VAOL-3GGE4
VAOL-3GGE4
    VCC
    径向
    Green 571nm LED Indication - Discrete 2.1V Radial
VAOL-3GGE4 数据手册
SUPERBRIGHT LED LAMP VAOL-3GGE4 Feature § § Package Dimension Low Power Consumption I.C. compatible Applications § § § § Commercial Outdoor Sign Board Front Panel Indicator Dot-Matrix Module LED Bulb Description § These LEDs are Based on AlInGaP/GaAsMaterial Technology § Emitted Color: GREEN § Water Transparent Lens *Tolerance:± 0.01 0.25 Unit:± Inch mm Absolute Maximum Ratings at Ta=25℃ Symbol Parameter Max. Unit 120 mW PD Power Dissipation VR Reverse Voltage 5 V IAF Average Forward Current 30 mA IPF Peak Forward Current(Duty=0.1,1kHz) 100 mA ― Derating Linear Form 25℃ 0.4 mA∕℃ Topr Operating Temperature Range –40 to + 85 ℃ Tstg Storage Temperature Range –40 to + 100 ℃ Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260℃ For 5 Seconds. Electrical / Optical Characteristics and Curves at Ta=25℃ Symbol Parameter Test Condition VF Forward Voltage IF= 20 mA IR Reverse Current VR= 5 △θ Half Intensity Angle IF= 20 mA 30 Deg. IV Luminous Intensity IF= 20 mA 1300 mcd. λd Peak Wavelength IF= 20 mA 570 nm Min. Typ. Max. Unit 2.1 V 2.4 V 100 μA Electrical Characteristics at Ta=25℃ Symbol Parameter Condition Unit Binning Iv VF λD Luminous Intensity Forward Voltage Dominant Wavelength IF=20mA IF=20mA IF=20mA mcd V nm Grade Range Grade Range Grade Range BIN 16 950~1300 C 1.9~2.0 G9 569~571 BIN 17 1300~1800 D 2.0~2.1 G10 571~573 E 2.1~2.2 F 2.2~2.3 G 2.3~2.4 Intensity: Tolerance of minimum and maximum = ± 15% Vf: Tolerance of minimum and maximum = ± 0.05v NOTE: 1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery must be properly grounded. 2. Specific binning requirements –please contact our home office Radiation Diagram IF=20 mA 50% Power Angle Angle =30∘ GREEN Typical Electro-optical Characteristic Curves (25°C Free Air Temperature Unless Otherwise Specified) Fig 2. Relative Intensity vs. Forward Current Fig 1. Forward Current vs. Forward Voltage 3.0 Relative Intensity Normalize @ 20 mA Forward Current (mA) 1000 100 10 1 0.1 1.0 2.5 2.0 1.5 1.0 0.5 0.0 1.5 2.0 2.5 3.0 1 10 Forward Voltage(V) 1.1 1.0 0.9 0 20 40 60 80 100 Relative Intensity @ 20 mA Fig 5. Relative Intensity vs. Wavelength 1.0 0.5 600 650 Wavelength(nm) 3.0 2.5 2.0 1.5 1.0 0.5 0.0 - 40 - 20 0 20 40 60 Ambient Temperature( C) Ambient Temperature( C) 0.0 550 Relative Intensity @ 20 mA Normalize @ 25 C Forward Voltage @ 20 mA Normalize @ 25 C 1.2 - 20 1000 Fig 4. Relative Intensity vs. Temperature Fig 3. Forward Voltage vs. Temperature 0.8 - 40 100 Forward Current(mA) 700 80 100
VAOL-3GGE4 价格&库存
很抱歉,暂时无法提供与“VAOL-3GGE4”相匹配的价格&库存,您可以联系我们找货
