SM0603AC
SM0603AC
    BIVAR
    发光二极管/LED 琥珀色 0603 607nm 6mcd
SM0603AC 数据手册
CC SM0603AC  Industry Standard 0603 Package  RoHS Compliant  Small Package and Footprint  Water Clear Lens  Wide Viewing Angle  Ideal for Status Indication, Display, and Backlighting Bivar Surface Mount 0603 package LED may be used in nearly any lighting or indication application. The miniature package is ideal for small scale applications such as general indication and backlighting. Low power consumption and excellent long life reliability are suitable for battery powered equipment. Bivar offers water clear LED lens for maximum luminous intensity. Wide variety of wavelength and intensity combinations are available to meet any illumination need. The SM0603 LED is packaged in standard tape and reels for pick and place assemblies. Part Number Material Emitted Color Peak Wavelength λp(nm) TYP. Lens Appearance Luminous Intensity (mcd) TYP. Viewing Angle SM0603AC GaAsP AMBER 610 Water Clear 7.2 130° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 05/22 Page 1 of 6 Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 78 mW Forward Current (DC) 30 mA Peak Forward Current 1 100 mA Reverse Voltage 5V Operating Temperature Range -40 - +85°C Storage Temperature Range -40 - +85°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 260°C Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & IF = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX SM0603AC 1.8 2.0 2.6 / Notes: 1. Tolerance of forward voltage : ±0.05V. 20 / Reverse Dominant Luminous Current Wavelength (nm)2 Intensity Iv (mcd)3 (μA) Viewing Angle 2Ө½ (deg) MAX MIN TYP MAX MIN TYP MAX TYP 10 / 606 / 3.6 7.2 11.5 130 2. Tolerance of dominant wavelength : ±1.0nm. 3. Tolerance of luminous intensity : ±10% Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 05/22 Page 2 of 6 Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 05/22 Page 3 of 6 Recommended Soldering Conditions Temp. ( ̊C ) a 25 b 150 c 200 d 220 e 245 f Max. 260 Belt Speed Time T0~T1 T1~T2 T2~T4 T3~T6 Max. 3 ̊C/sec 90~130 sec Max. 3 ̊C/sec Max. 50 sec T5~T7 Max. 10 sec Max. -3 ̊C/sec 70~90 cm/min Soldering Iron 1. Temperature at tip of iron: 300 ̊C Max. (25W Max.) 2. Soldering time: 5 ± 1 sec. Precautions For Use 1. Customer must apply resistors for protection and stability. Using Circuit B in the diagram below is recommended. Using Circuit A can result in LED burnout. 2. Current change may lead to LED color change. If there is a large difference between the spectral color separation current and actual service current, a color difference may occur. 3. Utilize forward current for LED operation. Subjecting the LED to continuous reverse voltage may cause damage to the die. Handling Precautions 1. When handling the product with tweezers, be careful to not damage the resin. The resin can be cut, chipped, delaminated, or deformed, which can lead to wire-bond breaks. 2. 3. 4. 5. Reflow soldering must not be performed more than twice. Hand soldering must not be performed more than once. When soldering, do not put stress on the LEDs during heating. LEDs are sensitive to static electricity or voltage surges. ESD can damage a die and its reliability. Do not stack assembled PCBs together. When stacked, PCBs with soldered LEDs can damage the resin surrounding the die, leading to failure. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 05/22 Page 4 of 6 Storage 1. The storage temperature and R.H. are 5 ̊C ~30 ̊C, R.H. 60% Max. 2. Once the package is opened, the products should be used within 72 hrs. Otherwise, they should be kept in a dampproof box with a desiccating agent. Considering the tape life, we suggest using the product 1 year of production date. 3. It’s recommended to bake at 70 ̊C ± 5 ̊C for 24 hrs before soldering them after the package is unsealed for 72 hrs. Tape and Reel Dimensions Note: 4000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 05/22 Page 5 of 6 2.8 [70mm] Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance unless otherwise noted: X.XXX ± 0.010" X.X ± 0.1” Packaging and Labeling Plan Note: 1 Reel / Bag Vacuum and Heat Sealed Clear AntiStatic Poly Bag Internal Quality Control Label Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision B 05/22 Page 6 of 6
SM0603AC 价格&库存
很抱歉,暂时无法提供与“SM0603AC”相匹配的价格&库存,您可以联系我们找货
SM0603AC
  • 1+4.04377
  • 10+3.37181
  • 100+2.69864
  • 500+2.42315
  • 1000+2.29379
  • 2000+2.09136
  • 4000+1.88893
  • 6000+1.75118
SM0603AC
  • 1+4.356371+0.56387
  • 10+3.6317710+0.47008
  • 100+2.90716100+0.37629
  • 500+2.61033500+0.33787
  • 1000+2.470651000+0.31979
  • 2000+2.252402000+0.29154
  • 4000+2.034144000+0.26329
  • 6000+1.885736000+0.24408
