COM-11452
COM-11452
    SPARKFUNELECTRONICS
    插件
    LED - 10MM CYCLING RGB (SLOW)
COM-11452 数据手册
深圳市旋彩电子有限公司 SHEN ZHEN XUAN CAI ELECTRONIC CO.,LTD SPECIFICATION 产品规格书 CUSTOMER : (客户) PART NO. : (产品型号) SPEC NO. : (规格书编号) : DATE (日期) FOR AFFIRM (供方确认) AFFIRM CHECKED PREPARED (核准) (审核) (制定) 刘小龙 www.xcled.com xc@xcled.com Tel:86-755-29015199 ; 29015299 prepared date:01-June-2011 PAGE:第 1 页 共 3 页 Fax:86-755-29015399 prepared by xiaolong 深圳市旋彩电子有限公司 SHEN ZHEN XUAN CAI ELECTRONIC CO.,LTD Red Green Light color color:Red Red、Green Green、 Blue Ta 25 Absolute maximum rating rating(Ta Ta=25 25℃) � Operating/Storage temperature range:-30℃~ +85℃ � Derating linear from 25℃:0.4 mA/℃ � Lead soldering temperature range:260℃ for 3 � Colloid Color:White Clear second � Life Test:20,000~50,000hours TA 25 Electro-optical characteristics characteristics(TA TA=25 25℃) RED COLOR COLOR: Parameter Symbol Min Typ. Max Unit Test Condition IF=20 mA Forward voltage VF � 2.00 2.25 Luminous intensity IV � 1000 1200 mcd Peak emission wavelength λp � 620 630 nm � Half intensity angle △Θ � 25 � deg � V IF=20 mA GREEN COLOR COLOR: Parameter Symbol Min Typ. Max Unit Test Condition IF=20 mA Forward voltage VF � 3.5 Luminous intensity IV � 1500 2000 mcd Peak emission wavelength λp � 515 525 nm � Half intensity angle △Θ � 25 � deg � 5 V IF=20 mA BLUE COLOR COLOR: Parameter Symbol Min Typ. Max Unit Test Condition IF=20 mA Forward voltage VF � 3.5 Luminous intensity IV � 1200 1500 mcd Peak emission wavelength λp � 460 470 nm � Half intensity angle △Θ � 25 � deg � Typ. 4.5 Max Unit 5.0 V 5 V IF=20 mA Direct Current Characteristics Parameter Operating voltage Symbol Min V DD 2.0 Remarks � Driver Current Iol � 50 � mA @VDS=1.2V Power Consumption Po � 225 � mW V DD=4.5V Ftet � 0.2 � Hz External±30% Flash Frequency *All specs and applications shown above subject to change without prior notice. (以上电路及规格仅供参考,本公司可进行修正) www.xcled.com xc@xcled.com Tel:86-755-29015199 ; 29015299 prepared date:01-June-2011 PAGE:第 2 页 共 3 页 Fax:86-755-29015399 prepared by xiaolong 深圳市旋彩电子有限公司 SHEN ZHEN XUAN CAI ELECTRONIC CO.,LTD Application diagram and Dimensions Output Sketch Map *All specs and applications shown above subject to change without prior notice. (以上电路及规格仅供参考,本公司可进行修正) www.xcled.com xc@xcled.com Tel:86-755-29015199 ; 29015299 prepared date:01-June-2011 PAGE:第 3 页 共 3 页 Fax:86-755-29015399 prepared by xiaolong
COM-11452 价格&库存
很抱歉,暂时无法提供与“COM-11452”相匹配的价格&库存,您可以联系我们找货
