CMD11504G
CMD11504G
    VCC
    SMD
    发光二极管/LED SMD
CMD11504G 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CMD11504 Series Bright Angle™ Right Angle Surface Mount LED Description and Features All dimensions in mm. • Right angle mounting. • Compact size: 3.00mm x 1.00mm x 2.00mm • High brightness LED DIE 1.00 Surface Mount Technology • Tape and reel packaged for high-speed autoinsertion. • Convection and vapor-phase reflow compatible. • Compact form enables high density placement. • Packaged 3000 pieces per reel. • RoHS Compliant 0.30 TYP.(2) 3.00 LIGHT OUTPUT 2.00 PLASTIC Leading Edge LED Optoelectronic Performance • Consistent high brightness. 2.00 SUBSTRATE PIN CONNECTION MARK CATHODE (-) 1.00 SOLDER PAD FOR REINFORCEMENT ANODE(+) Exceptional Reliability • Stringent process controls assure quality. • Extensive qualification testing to meet strictest requirements. • Designed to permit easy post-reflow solder joint inspection. • Refer to “Solder Pad Geometry 3.pdf” 0.30 TYP.(2) 0.45 1.00 Electro-Optical Characteristics and Ratings Part Number CMD11504UR CMD11504Y CMD11504G Source (Dice) Red Yellow Green Package Color Water Clear Water Clear Water Clear Luminous Intensity @20ma Min. (mcd) 6.6 1.6 3.0 Forward Voltage Typ. (mcd) Typ. (V) Max. (V) Viewing Angle (degrees) Peak Wavelength (nm) 13.2 3.2 16.0 1.7 2.2 2.1 2.0 2.5 2.5 100 100 100 660 580 560 CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: VCC: CMD11504G CMD11504UR CMD11504Y CMD11504R/G
CMD11504G 价格&库存
很抱歉,暂时无法提供与“CMD11504G”相匹配的价格&库存,您可以联系我们找货
