3mm
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
TURQUOISE,
BLUE,
YELLOW,
AMBER,
GREEN,
Low
Ultra
5V
12V
Extended
Ultra
Super
Low
Current
Bright
Ultra
Bright
Current
Bright
Profile
Bright
GREEN,
Extended
Profile
B
3GX-201-X
Industry Standard 3mm (T1) Package
RoHS Compliant
Water Clear (C), Diffused (D), and Tinted (T) Lenses
Available in a Shouldered (S) Lead Frame styles
Ideal for Status Indication and Display
Bivar 3mm T1 Package Extended Profile LED may be used in almost any application and provides additional protrusion for those applications with thicker face plates. Bivar offers water clear LED lens for
maximum light output, diffused LED lens for uniform light output, and tinted lens to identify the color of
the LED. The Shouldered Lead frame LED is ideal for vertical spacer assemblies without lead bends
and also has a built in strain relief feature which is ideal for right angle holder assemblies that require
lead bends.
Part Number
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
3GC-201-S
3GD-201-S
GaP/GaP
GREEN
568nm
3GT-201-S
Lens Appearance
Viewing Angle
Water Clear
20°
Green Diffused
35°
Green Tinted
20°
Part Number Designation
3 X X-2 0 1 - X
LED Body, mm
Emitted Color
Lens Appearance
Lead Frame & Body Style
i.e. -S, Shouldered
Extended Profile
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com
Revision C 06/15
Page 1 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
TURQUOISE,
YELLOW,
AMBER,
GREEN,
BLUE,
Low
Ultra
Extended
Low
5V
12V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Profile
Bright
GREEN,
Extended
Profile
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision C 06/15
Page 2 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
TURQUOISE,
YELLOW,
AMBER,
GREEN,
BLUE,
Low
Ultra
Extended
Low
5V
12V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Profile
Bright
GREEN,
Extended
Profile
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
80 mW
Forward Current ( DC )
Peak Forward Current
30 mA
1
150 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb )
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
40
35
3GT-201
40
3GC-201-S
40
35
40
3GC-201
3GD-201
3GD-201-S
2.1
2.1
2.8
2.8
100
3GT-201-S
Notes: 1. Tolerance of forward voltage : ±0.05V.
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision C 06/15
Page 3 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
TURQUOISE,
YELLOW,
AMBER,
GREEN,
BLUE,
Low
Ultra
Extended
Low
5V
12V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Profile
Bright
GREEN,
Extended
Profile
Typical Electrical / Optical Characteristics
0°
Iv
10°
20°
30°
1.0
40°
20°
50°
35°
0.5
60°
70°
80°
0.0
500
90°
λ(nm)
550
600
0.5
650
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
If (mA)
Iv
1000
3.0
100
2.0
10
1.0
1
0.1
1.0
Vf (V)
2.0
3.0
4.0
5.0
Fig. 3 Forward Current vs. Forward Voltage
0.0
1
10
100
1000
If (mA)
Fig. 4 Relative Luminous Intensity vs. Forward Current
Normalize @ 20 mA
Vf (V)
Iv
3.0
1.2
1.1
2.0
1.0
1.0
0.9
0.8
T (°C)
-40
80
Fig. 5 Forward Voltage vs. Temperature
0.0
T (°C)
-40
80
Fig. 6 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision C 06/15
Page 4 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
TURQUOISE,
YELLOW,
AMBER,
GREEN,
BLUE,
Low
Ultra
Extended
Low
5V
12V
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Profile
Bright
GREEN,
Extended
Profile
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
Anti-Static Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 Web:
E-mail:
bivar@bivar.com Web: www.bivar.com
Phone: (949)
www.bivar.com
Rev. A C
01/16/08
Revision
06/15
Page
Page 4
5 of
of 4
5
