GB04001
GB04001
    ETHERTRONICS
    RF ANTENNA WIFI/ISM/BT/ZIGBEE
GB04001 数据手册
PRODUCT: Table Top Antenna 2.4GHz Part No. GB04001 PresttaTM WiFi/BT/ISM/Zigbee Embedded Antennas 2.4 GHz KEY BENEFITS DESIGN ADVANTAGES Ethertronics’ Prestta series of Isolated Magnetic Dipole™ (IMD) stamped metal antennas include an embedded Bluetooth design that delivers on the key needs of today’s wireless product designers: miniaturized design, superior signal sensitivity and high isolation properties that virtually eliminate de-tuning. Together, these features provide compelling advantages for IMD-enabled cell phones, handsets headphones, laptops and other wireless devices that utilize Bluetooth technology. TECHNOLOGY ADVANTAGES Stays in Tune The form factor of IMD antenna technology provides superior RF field containment, resulting in less interaction with surrounding components. Ethertronics IMD antennas resist de-tuning, which impairs the end-user Protecting Your Brand Name With consumer expectations high and competition formidable, you can’t afford end-user disappointment. The high isolation characteristics of IMD antennas offer you performance stability you can rely on, while their radically smaller volume and higher operating efficiencies provide you with the design freedom needed to create mobile and wireless products that set your brand apart from the competition. Quicker Time-to-Market  By optimizing antenna size, performance and emissions, customer and regulatory specifications are more easily met. Greater Flexibility  IMD technology helps you achieve more advanced product designs coupled with superior performance and a wider range of antenna placement options. RoHS Compliant  Ethertronics’ antennas are fully compliant with the European RoHS Directive 2002/95/EC. END USER ADVANTAGES Excels in Real-Life Conditions  IMD embedded Bluetooth antennas deliver better enduser performance in situations where consumers have high expectations of exceptional service.  Meets the ever-growing demand for smaller, thinner product designs by eliminating whip and stub antennas. Superior Network Coverage  Better network coverage means more reliable wireless connections for mobile phones, laptops, stereo headsets, cars, media players, audio systems and more. Faster Data Rates  Improved performance also means faster data rates for downloading e-mail, surfing the internet and watching mobile video. SERVICE AND SUPPORT Extensive RF Experience  Our design teams are composed of RF PhDs, project managers and a complete engineering team to support every project — from initial prototyping to TIS and TRP performance testing. Global Operations & Design Support  Ethertronics’ global operations supports an integrated network of design centers that can take projects from concept to production. ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: Embedded 2.4GHz Antenna - Table top type - P/N GB04001 Example: Ethertronics’ PresttaTM Bluetooth Embedded Antenna Specifications. Ethertronics produces a wide variety of standard and custom stamped metal antennas to meet user needs. Below are the typical specs. Electrical Specifications 2.390-2.490 GHz Typical Characteristics (inside an enclosure) Peak Gain Efficiency 1 dBi 65% VSWR Match 2.1 : 1 Feed Point Impedance Power Handling Mechanical Specifications Polarization Linear Dimensions 15x10x3 mm Mechanical Mounting RF Mounting Typical Efficiency, Return Loss 50 ohms unbalanced 2 Watt CW Metal on plastic carrier. Antenna Assembly is SMD mounted (by reflow). RF and Ground feed pads are SMD attached to main PCB. Efficiency (dB) Return Loss (dB) For demo board on edge 1.5nH_1.5pF_Board 1 (80x50) Frequency (MHz) Frequency (MHz) Antenna Radiation Patterns Typical Performance z y 2.390-2.490 GHz Band x Phi = 0o Plane 80deg 0deg z x Theta = 90o Plane Phi = 90o Plane 80deg 0deg z y 0deg 80deg y x © 2013 Ethertronics. All rights reserved. Ethertronics, the Ethertronics logo, shaping antenna technology, Prestta, Isolated Magnetic Dipole and the iMD logo are trademarks of Ethertronics. All other trademarks are the property of their respective owners. Specifications subject to change and are dependent upon actual implementation. GB04001 1May2013
GB04001 价格&库存
很抱歉,暂时无法提供与“GB04001”相匹配的价格&库存,您可以联系我们找货
