BXRE-30G650C-D-73
BXRE-30G650C-D-73
    BRIDGELUX(普瑞)
    BXRE-30G650C-D-73
BXRE-30G650C-D-73 数据手册
Bridgelux Gen 7 V22 Array Series ® Product Data Sheet DS103 1 V Series Introduction The V Series™ LED Array products deliver high quality light in a compact and cost-effective solid-state lighting package. These chip on board (CoB) arrays can be efficiently driven at twice the nominal drive current, enabling design flexibility not previously possible. This high flux density light source is designed to support a wide range of high quality, low cost directional luminaires and replacement lamps for commercial and residential applications. The V22 LED Array is available in a variety of electrical, CCT and CRI combinations providing substantial design flexibility and energy efficiencies. Lighting system designs incorporating these LED arrays deliver increased system level efficacy and longer service life. Typical applications include, replacement lamps, and task, accent, spot, track, wide area, security, wall pack and down lights. Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and H Series™. Décor Series Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 93, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is designed as a replacement for halogen lamps. Décor Series™ Food products offer color points developed to address the unique requirements of the food, grocery, and restaurant industries. Highlighting the distinctive colors and nuanced patterns found in meats and breads, the Décor Series Food products are a must have for any butcher counter or bakery. Décor Series ™ Entertainment products provide color points developed specifically for the healthcare and entertainment industries. The 5600K cool white color point combined with a CRI of 90 or 97 provides the bright white required by these industries. Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features Benefits • Efficacy of 160 lm/W typical • Enhanced optical control • Compact high flux density light source • Clean white light without pixilation • Uniform high quality illumination • High quality true color reproduction • Minimum 65, 70, 80, 90 and 95 CRI options • Significantly reduced thermal resistance and increased operating temperatures • Streamlined thermal path • ENERGY STAR® / ANSI compliant color binning structure with 2, 3 and 4 SDCM options • Uniform consistent white light • Lower operating costs • More energy efficient than incandescent, halogen and fluorescent lamps • Easy to use with daylight and motion detectors to enable increased energy savings • Low voltage DC operation • Reduced maintenance costs • Instant light with unlimited dimming • Environmentally friendly, no disposal issue • Vf bin code backside marking Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 9 Electrical Characteristics 17 Eye Safety 18 Absolute Maximum Ratings 19 Performance Curves 20 Typical Radiation Pattern 24 Typical Color Spectrum 25 Mechanical Dimensions 26 Color Binning Information 27 Packaging and Labeling 28 Design Resources 30 Precautions 30 Disclaimers 30 About Bridgelux 31 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series family of products. Polarity symbols Designed to comply with global safety standards for creepage and clearance distances Fully engineered substrate for consistent thermal, mechanical and optical properties White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point Solder Pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 E 650 0 – C – 7 3 CCT Bin Options Product Family Nominal CCT 17 = 1,750K 20 = 2,000K 25 = 2,500K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 56 = 5,600K 57 = 5,700K 65 = 6,500K Gen. 7 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Array Configuration CRI B = 63 CRI typ. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Décor Series Showcase Target Flux Indicator 650x = 6500 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-17E6500-D-74 1750 80 1400 4340 3906 35.0 49.0 89 BXRE-20B6501-C-73 2000 65 1440 11183 10065 52.0 74.9 149 149 BXRE-20B6501-D-73 2000 65 1400 7318 6586 35.0 49.0 BXRE-25E6500-D-74 2500 80 1400 7015 6314 35.0 49.0 143 BXRE-27E6500-B-7x 2700 80 1170 9337 8403 52.0 60.8 153 BXRE-27E6500-C-7x 2700 80 1440 11492 10343 52.0 74.9 153 BXRE-27E6500-D-7x 2700 80 1400 7520 6768 35.0 49.0 153 BXRE-27G65H0-B-7x 2700 90 1170 8092 7283 52.0 60.8 133 BXRE-27G65H0-C-7x 2700 90 1440 9959 8963 52.0 74.9 133 BXRE-27G65H0-D-7x 2700 90 1400 6517 5865 35.0 49.0 133 BXRE-27G6500-B-7x 2700 90 1170 7770 6993 52.0 60.8 128 BXRE-27G6500-C-7x 2700 90 1440 9564 8607 52.0 74.9 128 BXRE-27G6500-D-7x 2700 90 1400 6258 5632 35.0 49.0 128 BXRE-27H6500-D-7x 2700 97 1400 5451 4906 35.0 49.0 111 BXRE-30C6501-B-74 3000 70 1170 10708 9637 52.0 60.8 176 176 BXRE-30C6501-C-74 3000 70 1440 13179 11861 52.0 74.9 BXRE-30C6501-D-74 3000 70 1400 8624 7762 35.0 49.0 176 BXRE-30E6500-B-7x10 3000 80 1170 9713 8742 52.0 60.8 160 BXRE-30E6500-C-7x10 3000 80 1440 11955 10759 52.0 74.9 160 BXRE-30E6500-D-7x10 3000 80 1400 7823 7041 35.0 49.0 160 BXRE-30G65H0-B-7x 3000 90 1170 8457 7611 52.0 60.8 139 BXRE-30G65H0-C-7x 3000 90 1440 10408 9367 52.0 74.9 139 BXRE-30G65H0-D-7x 3000 90 1400 6811 6130 35.0 49.0 139 BXRE-30G6500-B-7x 3000 90 1170 8084 7275 52.0 60.8 133 BXRE-30G6500-C-7x 3000 90 1440 9949 8954 52.0 74.9 133 BXRE-30G6500-D-7x 3000 90 1400 6511 5860 35.0 49.0 133 BXRE-30G650C-D-73 3000 90 1400 6056 5451 35.0 49.0 124 BXRE-30H6500-D-7x 3000 97 1400 5804 5224 35.0 49.0 118 BXRE-35E6500-B-7x10 3500 80 1170 10026 9024 52.0 60.8 165 BXRE-35E6500-C-7x10 3500 80 1440 12340 11106 52.0 74.9 165 BXRE-35E6500-D-7x10 3500 80 1400 8075 7268 35.0 49.0 165 BXRE-35G6500-B-7x 3500 90 1170 8334 7501 52.0 60.8 137 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Décor Series Ultra, Décor Series Street and Landmark and Décor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 10. SKUs meet DLC premium (Outdoor Mid Output) requirements under certain system level conditions. 3 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) 90 1440 10258 9232 90 1400 6713 6041 Part Number Nominal CCT1 (K) CRI BXRE-35G6500-C-7x 3500 BXRE-35G6500-D-7x 3500 BXRE-35A6501-D-73 2 Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Power (W) Typical Efficacy (lm/W) 52.0 74.9 137 35.0 49.0 137 Typical Vf (V) 3500 93 1400 6321 5689 35.0 49.0 129 BXRE-40C6501-B-74 4000 70 1170 10966 9870 52.0 60.8 180 8,9 BXRE-40C6501-C-74 4000 70 1440 13497 12147 52.0 74.9 180 BXRE-40C6501-D-74 4000 70 1400 8832 7949 35.0 49.0 180 BXRE-40E6500-B-7X10 4000 80 1170 10089 9080 52.0 60.8 166 BXRE-40E6500-C-7x 10 4000 80 1440 12417 11176 52.0 74.9 166 BXRE-40E6500-D-7x10 4000 80 1400 8126 7313 35.0 49.0 166 BXRE-40G6500-B-7x 4000 90 1170 8648 7783 52.0 60.8 142 BXRE-40G6500-C-7x 4000 90 1440 10643 9579 52.0 74.9 142 BXRE-40G6500-D-7x 4000 90 1400 6965 6268 35.0 49.0 142 BXRE-40H6500-D-73 4000 97 1400 5978 5380 35.0 49.0 122 BXRE-50C6501-B-7x10 5000 70 1170 11092 9983 52.0 60.8 182 BXRE-50C6501-C-7x10 5000 70 1440 13651 12286 52.0 74.9 182 BXRE-50C6501-D-7x10 5000 70 1400 8933 8040 35.0 49.0 182 BXRE-50E6501-B-7x10 5000 80 1170 10402 9362 52.0 60.8 171 BXRE-50E6501-C-7x 10 5000 80 1440 12803 11523 52.0 74.9 171 BXRE-50E6501-D-7x10 5000 80 1400 8378 7540 35.0 49.0 171 BXRE-50G6501-B-7x 5000 90 1170 8836 7952 52.0 60.8 145 BXRE-50G6501-C-7x 5000 90 1440 10875 9787 52.0 74.9 145 BXRE-50G6501-D-7x 5700 90 1400 7116 6405 35.0 49.0 145 BXRE-56G6501-D-7x 5600 90 1400 7470 6723 35.0 49.0 152 BXRE-57C6501-B-7x10 5700 70 1170 10716 9644 52.0 60.8 176 BXRE-57C6501-C-7x10 5700 70 1440 13189 11870 52.0 74.9 176 BXRE-57C6501-D-7x10 5700 70 1400 8630 7767 35.0 49.0 176 BXRE-57E6501-B-7x10 5700 80 1170 10282 9254 52.0 60.8 169 BXRE-57E6501-C-7x10 5700 80 1440 12655 11389 52.0 74.9 169 BXRE-57E6501-D-7x10 6500 80 1400 8281 7453 35.0 49.0 169 BXRE-65C6501-B-7x10 6500 70 1170 10904 9813 52.0 60.8 179 BXRE-65C6501-C-7x10 6500 70 1440 13420 12078 52.0 74.9 179 BXRE-65C6501-D-7x10 6500 70 1400 8782 7904 35.0 49.0 179 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Décor Series Ultra, Décor Series Street and Landmark and Décor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 10. SKUs meet DLC premium (Outdoor Mid Output) requirements under certain system level conditions. 4 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI 2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-65E6501-B-7x10 6500 80 1170 10464 9418 52.0 60.8 172 BXRE-65E6501-C-7x10 6500 80 1440 12879 11591 52.0 74.9 172 BXRE-65E6501-D-7x 6500 80 1400 8428 7585 35.0 49.0 172 10 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Décor Series Ultra, Décor Series Street and Landmark and Décor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 10. SKUs meet DLC premium (Outdoor Mid Output) requirements under certain system level conditions. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-35A6501-D-73 3500 80 93 1400 5879 5291 33.4 46.8 126 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. All CRI values are measured at Tj = Tc = 25°C. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-17E6500-D-74 1750 80 1400 3906 3516 33.4 46.8 84 BXRE-20B6501-C-73 2000 65 1440 10065 9058 50.7 73.0 138 BXRE-20B6501-D-73 2000 65 1400 6586 5928 33.4 46.8 141 BXRE-25E6500-D-74 2500 80 1400 6314 5682 33.4 46.8 135 142 BXRE-27E6500-B-7x 2700 80 1170 8403 7563 50.7 59.3 BXRE-27E6500-C-7x 2700 80 1440 10343 9308 50.7 73.0 142 BXRE-27E6500-D-7x 2700 80 1400 6768 6091 33.4 46.8 145 123 BXRE-27G65H0-B-7x 2700 90 1170 7283 6554 50.7 59.3 BXRE-27G65H0-C-7x 2700 90 1440 8963 8067 50.7 73.0 123 BXRE-27G65H0-D-7x 2700 90 1400 5865 5279 33.4 46.8 125 118 BXRE-27G6500-B-7x 2700 90 1170 6993 6294 50.7 59.3 BXRE-27G6500-C-7x 2700 90 1440 8607 7747 50.7 73.0 118 BXRE-27G6500-D-7x 2700 90 1400 5632 5069 33.4 46.8 120 BXRE-27H6500-D-7x 2700 97 1400 4906 4415 33.4 46.8 105 163 BXRE-30C6501-B-74 3000 70 1170 9637 8673 50.7 59.3 BXRE-30C6501-C-74 3000 70 1440 11861 10675 50.7 73.0 163 BXRE-30C6501-D-74 3000 70 1400 7762 6985 33.4 46.8 166 BXRE-30E6500-B-7x 3000 80 1170 8742 7868 50.7 59.3 147 BXRE-30E6500-C-7x 3000 80 1440 10759 9683 50.7 73.0 147 BXRE-30E6500-D-7x 3000 80 1400 7041 6337 33.4 46.8 151 BXRE-30G65H0-B-7x 3000 90 1170 7611 6850 50.7 59.3 128 BXRE-30G65H0-C-7x 3000 90 1440 9367 8431 50.7 73.0 128 BXRE-30G65H0-D-7x 3000 90 1400 6130 5517 33.4 46.8 131 BXRE-30G6500-B-7x 3000 90 1170 7275 6548 50.7 59.3 123 BXRE-30G6500-C-7x 3000 90 1440 8954 8059 50.7 73.0 123 BXRE-30G6500-D-7x 3000 90 1400 5860 5274 33.4 46.8 125 BXRE-30G650C-D-73 3000 90 1400 5451 4906 33.4 46.8 117 BXRE-30H6500-D-7x 3000 97 1400 5224 4701 33.4 46.8 112 BXRE-35E6500-B-7x 3500 80 1170 9024 8121 50.7 59.3 152 BXRE-35E6500-C-7x 3500 80 1440 11106 9996 50.7 73.0 152 BXRE-35E6500-D-7x 3500 80 1400 7268 6541 33.4 46.8 155 BXRE-35G6500-B-7x 3500 90 1170 7501 6751 50.7 59.3 127 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Décor Series Ultra, Décor Series Street and Landmark and Décor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 7 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 BXRE-35G6500-C-7x 3500 90 BXRE-35G6500-D-7x 3500 90 Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) 1440 9232 8309 50.7 73.0 127 1400 6041 5437 33.4 46.8 129 Nominal Drive Current3 (mA) Typical Power (W) Typical Efficacy (lm/W) BXRE-35A6501-D-737,8 3500 93 1400 5689 5120 33.4 46.8 122 BXRE-40C6501-B-74 4000 70 1170 9870 8883 50.7 59.3 166 BXRE-40C6501-C-74 4000 70 1440 12147 10933 50.7 73.0 166 BXRE-40C6501-D-74 4000 70 1400 7949 7154 33.4 46.8 170 BXRE-40E6500-B-7x 4000 80 1170 9080 8172 50.7 59.3 153 BXRE-40E6500-C-7x 4000 80 1440 11176 10058 50.7 73.0 153 BXRE-40E6500-D-7x 4000 80 1400 7313 6582 33.4 46.8 156 131 BXRE-40G6500-B-7x 4000 90 1170 7783 7005 50.7 59.3 BXRE-40G6500-C-7x 4000 90 1440 9579 8621 50.7 73.0 131 BXRE-40G6500-D-7x 4000 90 1400 6268 5642 33.4 46.8 134 BXRE-40H6500-D-73 4000 97 1400 5380 4842 33.4 46.8 115 BXRE-50C6501-B-7x 5000 70 1170 9983 8984 50.7 59.3 168 168 BXRE-50C6501-C-7x 5000 70 1440 12286 11058 50.7 73.0 BXRE-50C6501-D-7x 5000 70 1400 8040 7236 33.4 46.8 172 BXRE-50E6501-B-7x 5000 80 1170 9362 8426 50.7 59.3 158 BXRE-50E6501-C-7x 5000 80 1440 11523 10370 50.7 73.0 158 BXRE-50E6501-D-7x 5000 80 1400 7540 6786 33.4 46.8 161 BXRE-50G6501-B-7x 5000 90 1170 7952 7157 50.7 59.3 134 BXRE-50G6501-C-7x 5000 90 1440 9787 8809 50.7 73.0 134 BXRE-50G6501-D-7x 5700 90 1400 6405 5764 33.4 46.8 137 BXRE-56G6501-D-7x 5600 90 1400 6723 6050 33.4 46.8 144 BXRE-57C6501-B-7x 5700 70 1170 9644 8680 50.7 59.3 163 BXRE-57C6501-C-7x 5700 70 1440 11870 10683 50.7 73.0 163 BXRE-57C6501-D-7x 5700 70 1400 7767 6991 33.4 46.8 166 BXRE-57E6501-B-7x 5700 80 1170 9254 8328 50.7 59.3 156 BXRE-57E6501-C-7x 5700 80 1440 11389 10250 50.7 73.0 156 BXRE-57E6501-D-7x 6500 80 1400 7453 6708 33.4 46.8 159 BXRE-65C6501-B-7x 6500 70 1170 9813 8832 50.7 59.3 166 BXRE-65C6501-C-7x 6500 70 1440 12078 10870 50.7 73.0 166 BXRE-65C6501-D-7x 6500 70 1400 7904 7113 33.4 46.8 169 BXRE-65E6501-B-7x 6500 80 1170 9418 8476 50.7 59.3 159 BXRE-65E6501-C-7x 6500 80 1440 11591 10432 50.7 73.0 159 BXRE-65E6501-D-7x 6500 80 1400 7585 6827 33.4 46.8 162 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Décor Series Ultra, Décor Series Street and Landmark and Décor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 8 Performance at Commonly Used Drive Currents V Series LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRE-17E6500-D-74 80 BXRE-20B6501-C-73 65 BXRE-20B6501-D-73 65 BXRE-25E6500-D-74 80 BXRE-27E6500-B-7X 80 BXRE-27E6500-C-7x 80 BXRE-27E6500-D-7x 80 BXRE-27G65H0-B-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 2100 2800 720 960 1440 2160 2880 700 1050 1400 2100 2800 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 23.3 35.9 49.0 76.5 105.6 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 2241 3301 4340 6276 8082 6243 7941 11183 15660 19673 3778 5566 7318 10581 13626 3622 5336 7015 10143 13062 4996 6486 9337 13294 16868 6415 8160 11492 16092 20216 3882 5720 7520 10873 14002 4330 5621 8092 11521 14618 2065 3028 3906 5637 7185 5301 6946 10065 14397 18249 3482 5105 6586 9505 12114 3337 4893 6314 9112 11612 4622 5930 8403 11828 14856 5448 7138 10343 14794 18752 3578 5246 6768 9767 12448 4006 5139 7283 10250 12874 96 92 89 82 77 175 164 149 134 122 162 155 149 138 129 156 148 143 133 124 172 165 153 140 128 179 168 153 138 125 167 159 153 142 133 149 143 133 121 111 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-27G65H0-C-7x 90 BXRE-27G65H0-D-7x 90 BXRE-27G6500-B-7x 90 BXRE-27G6500-C-7x 90 BXRE-27G6500-D-7x 90 BXRE-27H6500-D-7x 97 BXRE-30C6501-B-74 70 BXRE-30C6501-C-74 70 BXRE-30C6501-D-74 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 5559 7072 9959 13946 17520 3364 4957 6517 9422 12134 4158 5398 7770 11064 14038 5338 6791 9564 13392 16824 3231 4760 6258 9048 11653 2814 4146 5451 7881 10149 5977 7603 10708 14994 18837 6804 10024 13179 19054 24539 4452 6559 8624 12469 16058 4721 6186 8963 12821 16251 3100 4546 5865 8464 10787 3847 4935 6993 9843 12363 4534 5940 8607 12312 15606 2977 4365 5632 8128 10359 2593 3802 4906 7080 9023 5076 6651 9637 13785 17473 6270 9193 11861 17117 21815 4103 6016 7762 11201 14275 156 146 133 119 109 145 138 133 123 115 143 137 128 116 107 149 140 128 114 104 139 132 128 118 110 121 115 111 103 96 206 193 176 157 143 190 207 176 163 152 191 182 176 163 152 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-30E6500-B-7x 80 BXRE-30E6500-C-7x 80 BXRE-30E6500-D-7x 80 BXRE-30G65H0-B-7x 90 BXRE-30G65H0-C-7x 90 BXRE-30G65H0-D-7x 90 BXRE-30G6500-B-7x 90 BXRE-30G6500-C-7x 90 BXRE-30G6500-D-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 5197 6747 9713 13830 17548 6673 8489 11955 16740 21030 4039 5950 7823 11311 14566 4525 5874 8457 12041 15278 5810 7391 10408 14575 18310 3516 5180 6811 9848 12682 4326 5615 8084 11510 14604 5554 7065 9949 13932 17502 3361 4952 6511 9413 12123 4808 6168 8742 12304 15454 5667 7425 10759 15390 19507 3722 5457 7041 10160 12949 4186 5371 7611 10713 13455 4934 6465 9367 13399 16984 3240 4751 6130 8846 11274 4002 5134 7275 10240 12862 4716 6180 8954 12808 16235 3097 4541 5860 8456 10777 179 171 160 145 133 187 175 160 143 131 174 166 160 148 138 156 149 139 126 116 163 153 139 125 114 151 144 139 129 120 149 143 133 121 111 155 146 133 119 109 144 138 133 123 115 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-30G650C-D-73 90 BXRE-30H6500-D-7x 97 BXRE-35E6500-B-7x 80 BXRE-35E6500-C-7x 80 BXRE-35E6500-D-7x 80 BXRE-35G6500-B-7x 90 BXRE-35G6500-C-7x 90 BXRE-35G6500-D-7x 90 BXRE-35A6501-D-73 93 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 2100 2800 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 700 1050 1400 2100 2800 33.2 34.2 35.0 36.4 37.7 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 33.2 34.2 35.0 36.4 37.7 23.3 35.9 49.0 76.5 105.6 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 23.3 35.9 49.0 76.5 105.6 3127 4607 6056 8757 11277 2996 4415 5804 8392 10807 5365 6965 10026 14276 18114 6888 8762 12340 17280 21708 4169 6142 8075 11675 15036 4460 5789 8334 11867 15057 5726 7284 10258 14364 18045 3465 5106 6713 9705 12499 3263 4808 6321 9139 11770 2881 4225 5451 7866 10025 2761 4049 5224 7538 9607 4963 6367 9024 12701 15952 5850 7665 11106 15886 20137 3842 5633 7268 10488 13367 4126 5293 7501 10558 13260 4863 6371 9232 13205 16739 3193 4682 6041 8718 11111 3007 4409 5689 8210 10463 134 128 123 114 107 129 123 118 110 102 185 177 165 150 138 193 181 165 148 135 179 171 165 153 142 154 147 137 125 115 160 150 137 123 112 149 142 137 127 118 140 134 129 119 111 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-40C6501-B-74 70 BXRE-40C6501-C-74 70 BXRE-40C6501-D-74 70 BXRE-40E6500-B-7x 80 BXRE-40E6500-C-7x 80 BXRE-40E6500-D-7x 80 BXRE-40G6500-B-7x 90 BXRE-40G6500-C-7x 90 BXRE-40G6500-D-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 6121 7787 10966 15356 19292 6968 10266 13497 19515 25131 4560 6718 8832 12770 16445 5399 7008 10089 14365 18227 6931 8817 12417 17388 21844 4195 6180 8126 11748 15130 4627 6007 8648 12313 15623 5941 7558 10643 14904 18724 3596 5298 6965 10070 12968 5198 6811 9870 14118 17895 6421 9415 12147 17530 22342 4202 6161 7949 11471 14620 4994 6407 9080 12780 16052 5886 7712 11176 15985 20263 3866 5668 7313 10554 13450 4281 5492 7783 10955 13759 5045 6611 9579 13702 17368 3313 4858 6268 9046 11529 211 198 180 161 147 195 212 180 167 156 196 187 180 167 156 186 178 166 151 139 194 182 166 149 136 180 172 166 153 143 159 153 142 129 119 166 156 142 127 116 155 147 142 132 123 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-40H6500-D-73 97 BXRE-50C6501-B-7x 70 BXRE-50C6501-C-7x 70 BXRE-50C6501-D-7x 70 BXRE-50E6501-B-7x 80 BXRE-50E6501-C-7x 80 BXRE-50E6501-D-7x 80 BXRE-50G6501-B-7x 90 BXRE-50G6501-C-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 3086 4547 5978 8643 11131 5935 7705 11092 15793 20038 7620 9694 13651 19116 24015 4612 6795 8933 12916 16633 5566 7226 10402 14811 18793 7147 9091 12803 17928 22523 4325 6372 8378 12113 15600 4728 6138 8836 12581 15963 6070 7722 10875 15228 19131 2844 4170 5380 7764 9895 5491 7044 9983 14051 17647 6471 8479 12286 17574 22276 4250 6231 8040 11603 14787 5149 6606 9362 13177 16551 6069 7952 11523 16482 20892 3986 5844 7540 10882 13868 4374 5611 7952 11193 14058 5155 6754 9787 14000 17745 133 126 122 113 105 204 196 182 166 152 213 200 182 163 149 198 189 182 169 158 192 183 171 155 143 200 188 171 153 140 186 177 171 158 148 163 156 145 132 121 170 159 145 130 119 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-50G6501-D-7x 90 BXRE-56G6501-D-7x 90 BXRE-57C6501-B-7x 70 BXRE-57C6501-C-7x 70 BXRE-57C6501-D-74 70 BXRE-57E6501-B-7x 80 BXRE-57E6501-C-7x 80 BXRE-57E6501-D-74 80 BXRE-65C6501-B-7x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 2100 2800 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 33.2 34.2 35.0 36.4 37.7 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 23.3 35.9 49.0 76.5 105.6 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 3674 5413 7116 10289 13250 3856 5681 7470 10800 13908 5734 7443 10716 15257 19359 7362 9365 13189 18468 23201 4455 6564 8630 12478 16070 5502 7142 10282 14640 18575 7064 8986 12655 17721 22262 4275 6299 8281 11973 15419 5835 7574 10904 15525 19699 3385 4964 6405 9243 11779 3554 5210 6723 9702 12364 5305 6805 9644 13574 17049 6252 8192 11870 16978 21521 4106 6020 7767 11209 14286 5090 6530 9254 13025 16359 5999 7860 11389 16291 20650 3940 5776 7453 10756 13707 5398 6924 9813 13812 17348 158 151 145 134 125 166 158 152 141 132 197 189 176 160 147 206 193 176 158 144 191 183 176 163 152 189 181 169 154 141 198 185 169 151 138 184 175 169 156 146 201 192 179 163 150 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-65C6501-C-7x 70 BXRE-65C6501-D-7x 70 BXRE-65E6501-B-7x 80 BXRE-65E6501-C-7x 80 BXRE-65E6501-D-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 7491 9529 13420 18792 23608 4534 6679 8782 12697 16351 5600 7269 10464 14900 18905 7189 9145 12879 18035 22657 4351 6410 8428 12185 15693 6362 8335 12078 17276 21899 4178 6126 7904 11406 14536 5180 6646 9418 13256 16649 6105 7999 11591 16580 21016 4010 5879 7585 10946 13951 210 197 179 161 147 195 186 179 166 155 193 185 172 156 144 201 189 172 154 141 187 178 172 159 149 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRE-xxx650x-B-7x BXRE-xxx650x-C-7x BXRE-xxx650x-D-7x Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.07 46.3 57.3 -22.1 0.09 50.2 61.8 55.9 -22.1 0.06 46.3 57.3 55.9 60.1 -22.1 0.08 50.0 61.6 32.4 35.0 37.6 -22.1 0.07 30.6 39.1 35.0 37.7 40.4 -22.1 0.08 33.2 41.8 Minimum Typical Maximum 1170 48.1 52.0 55.9 -22.1 2340 52.0 56.2 60.4 1440 48.1 52.0 2880 51.7 1400 2800 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 17 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRE-xxx650x-B-7x BXRE-xxx650x-C-7x BXRE-xxx650x-D-7x CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 6500K4 1170 RG1 RG1 RG1 RG1 1755 RG1 RG1 RG2 RG2 2340 RG1 RG2 RG2 RG2 1440 RG1 RG1 RG1 RG2 2160 RG1 RG1 RG2 RG2 2880 RG1 RG2 RG2 RG2 1400 RG1 RG1 RG1 RG1 2100 RG1 RG1 RG1 RG2 2800 RG1 RG1 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 18 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRE-xxx650x-B-7x BXRE-xxx650x-C-7x BXRE-xxx650x-D-7x Maximum Drive Current3 2340mA 2880mA 2800mA Maximum Peak Pulsed Drive Current4 3340mA 4110mA 4000mA Maximum Reverse Voltage5 -90V -90V -60V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 19 Performance Curves Figure 2: V22C Drive Current vs. Voltage 2500 3000 2000 2500 Forward Current (mA) Forward Current (mA) Figure 1: V22B Drive Current vs. Voltage 1500 1000 500 0 2000 1500 1000 500 47 48 49 50 51 52 53 54 55 56 0 57 47 48 49 50 Forward Voltage (V) 51 52 53 54 55 56 57 Forward Voltage (V) Figure 4: V22B Typical Relative Flux vs. Current Figure 3: V22D Drive Current vs. Voltage 200% 3000 180% 160% Relative Luminous Flux Forward Current (mA) 2500 2000 1500 1000 140% 120% 100% 80% 60% 40% 500 20% 0 30 31 32 33 34 35 36 37 38 0% 100 400 700 1000 1300 1600 1900 2200 2500 Forward Voltage (V) Forward Current (mA) Figure 6: V22D Typical Relative Flux vs. Current Figure 5: V22C Typical Relative Flux vs. Current 200% 180% 180% 160% 160% 140% 140% 120% Relative Luminous Flux Relative Luminous Flux 200% 100% 80% 60% 40% 120% 100% 80% 60% 40% 20% 20% 0% 0% 100 400 700 1000 1300 1600 1900 2200 2500 2800 0 500 1000 1500 2000 2500 3000 Forward Current (mA) Forward Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 20 Performance Curves Figure 7: Typical DC Flux vs. Case Temperature Figure 8: Typical DC ccy Shift vs. Case Temperature 0 50 75 100 125 Warm White Neutral White 100% 0.000 Cool White 25°C Pulsed 97% -0.003 ccy Shift Relative Luminous Flux 25 0.003 103% 94% -0.006 91% -0.009 88% Warm White -0.012 85% -0.015 82% 0 25 50 75 100 125 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Case Temperature (°C) Figure 9: Typical DC ccx Shift vs. Case Temperature 0 25 50 75 100 125 0.000 -0.002 ccx Shift -0.004 -0.006 -0.008 Warm White -0.010 -0.012 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Notes for Figures 7-9: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 21 Performance Curves Figure 10: 1750K Color Shift vs. Case Temperature1 Figure 11: 2500K Color Shift vs. Case Temperature1 0.3705 0.37 0.4145 Pulsed Center Point Tc = 25°C 15°C 15°C 0.414 25°C 0.4135 25°C 0.413 0.3695 0.369 ccy ccy 45°C 0.411 0.52 85°C 0.4115 105°C 0.5198 70°C 0.412 0.3685 0.368 0.5196 45°C 0.4125 70°C 85°C 0.5202 0.5204 0.5206 105°C 0.4105 0.468 0.47 0.472 15°C Pulsed Center Point Tc=25°C 25°C 0.401 25°C 45°C 0.4 45°C 0.4096 ccy ccy 15°C 0.402 Pulsed Center Point Tc=25°C 0.4097 0.4095 65°C 0.399 65°C 0.398 0.4094 85°C 0.4093 0.397 85°C 0.4092 0.396 105°C 0.4091 0.409 0.525 0.478 0.403 0.41 0.4098 0.476 Figure 13: 3000K, 90 CRI Color Shift vs. Case Temperature3 0.4101 0.4099 0.474 ccx ccx Figure 12: 2000K, 65 CRI Color Shift vs. Case Temperature Pulsed Center Point Tc = 25°C 0.526 0.527 0.528 0.529 0.53 0.531 0.532 ccx 0.395 0.444 105°C 0.4445 0.445 0.4455 0.446 0.4465 0.447 ccx Note for Figures 10-13: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRE-30G650C-x-73 22 Performance Curves Figure 14: 2700K, 97 CRI Color Shift vs. Case Temperature1 Figure 15: 3000K, 97 CRI Color Shift vs. Case Temperature1 0.4110 0.4050 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 25°C 45°C 0.4010 45°C ccy ccy 0.4080 Pulsed Center Point Tc = 25°C 15°C 0.4030 0.4090 0.4070 65°C 70°C 0.3990 0.4060 85°C 85°C 0.4050 0.3970 105°C 0.4040 105°C 0.4030 0.457 0.4572 0.4574 0.4576 0.4578 0.3950 0.4323 0.458 0.4328 0.4333 ccx 0.4338 0.4343 Figure 16: 5600K Color Shift vs. Case Temperature1,3 0.37 15°C 0.342 Pulsed Center Point Tc = 25°C 15°C 0.34 25°C 0.338 0.368 25°C 0.366 0.336 Pulsed Center Point Tc=25°C 45°C 45°C 0.334 ccy ccy 0.4353 Figure 17: 3500K Class A Color Shift vs. Case Temperature1 0.344 0.332 0.364 70°C 70°C 0.33 0.362 85°C 85°C 0.328 0.326 0.4348 ccx 0.36 105°C 105°C 0.324 0.322 0.32 0.322 0.324 0.326 0.328 0.33 ccx 0.358 0.392 0.393 0.394 0.395 0.396 0.397 ccx Note for Figures 14-17: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Color shift shown for product hot targeted at Tc=85°C 23 Typical Radiation Pattern Figure 18: Typical Spatial Radiation Pattern Note for Figure 18: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 19: Typical Polar Radiation Pattern 24 Typical Color Spectrum Figure 20: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 20: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 21: Typical Color Spectrum for Décor Series 1 17E 20B 0.9 25E 27H 0.8 30G (Décor Series Showcase) Relative Spectral Power Distribution 30H 56G 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 21: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 25 Mechanical Dimensions Figure 22: Drawing for V22 LED Array Notes for Figure 22: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Solder pad labeled “+” denotes positive contact. 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 26 Color Binning Information Figure 23: Graph of Warm and Neutral White Test Bins in xy Color Space 0.44 2500K 4SDCM 3 SDCM 4 SDCM 2000K 3SDCM 2700K 0.42 3000K 3500K 0.4 Y 4000K 1750K 4SDCM 0.38 0.36 0.34 0.36 0.39 0.42 0.45 X 0.48 0.51 0.54 Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2000K 2700K 3000K1 3500K1 4000K1 ANSI Bin (for reference only) - (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) - (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) - (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.5280, 0.4100) (0.4578, 0.4101) (0.4338, 0.403) (0.4465, 0.4024)2 (0.4073, 0.3917) (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Decor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. Figure 24: Graph of Cool White Test Bins in xy Color Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5600K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5310K - 6020K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5475K - 5830K) (5481K - 5829K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3293, 0.3423) (0.3287, 0.3417) (0.3123, 0.3282) Note for Table 9: 1. Select configurations with a CCT of 5600K are available with center point targets at Tc = 85°C or Tc = 25°C. 27 Packaging and Labeling Figure 25: Drawing for V22 Packaging Tube Notes for Figure 25: 1. Each tube holds 15 V22 COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box and shipped. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 30.7 (W) x 9.65(H) x 460(L). Dimensions for the anti-static bag are 75 (W) x 615 (L) x 3.1 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm. 28 Packaging and Labeling Figure 26: Gen. 7 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E4000C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 29 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 30 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2018 Bridgelux, Inc. All rights reserved 2018. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 7 V22 Array Series Product Data Sheet DS103 Rev. N (11/2018) 31
BXRE-30G650C-D-73 价格&库存
很抱歉,暂时无法提供与“BXRE-30G650C-D-73”相匹配的价格&库存,您可以联系我们找货
