3HC-F
3HC-F
    BIVAR
    T-1
    发光二极管/LED 径向
3HC-F 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER GREEN RED RED 3HX-X ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant Water Clear (C), Diffused (D), and Tinted (T) Lenses Available in Flange (F) and Shouldered (S) Lead Frame styles Ideal for Status Indication and Display Bivar 3mm T1 Package LED may be used in almost any application. Bivar offers water clear LED lens for maximum light output, diffused LED lens for uniform light output, and tinted lens to identify the color of the LED. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies. The Shouldered Lead frame LED is ideal for vertical spacer assemblies without lead bends and also has a built in strain relief feature which is ideal for right angle holder assemblies that require lead bends. Part Number Viewing Angle 3HC-F Water Clear 20° 3HD-F Red Diffused 35° Red Tinted 20° Water Clear 30° 3HD-S Red Diffused 40° 3HT-S Red Tinted 30° 3HC-S Emitted Color Peak. Wavelength λp(nm) TYP. Lens Appearance 3HT-F Material GaAsP/GaP 625nm RED Part Number Designation 3 X X - X LED Body, mm Emitted Color Lead Frame & Body Style i.e. -F, -S Lens Appearance ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 1 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER GREEN RED Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 2 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER GREEN RED Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 80 mW Forward Current ( DC ) 30 mA Peak Forward Current 1 150 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX Reverse Dominant Current Wavelength (nm)2 (μA) MAX Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 50 / 20 / / / / 30 / 35 3HT-F / / / / 50 / 20 3HC-S / / / / 50 / 30 / / / / 30 / 40 / / / / 50 / 30 3HC-F 3HD-F 3HD-S / / 2.0 2.0 2.8 2.8 / / 20 20 / 100 / 100 3HT-S Notes: 1. Tolerance of forward voltage : ±0.05V. 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 3 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER GREEN RED Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° Iv 20° 10° 30° 1.0 40° 20° 30° 35° 0.5 50° 40° 60° 70° 80° λ(nm) 0.0 550 600 650 700 750 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA 90° 0.5 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Iv Iv (%) 50 1000 40 100 30 20 10 10 .01 1.2 Vf (V) 1.6 2.0 2.4 2.8 3.0 1 Fig. 3 Relative Intensity (10mA) vs. Forward Voltage 50 If (mA) 1 10 100 1000 Fig. 4 Relative Luminous Intensity (%) vs. Forward Current If(mA) 400 Iv (%) 200 40 100 30 20 50 10 20 T (°C) 0 0 20 40 60 80 100 Fig. 5 Forward Current vs. Temperature 10 T (°C) -20 0 20 40 60 80 100 Fig. 6 Relative Intensity (%) vs. Temperature @ 20 mA Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 4 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER GREEN RED Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan Anti-Static Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 Web: E-mail: bivar@bivar.com Web: www.bivar.com Phone: (949) www.bivar.com Rev. A C 01/16/08 Revision 06/15 Page Page 4 5 of of 4 5
3HC-F 价格&库存
很抱歉,暂时无法提供与“3HC-F”相匹配的价格&库存,您可以联系我们找货
