SM1206NPGC-IL
SM1206NPGC-IL
    BIVAR
    发光二极管/LED 翠绿色 1206 525nm 1550mcd
SM1206NPGC-IL 数据手册
SURFACE MOUNT LED PURE GREEN, 1206 IL PACKAGE SM1206NPGC-IL       Industry Standard 1206 Package RoHS Compliant Water Clear Inner Lens High Luminous Intensity Narrow Viewing Angle Ideal for Status Indication, Display, and Backlighting Bivar Surface Mount 1206 Inner Lens package LED may be used in nearly any lighting or indication application. The water clear inner lens provides a narrow viewing angle and high luminous intensity making it suitable for small scale applications such as display, backlighting, and general indication. Low power consumption and excellent long life reliability are ideal for battery powered equipment. Wide variety of wavelength and intensity combinations are available to meet any illumination need. The SM1206-IL LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Peak Wavelength λp(nm) TYP. Lens Appearance Luminous Intensity (mcd) TYP. Viewing Angle SM1206NPGC-IL InGaN/SiC PURE GREEN 523 Water Clear 1550 30° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Level 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 1 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 1206 IL PACKAGE Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 100 mW Forward Current ( DC ) 25 mA Peak Forward Current 1 100 mA Reverse Voltage 5V Operating Temperature Range -30 ~ +80°C Storage Temperature Range -40 ~ +85°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX SM1206NPGC-IL / 3.0 4.2 / 20 Notes: 1. Tolerance of forward voltage : ±0.05V. / Reverse Dominant Current Wavelength (nm)2 (μA) MAX MIN TYP MAX 10 / 525 / Luminous Intensity Iv (mcd) MIN TYP 1000 1550 Viewing Angle 2Ө½ (deg) MAX TYP / 30 2. Tolerance of dominant wavelength : ±5.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 2 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 1206 IL PACKAGE Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 3 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 1206 IL PACKAGE Recommended Soldering Conditions Tape and Reel Dimensions Note: 3000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision B 06/15 Page 4 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER PURE GREEN, 1206 IL PACKAGE Packaging and Labeling Plan Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance unless otherwise noted: X.XXX ± 0.010" X.X ± 0.1” Note: 1 Reel / Bag Vacuum and Heat Sealed ESD/MBB Bag Internal Quality Control X.XXX Humidity Indicator Card X.XXX Desiccants Bivar Standard Packaging Label Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: E-mail: bivar@bivar.com Web: www.bivar.com Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 Web: www.bivar.com Rev. A B 01/16/08 Revision 06/15 Page Page 4 5 of of 4 5
SM1206NPGC-IL 价格&库存
很抱歉,暂时无法提供与“SM1206NPGC-IL”相匹配的价格&库存,您可以联系我们找货
SM1206NPGC-IL
  • 3000+5.491303000+0.71077
SM1206NPGC-IL
    SM1206NPGC-IL
    • 3000+4.396603000+0.56908
    • 6000+4.203816000+0.54413
    • 9000+4.105099000+0.53135
    • 15000+3.9937115000+0.51693
    • 21000+3.9275121000+0.50836
    库存:11958
    SM1206NPGC-IL
    • 25+6.37223
    库存:650
    SM1206NPGC-IL
    • 25+6.37223
    库存:650
    SM1206NPGC-IL
      SM1206NPGC-IL
      • 1+11.398611+1.47539
      • 10+8.0132110+1.03720
      • 100+5.97557100+0.77346
      • 500+5.07158500+0.65645
      • 1000+4.775901000+0.61818
      库存:11958
      SM1206NPGC-IL
