SM0805UHC
SM0805UHC
    BIVAR
    发光二极管/LED 0805
SM0805UHC 数据手册
SURFACE MOUNT LED HE RED, 0805 PACKAGE SM0805UHC ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 0805 Package RoHS Compliant Small Package and Footprint Water Clear Lens Wide Viewing Angle Ideal for Status Indication, Display, and Backlighting Bivar Surface Mount 0805 package LED may be used in nearly any lighting or indication application. The miniature package is ideal for small scale applications such as general indication and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment. Bivar offers water clear LED lens for maximum luminous intensity. Wide variety of wavelength and intensity combinations are available to meet any illumination need. The SM0805 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Peak Wavelength λp(nm) TYP. Lens Appearance Luminous Intensity (mcd) TYP. Viewing Angle SM0805UHC AlGaInP RED 645 Water Clear 115 130° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Level 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 1 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER HE RED, 0805 PACKAGE Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 78 mW Forward Current ( DC ) 30 mA Peak Forward Current 1 100 mA Reverse Voltage 5V Operating Temperature Range -30 ~ +80°C Storage Temperature Range -40 ~ +85°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX SM0805UHC / 2.1 2.6 / 20 Notes: 1. Tolerance of forward voltage : ±0.05V. / Reverse Dominant Current Wavelength (nm)2 (μA) Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MAX MIN TYP MAX MIN TYP MAX TYP 10 / 631 / 70 115 / 130 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 2 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER HE RED, 0805 PACKAGE Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 3 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER HE RED, 0805 PACKAGE Recommended Soldering Conditions Tape and Reel Dimensions Note: 4000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 4 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER HE RED, 0805 PACKAGE Packaging and Labeling Plan Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance unless otherwise noted: X.XXX ± 0.010" X.X ± 0.1” Note: 1 Reel / Bag Vacuum and Heat Sealed Clear AntiStatic Poly Bag Internal Quality Control X.XXX Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 03/09 Page Page 4 5 of of 4 5
SM0805UHC
物料型号:BIVAR SM0805UHC
器件简介: - 表面贴装LED,0805封装 - 符合RoHS标准 - 小型封装,适合小规模应用 - 低功耗,长寿命,适合电池供电设备 - 透明水光镜头,最大光强 - 提供多种波长和强度组合,满足不同照明需求 - 标准胶带和卷轴包装,适合自动拾取和放置装配
引脚分配: - 极性标识:0.049英寸(1.2毫米) - 引脚间距:0.032英寸(0.8毫米) - 引脚长度:0.012英寸(0.3毫米)
参数特性: - 发光颜色:红色 - 峰值波长:645纳米 - 发光强度:115毫坎德拉 - 视角:130度
功能详解: - 绝对最大额定值: - 功率耗散:78毫瓦 - 正向电流:30毫安(直流) - 峰值正向电流:100毫安 - 反向电压:5伏特 - 工作温度范围:-30至+80摄氏度 - 存储温度范围:-40至+85摄氏度 - 引脚焊接温度:260摄氏度(距离环氧灯泡底部3毫米处) - 电气/光学特性(25摄氏度,正向电流20毫安): - 正向电压:2.1至2.6伏特 - 反向电流:10毫安 - 主波长:631纳米 - 发光强度:70至115毫坎德拉
应用信息: - 表面贴装LED适用于指示灯、显示和背光等多种应用。
封装信息: - 推荐焊接条件: - 无铅焊接:最高255摄氏度,持续5秒 - 有铅焊接:最高220摄氏度,持续5秒 - 预热、前流、前流、冷却时间:140摄氏度至170摄氏度,20至70秒 - 胶带和卷轴尺寸:4000个/卷
注意事项: - 所有尺寸以英寸[毫米]为单位。 - 标准公差:±0.010英寸,除非另有说明。 - 注意静电敏感器件的处理。 - 湿度敏感等级4。
SM0805UHC 价格&库存
很抱歉,暂时无法提供与“SM0805UHC”相匹配的价格&库存,您可以联系我们找货
