 128 BXRE-40G1000-B-7x 4000 90 270 1167 1027 33.8 9.1 BXRE-40G1000-C-7x 4000 90 360 1556 1369 33.8 12.2 128 BXRE-50C1001-B-7x 5000 70 270 1489 1311 33.8 9.1 163 BXRE-50C1001-C-7x 5000 70 360 1986 1748 33.8 12.2 163 BXRE-50E1001-B-7x 5000 80 270 1402 1234 33.8 9.1 154 BXRE-50E1001-C-7x 5000 80 360 1870 1645 33.8 12.2 154 BXRE-50G1001-B-7x 5000 90 270 1185 1042 33.8 9.1 130 BXRE-50G1001-C-7x 5000 90 360 1579 1390 33.8 12.2 130 BXRE-57C1001-B-7x 5700 70 270 1437 1265 33.8 9.1 157 BXRE-57C1001-C-7x 5700 70 360 1916 1686 33.8 12.2 157 BXRE-57E1001-B-7x 5700 80 270 1387 1220 33.8 9.1 152 BXRE-57E1001-C-7x 5700 80 360 1849 1627 33.8 12.2 152 BXRE-65C1001-B-7x 6500 70 270 1463 1288 33.8 9.1 160 BXRE-65C1001-C-7x 6500 70 360 1951 1717 33.8 12.2 160 BXRE-65E1001-B-7x 6500 80 270 1412 1243 33.8 9.1 155 BXRE-65E1001-C-7x 6500 80 360 1883 1657 33.8 12.2 155 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 7 Performance at Commonly Used Drive Currents V Series LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series LED Arrays may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1 & 2 and the flux vs. current characteristics shown in Figures 3 & 4. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRE-20B1001-B-73 65 BXRE-27E1000-B-7X 80 BXRE-27E1000-C-7X 80 BXRE-27G10H0-B-7x 90 BXRE-27G10H0-C-7x 90 BXRE-27G1000-B-7x 90 BXRE-27G1000-C-7x 90 BXRE-27H1000-B-7x 97 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 180 270 405 540 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 4.5 6.1 9.4 14.4 19.5 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 731 959 1372 2013 2579 743 974 1394 2045 2619 988 1294 1858 2706 3456 641 840 1203 1764 2260 853 1117 1604 2335 2983 619 811 1161 1704 2183 823 1079 1548 2255 2880 536 703 1006 1477 1892 657 860 1235 1791 2283 667 873 1254 1819 2318 882 1150 1672 2351 2959 576 754 1082 1570 2001 761 992 1443 2029 2553 556 728 1045 1516 1932 735 958 1394 1959 2465 482 631 906 1314 1674 163 157 146 140 132 166 159 148 142 134 165 159 148 141 133 143 137 128 122 116 143 137 128 121 115 138 133 124 118 112 138 132 124 117 111 120 115 107 102 97 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-30C1001-B-74 70 BXRE-30C1001-C-74 70 BXRE-30E1000-B-7x 80 BXRE-30E1000-C-7x 80 BXRE-30G10H0-B-7x 90 BXRE-30G10H0-C-7x 90 BXRE-30G1000-B-7x 90 BXRE-30G1000-C-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 856 1123 1607 2357 3020 1139 1492 2142 3119 3985 774 1014 1452 2130 2728 1029 1348 1936 2818 3600 676 886 1268 1861 2384 899 1178 1691 2463 3146 645 845 1210 1775 2274 858 1124 1613 2349 3000 769 1007 1446 2097 2673 1016 1326 1928 2710 3411 695 910 1307 1895 2415 918 1198 1742 2448 3082 607 795 1142 1655 2110 802 1047 1522 2139 2693 579 758 1089 1579 2012 765 998 1452 2040 2568 191 183 171 163 155 191 183 171 162 153 173 166 155 148 140 172 165 155 146 138 151 145 135 129 122 150 144 135 128 121 144 138 129 123 116 143 138 129 122 115 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-30G100C-B-73 90 BXRE-30G100C-C-73 90 BXRE-30A1001-B-73 93 BXRE-30A1001-C-73 93 BXRE-30H1000-B-7x 97 BXRE-35E1000-B-7x 80 BXRE-35E1000-C-7x 80 BXRE-35G1000-B-7x 90 BXRE-35G1000-C-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 598 784 1123 1647 2110 796 1043 1497 2180 2784 581 762 1090 1599 2049 773 1012 1453 2116 2703 578 757 1084 1590 2037 799 1048 1500 2201 2819 1063 1393 2000 2912 3720 665 872 1248 1832 2346 885 1159 1665 2424 3096 538 704 1010 1465 1868 710 926 1347 1893 2383 522 683 981 1422 1813 689 899 1308 1838 2314 519 679 976 1415 1803 718 940 1350 1958 2495 949 1238 1800 2530 3185 598 782 1124 1629 2077 790 1030 1498 2106 2650 133 128 119 114 108 133 128 119 113 107 130 124 116 111 105 129 124 116 110 104 129 124 115 110 104 178 171 160 152 144 178 171 160 151 143 148 143 133 127 120 148 142 133 126 119 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-35A1001-B-73 93 BXRE-35A1001-C-73 93 BXRE-40C1001-B-74 70 BXRE-40C1001-C-74 70 BXRE-40E1000-B-7x 80 BXRE-40E1000-C-7x 80 BXRE-40G1000-B-7x 90 BXRE-40G1000-C-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 626 821 1175 1723 2207 833 1091 1566 2280 2913 871 1142 1635 2399 3073 1159 1589 2180 3174 4055 805 1055 1510 2215 2838 1070 1402 2013 2931 3744 691 906 1297 1903 2437 919 1204 1729 2518 3216 562 736 1057 1533 1954 743 969 1409 1981 2493 783 1025 1471 2134 2720 1034 1349 1962 2757 3471 723 946 1359 1970 2511 955 1246 1812 2546 3205 621 813 1167 1692 2157 820 1070 1556 2187 2753 140 134 125 119 113 139 134 125 118 112 194 187 174 166 157 194 186 174 165 156 179 172 161 153 145 179 172 161 152 144 154 148 138 132 125 154 148 138 131 124 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-50C1001-B-7x 70 BXRE-50C1001-C-7x 70 BXRE-50E1001-B-7x 80 BXRE-50E1001-C-7x 80 BXRE-50G1001-B-7x 90 BXRE-50G1001-C-7x 90 BXRE-57C1001-B-7x 70 BXRE-57C1001-C-7x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 882 1156 1655 2428 3110 1173 1537 2207 3213 4104 830 1089 1558 2286 2929 1105 1447 2078 3025 3864 701 920 1316 1931 2474 933 1222 1755 2555 3264 851 1116 1597 2343 3001 1132 1483 2129 3100 3960 792 1037 1489 2160 2753 1047 1365 1986 2791 3513 746 976 1402 2033 2592 986 1286 1870 2628 3308 630 825 1185 1718 2189 833 1086 1579 2220 2794 765 1001 1437 2084 2656 1010 1317 1916 2693 3390 197 189 176 168 159 196 188 176 167 158 185 178 166 158 150 185 177 166 157 148 156 150 140 134 127 156 150 140 133 125 190 182 170 162 154 189 182 170 161 152 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-57E1001-B-7x 80 BXRE-57E1001-C-7x 80 BXRE-65C1001-B-7x 70 BXRE-65C1001-C-7x 70 BXRE-65E1001-B-7x 80 BXRE-65E1001-C-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 135 180 270 405 540 180 240 360 540 720 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 4.5 6.1 9.4 14.4 19.5 6.0 8.2 12.5 19.2 26.0 821 1077 1541 2261 2896 1092 1431 2055 2992 3822 866 1136 1626 2385 3056 1153 1510 2168 3157 4032 836 1096 1569 2302 2949 1112 1457 2092 3047 3892 738 966 1387 2011 2563 975 1271 1849 2599 3271 779 1019 1463 2122 2705 1028 1341 1951 2742 3452 751 983 1412 2048 2610 993 1295 1883 2647 3331 183 176 164 157 148 183 175 164 155 147 193 186 173 165 157 193 185 173 164 155 186 179 167 160 151 186 179 167 158 150 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRE-xxx100x-B-7x BXRE-xxx100x-C-7x Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.49 30.9 38.5 -16.1 0.56 32.1 39.9 37.4 -16.1 0.37 30.9 38.5 38.8 -16.1 0.45 32.1 39.9 Minimum Typical Maximum 270 32.2 34.8 37.4 -16.1 540 33.4 36.1 38.8 360 32.2 34.8 720 33.4 36.1 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 14 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRE-xxx100x-B-7x BXRE-xxx100x-C-7x CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 6500K4 270 RG1 RG1 RG1 RG1 405 RG1 RG1 RG1 RG2 540 RG1 RG1 RG2 RG2 360 RG1 RG1 RG1 RG2 540 RG1 RG1 RG2 RG2 720 RG1 RG2 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 15 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRE-xxx100x-B-7x BXRE-xxx100x-C-7x Maximum Drive Current3 540mA 720mA Maximum Peak Pulsed Drive Current4 770mA 1030mA Maximum Reverse Voltage5 -60V -60V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 16 Performance Curves Figure 1: V10B Drive Current vs. Voltage Figure 2: V10C Drive Current vs. Voltage 600 800 700 Forward Current (mA) Forward Current (mA) 500 400 300 200 100 0 600 500 400 300 200 100 32 33 34 35 36 37 0 38 32 33 34 Forward Voltage (V) 36 37 38 Figure 4: V10C Typical Relative Flux vs. Current Figure 3: V10B Typical Relative Flux vs. Current 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux 35 Forward Voltage (V) 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0% 0 100 200 300 Forward Current (mA) 400 500 600 0 100 200 300 400 500 600 700 800 Forward Current (mA) Notes for Figures 1-4: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 17 Performance Curves Figure 5: Typical DC Flux vs. Case Temperature5 103% 0 Warm White Cool White 50 75 100 125 0.000 25°C Pulsed 97% 25 0.003 Neutral White 100% -0.003 94% ccy Shift Relative Luminous Flux Figure 6: Typical DC ccy Shift vs. Case Temperature 91% -0.006 88% -0.009 85% -0.012 Warm White 82% 0 25 50 75 100 125 -0.015 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Case Temperature (°C) Figure 7: Typical DC ccx Shift vs. Case Temperature 0 25 50 75 100 125 0.000 -0.002 ccx Shift -0.004 -0.006 -0.008 Warm White -0.010 -0.012 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Notes for Figures 5-7: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. Characteristics shown for warm white includes Decor Series Class A 5. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 18 Performance Curves Figure 8: 2000K, 65 CRI Color Shift vs. Case Temperature Figure 9: 3000K, 90 CRI Color Shift vs. Case Temperature1,3 0.403 0.4101 0.41 0.4099 0.4098 15°C 0.4097 45°C 0.4 45°C ccy ccy Pulsed Center Point Tc=25°C 25°C 0.401 25°C 0.4096 0.4095 65°C 0.399 65°C 0.398 0.4094 85°C 0.4093 0.397 85°C 0.4092 0.526 0.527 0.528 0.529 0.53 0.531 105°C 0.396 105°C 0.4091 0.409 0.525 15°C 0.402 Pulsed Center Point Tc=25°C 0.395 0.444 0.532 0.4445 0.445 0.4455 0.446 0.4465 0.447 ccx ccx Figure 10: 2700K, 97 CRI Color Shift vs. Case Temperature1 Figure 11: 3000K, 97 CRI Color Shift vs. Case Temperature1 0.4110 0.4050 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 25°C 0.4090 45°C 0.4010 45°C ccy ccy 0.4080 Pulsed Center Point Tc = 25°C 15°C 0.4030 0.4070 65°C 70°C 0.3990 0.4060 85°C 85°C 0.4050 0.3970 105°C 0.4040 105°C 0.4030 0.457 0.3950 0.4323 0.4572 0.4574 0.4576 0.4578 0.4328 0.4333 ccx 0.4343 0.4348 0.4353 ccx Figure 12: 3000K Class A Color Shift vs. Case Temperature1 Figure 13: 3500K Class A Color Shift vs. Case Temperature1 0.37 0.369 15°C 0.368 25°C 0.367 0.366 15°C Pulsed Center Point Tc=25°C 0.368 25°C 0.366 45°C Pulsed Center Point Tc=25°C 45°C 0.365 ccy ccy 0.4338 0.458 0.364 0.364 70°C 0.363 70°C 0.362 85°C 85°C 0.362 0.361 0.36 0.416 0.36 105°C 0.4165 105°C 0.417 ccx 0.4175 0.418 0.4185 0.358 0.392 0.393 0.394 0.395 0.396 0.397 ccx Note for Figures 8-13: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRE-30G100C-x-73 19 Typical Radiation Pattern Figure 14: Typical Spatial Radiation Pattern Note for Figure 14: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 15: Typical Polar Radiation Pattern 20 Typical Color Spectrum Figure 16: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 16: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 17: Typical Color Spectrum for Décor Series 1 20B 27H 0.9 30H 30G (Décor Series Showcase) Relative Spectral Power Distribution 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 17: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 21 Mechanical Dimensions Figure 18: Drawing for V10 LED Array Notes for Figure 18: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Solder pad labeled “+” denotes positive contact. 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 22 Color Binning Information Figure 19: Warm and Neutral White Test Bins in xy Color Figure 20: Cool White Test Bins in xy Color Space Space 0.39 0.44 4 SDCM 3 SDCM 2000K 3SDCM 2 SDCM 0.42 3 SDCM 0.38 2700K 0.37 5000K 3000K 0.36 3500K 0.4 5700K 0.35 Y Y 4000K 0.34 0.38 6500K 0.33 0.36 0.32 0.31 0.34 0.36 0.39 0.42 0.45 X 0.48 0.51 0.54 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2000K 2700K 3000K1 3500K1 4000K1 ANSI Bin (for reference only) - (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) - (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) - (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.5280, 0.4100) (0.4578, 0.4101) (0.4338, 0.403) (0.4465, 0.4024)2 (0.4073, 0.3917) (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Décor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5481K - 5829K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) 23 Packaging and Labeling Figure 21: V10 Packaging Tube Notes for Figure 21: 1. Each tube holds 30 V10 COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 8.3 (W) x 15.4 (H) x 430 (L). Dimensions for the anti-static bag are 75 (W) x 615 (L) x 3.1 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 24 Packaging and Labeling Figure 22: Gen. 7 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E4000C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 25 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 26 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2018 Bridgelux, Inc. All rights reserved 2018. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 7 V10 Array Series Product Data Sheet DS100 Rev. M (11/2018) 27
BXRE-20B1001-B-73 价格&库存
很抱歉,暂时无法提供与“BXRE-20B1001-B-73”相匹配的价格&库存,您可以联系我们找货
BXRE-20B1001-B-73
    • 1+39.81960
    • 210+15.89760
    • 510+15.35760
    • 990+15.09840
