SUPERBRIGHT LED LAMP
VAOL-5LSBY1
Feature
Package Dimension
Low Power Consumption
High Intensity
I.C. compatible
Applications
Commercial Outdoor Sign Board
Front Panel Indicator
Dot-Matrix Module
Automotive
LED Bulb
Description
These High Intensity LEDs are Based on
InGaN/Sapphire Material Technology
Emitted color:Blue
Milkey Diffusion Lens
*Tolerance:± 0.01
0.25
Unit:±
inch
mm
Absolute Maximum Ratings at Ta=25℃
Symbol
Parameter
Max.
Unit
100
mW
PD
Power Dissipation
VR
Reverse Voltage
5
V
IAF
Average Forward Current
mA
IPF
Peak Forward Current(Duty=0.1,1kHz)
85
mA
Derating Linear Form 25℃
0.4
mA∕℃
Topr
Operating Temperature Range
–40 to + 80
Tstg
Storage Temperature Range
–40 to + 100
Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260℃ For 5 Seconds.
Electrical / Optical Characteristics and Curves at Ta=25℃
Symbol
Parameter
Test Condition
VF
Forward Voltage
IF= 20 mA
IR
Reverse Current
VR= 5
△θ
Half Intensity Angle
IF= 20 mA
60
Deg.
IV
Luminous Intensity
IF= 20 mA
1500
mcd.
λd
Dominant Wavelength
IF= 20 mA
470
nm
Min.
Typ.
3.5
V
Max. Unit
4.0
V
100
μA
Electrical Characteristics at Ta=25℃
Symbol
Iv
VF
λD
Parameter
Luminous Intensity
Forward Voltage
Dominant Wavelength
Condition
IF=20mA
IF=20mA
IF=20mA
Unit
mcd
V
nm
Grade
Range
Grade
Range
Grade
Range
BIN 16
950~1300
P1
3.0~3.2
B5
460~465
BIN 17
1300~1800
P2
3.2~3.4
B6
465~470
P3
3.4~3.6
B7
470~475
P4
3.6~3.8
P5
3.8~4.0
Intensity: Tolerance of minimum and maximum = ± 15%
Vf: Tolerance of minimum and maximum = ± 0.05v
NOTE:
1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist
band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery
must be properly grounded.
2. Specific binning requirements –please contact our home office
Radiation Diagram
IF=20 mA 50% Power Angle
Angle =60∘
BLUE
Typical Electro-optical Characteristic Curves
(25°C Free Air Temperature Unless Otherwise Specified)
很抱歉,暂时无法提供与“VAOL-5LSBY1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.204131+1.05744
- 10+5.7258210+0.73801
- 100+4.18998100+0.54005
- 500+3.50499500+0.45177
- 1000+3.280541000+0.42283
- 2000+3.089922000+0.39827
- 5000+2.881675000+0.37142
- 10000+2.7518210000+0.35469
- 25000+2.6103025000+0.33645
