SUPERBRIGHT LED LAMP
VAOL-3GRE4
Feature
Package Dimension
Low Power Consumption
I.C. compatible
Applications
Commercial Outdoor Sign Board
Front Panel Indicator
Dot-Matrix Module
LED Bulb
Description
These LEDs are Based on
AlInGaP/GaAsMaterial Technology
§ Emitted Color: RED
§ Water Transparent Lens
*Tolerance:± 0.01
0.25
Unit:±
Inch
mm
Absolute Maximum Ratings at Ta=25℃
Symbol
Parameter
Max.
Unit
120
mW
PD
Power Dissipation
VR
Reverse Voltage
5
V
IAF
Average Forward Current
30
mA
IPF
Peak Forward Current(Duty=0.1,1kHz)
100
mA
Derating Linear Form 25℃
0.4
mA∕℃
Topr
Operating Temperature Range
–40 to + 85
Tstg
Storage Temperature Range
–40 to + 100
Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260℃ For 5 Seconds.
Electrical / Optical Characteristics and Curves at Ta=25℃
Symbol
Parameter
Test Condition
VF
Forward Voltage
IF= 20 mA
IR
Reverse Current
VR= 5
△θ
Half Intensity Angle
IF= 20 mA
30
Deg.
IV
Luminous Intensity
IF= 20 mA
2000
mcd.
λd
Peak Wavelength
IF= 20 mA
625
nm
Min.
Typ. Max. Unit
2.1
V
2.4
V
100
μA
Electrical Characteristics at Ta=25℃
Symbol
Parameter
Condition
Unit
Binning
Iv
VF
λD
Luminous Intensity
Forward Voltage
Dominant Wavelength
IF=20mA
IF=20mA
IF=20mA
mcd
V
nm
Grade
Range
Grade
Range
Grade
Range
BIN 17
1300~1800
C
1.9~2.0
O2
620~625
BIN 18
1800~2500
D
2.0~2.1
O3
625~630
E
2.1~2.2
F
2.2~2.3
G
2.3~2.4
Intensity: Tolerance of minimum and maximum = ± 15%
Vf: Tolerance of minimum and maximum = ± 0.05v
NOTE:
1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist
band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery
must be properly grounded.
2. Specific binning requirements –please contact our home office
Radiation Diagram
IF=20 mA 50% Power Angle
Angle =30∘
RED
Typical Electro-optical Characteristic Curves
(25°C Free Air Temperature Unless Otherwise Specified)
Fig 1. Forward Current vs. Forward Voltage
Fig 2. Relative Intensity vs. Forward Current
3.5
Relative Intensity
Normalize @ 20 mA
Forward Current (mA)
1000
100
10
1
0.1
1.0
3.0
2.5
2.0
1.5
1.0
0.5
0.0
1.5
2.0
2.5
3.0
1
10
Forward Voltage(V)
1.1
1.0
0.9
60
80
100
Relative Intensity @ 20 mA
Fig 5. Relative Intensity vs. Wavelength
1.0
0.5
610
660
Wavelength(nm)
3.0
2.5
2.0
1.5
1.0
0.5
0.0
- 40
- 20
60
Ambient Temperature( C)
0.0
560
Normalize @ 25 C
Forward Voltage @ 20 mA
Normalize @ 25 C
1.2
- 20
1000
Fig 4. Relative Intensity vs. Temperature
Fig 3. Forward Voltage vs. Temperature
0.8
- 40
100
Forward Current(mA)
710
80
100
很抱歉,暂时无法提供与“VAOL-3GRE4”相匹配的价格&库存,您可以联系我们找货
