4302F-5V, 4302F-12V Series
Integrated Resistor
5 Volts 12 Volts T-1 (3mm)
Through-hole LEDs with Built-in 5V and 12V Resistor in the standard T-1
(3mm) size LED package. Available in 3 colors and 60º viewing angle
Key Features
• Integral current limiting resistor
• Wide viewing angle: 60°.
• TTL compatible requires no external current limiter with 5V or 12V supply.
Electro-Optical Characteristics and Ratings
P AR T NUMB E R
Output C olor
Diffusion
P ackage C olor
R ated C urrent (mA)
F orward Voltage Typ. (V)
F orward V oltage Max. (V )
Luminous Intensity Min. (mcd)
Luminous Intensity T yp. (mcd)
C ontinuous F orward C urrent Max. (mA)
P eak Wavelength (nm)
Viewing Angle 20 1/ 2 (degrees)
Reverse Breakdown Voltage Min. (V)
Operating Temperature (°C)
Storage Temperature (°C)
Lead Solder Time at 260°C (sec.)
the first call for illuminated components
4302F 1-5V 4302F 3-5V 4302F 5-5V 4302F 1-12V 4302F 3-12V 4302F 5-12V
G reen
R ed
Amb er
Amber
R ed
G reen
Diffused
Diffused
Diffused
Diffused
Diffused
Diffused
G reen
R ed
Amber
Amber
G reen
R ed
13
13
10
13
10
10
12
5
12
5
12
5
15
15
7.5
15
7.5
7.5
2.0
2.1
2.0
2.0
2.0
2.0
8.0
8.0
8.0
8.0
8.0
8.0
565
635
583
635
583
565
60
60
60
60
60
60
5
5
5
5
5
5
-40 to +80 -40 to +85 -40 to +85 -40 to +85 -40 to +85 -20 to +85
-55 to +100 -55 to +100 -55 to +100 -55 to +100 -55 to +100 -55 to +100
5
5
5
5
5
5
www.vcclite.com
1
1.800.522.5546
11/16
Rev 1
Product Dimensions
.115±.010
2.92±0.25
.175±.010
4.45±0.25
.235±.015
5.97±0.38
.040
1.02
.950
24.13
MIN.
.018
0.46
SQ. NOM.
CATHODE
.050
1.27
NOM.
.100
2.54
.125±.010
Dimensions in inches [mm]
www.vcclite.com
2
1.800.522.5546
11/16 Rev 1
很抱歉,暂时无法提供与“4302F1-12V”相匹配的价格&库存,您可以联系我们找货
