R50RED-4-0045
R50RED-4-0045
    BIVAR
    DIP-4
    发光二极管/LED 红色 DIP-4 628nm 6000mcd
R50RED-4-0045 数据手册
4-Pin Super Flux Red LED Lamp Orca R Series (4.6mm Dome) R50RED-4-0045 ♦ ♦ ♦ ♦ ♦ ♦ RoHS Compliant Low Profile Dome Lens Automatic Insertion Compatible — Tubular Packaging Automatic Placement Compatible High Intensity Output High Power Efficiency Bivar R50RED-4-0045 comes with low profile package design incorporating higher forward current to maximize intensity while minimizing the number of LEDs required to achieve uniform and enhanced light distribution. Low power consumption with quick response time means savings in electricity. Bivar R50RED-4-0045 can be coupled with reflectors or lenses for optimal light distribution needs. Typical applications are automotive exterior lighting, decorative interior or exterior lighting, specialty stage lighting, and electronic signage. Part Number Material Emitted Color Intensity Typ. mcd Lens Color Viewing Angle R50RED-4-0045 AlGaInP/GaAs Red 6000 Water Clear 45° Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 CAUTION: LOOKING DIRECTLY AT LED WITHOUT SHIELDED EYES MAY CAUSE DAMAGE TO RETINA. Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision D 09/11 Page 1 of 4 4-Pin Super Flux Red LED Lamp R50RED-4-0045 Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 140 mW Forward Current ( DC ) 80 mA Peak Forward Current 1 160 mA Electrostatic Discharge ( Class1 ) 1000 V Reverse Voltage 5V Operating Temperature Range -25 ~ +80°C Storage Temperature Range -30 ~ +80°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical Characteristics TA = 25°C & I F = 50 mA unless otherwise noted Emitting Color Red Forward Voltage (V)1 Recommend Forward Current (mA) Reverse Viewing Luminous Dominant Current (µA) Angle 2 3 Wavelength (nm) Intensity (mcd) VR=5V 2 Ө ½ (deg) MIN TYP MAX TYP MAX MIN MAX MIN TYP TYP 2.0 2.4 2.8 50 10 620 635 5000 6000 45 Notes: 1. Tolerance of Forward Voltage : ±0.05V. 2. Tolerance of Dominant Wavelength : ±0.1nm. 3. Tolerance of Luminous Intensity : ±15%. Directivity Radiation TA = 25°C unless otherwise noted Relative Luminous Intensity vs. Radiation Angle Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision D 09/11 Page 2 of 4 4-Pin Super Flux Red LED Lamp R50RED-4-0045 Typical Electrical / Optical Characteristics Curves TA = 25°C unless otherwise noted Fig.5 Relative Luminous Intensity vs. Ambient Temperature Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision D 09/11 Page 3 of 4 4-Pin Super Flux Red LED Lamp R50RED-4-0045 Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan Bivar Orca R series Super Flux LEDs are packaged in tubes, each of which contains 60 LEDs; and each tube contains a rubber stopper at each end. Bivar reserves the right to make changes at any time. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision D 09/11 Page 4 of 4
R50RED-4-0045 价格&库存
很抱歉,暂时无法提供与“R50RED-4-0045”相匹配的价格&库存,您可以联系我们找货
