engineered to light up your design
www.vcclite.com
1.800.522.5546
CMDA5 Series 0805 Package Size Surface Mount LED
Description and Features
Features
• Small size
• Industry standard 0805
Footprint
• Compatible with IR solder
profiles
• Diffused optics
• Top emitting
• Ideal for use with Light
Pipes
• Available in 8 mm tape on
7” (178 mm) diameter
reels
• Packaged 4,000 pieces
per reel
• RoHS Compliant
NOTES:
1. All dimensions are in millimeters (in).
2. 1 micro second @ 10% duty cycle
Applications
• Keypad backlighting
• Push-button
backlighting
• LCD backlighting
• Symbol backlighting
• Front panel indicator
Electro-Optical Characteristics and Ratings
Part
Number
Output
Color
Diffusion
Package
Color
Test
Current
(mA)
Forward
Voltage
Typ. (V)
Forward
Luminous
Voltage
Intensity
Max. Typ. (V) Min. (mcd)
Luminous
Intensity
Typ. (mcd)
Peak
Wavelength
(nm)
Viewing
Angle
(Degrees)
CMDA5AY7D1S
Green
Diffused
Clear
2.6
4.0
15
570
170
CMDA5BR7D1S
HE Red
Diffused
Clear
2.6
2.5
10
630
170
CMDA5DR7D1S
Red
Diffused
Clear
2.6
6.3
17
660
170
Absolute Maximum Ratings to = 25°C
Part
Number
Power
Dissipation
(mW)
Operating
Temperature
(°C)
Storage
Temperature
(°C)
Peak Forward
Current Max.
(See note 2) (mA)
Reverse Voltage
(IR = 100 mA)
(V)
Lead Solder Time
at 230°C
(Seconds)
AY
52
-30 to +85
-40 to +85
100
5
10
BR
52
-30 to +85
-40 to +85
100
5
10
DR
65
-30 to +85
-40 to +85
100
5
10
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
很抱歉,暂时无法提供与“CMDA5AY7D1S”相匹配的价格&库存,您可以联系我们找货
