5mm
3mm
(T1
Package
Package
Discrete
Discrete
LED
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER/GREEN,
RED/GREEN,
Tri-Color
RED/GREEN, Tri-Color
Bi-Color
5BC-3-CA-X
Industry Standard 5mm (T1 ¾) Package
RoHS Compliant
White Diffused Lens
Available in Flange (F) and Shouldered (Blank) Lead Frame
styles
3-Lead Bi-Color LED
Ideal for Status Indication and Display
Bivar 5mm T1 ¾ Package Tri-Color LED is ideal for those applications where multiple signals need to
be displayed at the same location such as standby-on indication for server or computer peripherals.
When needed, the 3rd color signal could be created by powering up both chips together for on-offstandy applications that require three distinct signals. Bivar offers white diffused LED lens for uniform
light output. The Flange LED is ideal for Panel Mount Clip & Ring assemblies and the Shouldered
Lead frame LED has a built in strain relief feature which is ideal for Right Angle Holder assemblies that
require lead bends. This 3-Lead Bi-Color LED package comes in a common anode Lead Frame configuration.
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
GaAsP/GaP
RED
625nm
GaP/GaP
GREEN
568nm
GaAsP/GaP
RED
625nm
GaP/GaP
GREEN
568nm
Part Number
5BC-3-CA-F
5BC-3-CA
Lens Appearance
Viewing Angle
White Diffused
40°
Part Number Designation
5 B C - 3 -X X - X X - X
LED Body, mm
Bi-Color
Tri-Lead
Lead Frame & Body Style
i.e. –F, Blank for Shouldered
• Common Anode, CA
• Common Cathode, “ ”
Emitted Colors, i.e. Y/G, “ ” for R/G
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision A 03/08
Page 1 of 6
3mm
(T1)¾)
Package
Discrete
LEDs
5mm (T1
Package
Discrete
LED
AMBER
RED/GREEN, Bi-Color
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision A 03/08
Page 2 of 6
3mm
(T1)¾)
Package
Discrete
LEDs
5mm (T1
Package
Discrete
LED
AMBER
RED/GREEN, Bi-Color
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
80 mW
Forward Current ( DC )
Peak Forward Current
30 mA
1
150 mA
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part
Emitted
Number Color
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
5BC-3CA-F
5BC-3CA
Red
2.0
2.8
Green
2.1
2.8
Red
2.0
2.8
Green
2.1
2.8
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
Notes: 1. Tolerance of forward voltage : ±0.05V.
MIN
Viewing
Angle
2Ө½
(deg)
Luminous
Intensity Iv
(mcd)
TYP MAX MIN TYP MAX
4
6
4
6
TYP
40
40
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 03/08
Page 3 of 6
3mm
(T1)¾)
Package
Discrete
LEDs
5mm (T1
Package
Discrete
LED
AMBER
RED/GREEN, Bi-Color
Typical Electrical / Optical Characteristics - Red
0°
Iv
10°
20°
30°
1.0
40°
40°
50°
0.5
60°
70°
80°
λ(nm)
0.0
550 600
650 700 750
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
Iv
90°
0.5
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
Iv (%)
1000
50
40
100
30
10
.01
1.2
Vf (V)
1.6
2.0 2.4
2.8 3.0
1
Fig. 3 Relative Intensity (10mA) vs.
Forward Voltage
50
If (mA)
1
10
100
1000
Fig. 4 Relative Luminous Intensity (%) vs.
Forward Current
If(mA)
400
Iv (%)
200
40
100
30
10
T (°C)
60
80
100
Fig. 5 Forward Current vs. Temperature
10
T (°C)
-20
0 20 40
60
80 100
Fig. 6 Relative Intensity (%) vs. Temperature
@ 20 mA
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 03/08
Page 4 of 6
3mm
(T1)¾)
Package
Discrete
LEDs
5mm (T1
Package
Discrete
LED
AMBER
RED/GREEN, Bi-Color
Typical Electrical / Optical Characteristics - Green
0°
10°
20°
30°
Iv
1.0
40°
40°
50°
60°
0.5
70°
80°
0.0
500
λ(nm)
550
600
650
@ 20mA
90°
0.5
0.3
0.1
0.2
0.4
0.6
If (mA)
Iv
1000
3.0
100
2.0
10
1.0
1
0.1
1.0
Vf (V)
2.0
3.0
4.0
5.0
Fig. 3 Forward Current vs. Forward Voltage
0.0
1
10
100
1000
If (mA)
Fig. 4 Relative Luminous Intensity vs. Forward Current
Normalize @ 20 mA
Vf (V)
Iv
3.0
1.2
1.1
2.0
1.0
1.0
0.9
0.8
T (°C)
-40
80
Fig. 5 Forward Voltage vs. Temperature
0.0
T (°C)
-40
80
Fig. 6 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 03/08
Page 5 of 6
3mm
(T1)¾)
Package
Discrete
LEDs
5mm (T1
Package
Discrete
LED
AMBER
RED/GREEN, Bi-Color
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A A
01/16/08
Revision
03/08
Page 6
4 of
of 6
4
Page
很抱歉,暂时无法提供与“5BC-3-CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.70768
- 10+3.81499
- 41+2.65073
- 112+2.50580
- 2000+2.49622
- 国内价格 香港价格
- 1+9.320141+1.12707
- 10+5.7214210+0.69188
- 100+3.88808100+0.47018
- 500+3.16780500+0.38308
- 1000+2.946601000+0.35633
- 2000+2.765282000+0.33440
- 5000+2.574745000+0.31136
- 10000+2.4604010000+0.29753
- 25000+2.3401725000+0.28299
