VAOL-S8SYGC-2012511-C 数据手册
0805 SMD TYPE LED
Features
․Fit automatic placement equipment.
․Fit Compatible with infrared and vapor phase
reflow solder process.
․Pb-free.
․RoHS compliant.
Descriptions
․For higher packing density .
․For minature applications .
․Water clear lens .
․Chip material : AlGaInP .
․Emitting color : Yellow Green .
Package Outline Dimensions
Note: The tolerances unless mentioned is
±0.1mm ,Unit = mm
0805 SMD TYPE LED
Absolute Maximum Ratings (Ta=25℃)
Parameter
Symbol
Rating
Unit
Reverse Voltage
VR
5
V
Forward Current
Operating Temperature
IF
Topr
25
-40 ~ +85
mA
Storage Temperature
Tstg
-40~ +90
ESD
2000
V
Pd
60
mW
IFP
60
mA
Electrostatic
Discharge(HBM)
Power Dissipation
Peak Forward Current
(Duty 1/10 @1KHz)
Reflow Soldering : 260
Soldering Temperature
Tsol
Hand Soldering : 350
℃ for 10 sec.
for 3 sec.
Electro-Optical Characteristics (Ta=25℃)
Parameter
Luminous Intensity
Symbol
Iv
*Chip
Rank
Min.
Typ.
Max.
E1
12
17
E2
17
23
E3
22
31
E4
27
41
Unit
Condition
mcd
Viewing Angle
Peak Wavelength
2θ1/2
λp
140
575
deg
nm
Dominant Wavelength
λd
573
nm
Spectrum Radiation
Bandwidth
△λ
nm
Forward Voltage
VF
1.7
2.0
2.4
V
Reverse Current
IR
10
μA
IF=20 mA
VR=5V
0805 SMD TYPE LED
Typical Electro-Optical Characteristics Curves
0805 SMD TYPE LED
Reel Dimensions
±0.1mm ,Unit = mm
0805 SMD TYPE LED
Carrier Tape Dimensions: Loaded quantity3000 PCS per reel
±0.1mm , Unit = mm
Moisture Resistant Packaging
Label
Aluminum
moisture-proof
bag
Desiccant
Label
0805 SMD TYPE LED
Soldering Condition
1.Pb-free solder temperature profile
2.Reflow soldering should not be done more than two times.
3 When soldering, do not put stress on the LEDs during heating.
4 After soldering, do not warp the circuit board.
Soldering Iron
Each terminal is to go to the tip of soldering iron temperature less than 350℃
for 3 seconds within
once in less than the soldering iron capacity 25W. Leave two seconds and more intervals, and do soldering
of each terminal. Be careful because the damage of the product is often started at the time of
the hand solder.
VAOL-S8SYGC-2012511-C 价格&库存
很抱歉,暂时无法提供与“VAOL-S8SYGC-2012511-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.37676
- 200+0.94835
- 500+0.91671
- 1000+0.90105
