3mm
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
GREEN,
YELLOW,
Super
Bright
Bright
YELLOW,Super
Super
Bright
B
3SYX-X
Industry Standard 3mm (T1) Package
RoHS Compliant
Water Clear (C), Diffused (D), and Tinted (T) Lenses
Available in Flange (F), Standard (Blank), and Shouldered
(S) Lead frame styles
Up to 50 mcd Luminous Intensity at 20 mA
Ideal for Status Indication and Display
Recommended for Bivar Flexible Light Pipe assemblies
Bivar 3mm T1 Package Super Bright LED is ideal for those applications where higher ambient lighting
exists such as sign boards, security system displays, and medical applications. Bivar offers water
clear LED lens for maximum light output, diffused LED lens for uniform light output, and tinted lens to
identify the color of the LED. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies, the
Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends, and the Shouldered Lead frame LED has a built in strain relief feature which is ideal for Right Angle Holder assemblies that require lead bends. A long lead version is also available with a “-LL” suffix added to part
numbers.
Part Number
Emitted Color
Peak. Wavelength
λp(nm) TYP.
Lens Appearance
Viewing Angle
3SYC-F
Water Clear
20°
3SYD-F
Yellow Diffused
35°
3SYT-F
Yellow Tinted
20°
3SYC
Water Clear
30°
Yellow Diffused
40°
3SYT
Yellow Tinted
30°
3SYC-S
Water Clear
30°
3SYD-S
Yellow Diffused
40°
3SYT-S
Yellow Tinted
30°
3SYD
Material
GaAsP/Gap
YELLOW
590nm
Part Number Designation
3 S X X -X
LED Body, mm
Super Bright
Emitted Color
Lead Frame & Body Style
i.e. -F, -S, Blank for Standard
Lens Appearance
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision B 04/09
Page 1 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
GREEN,
Bright
YELLOW,Super
Super
Bright
Outline Dimensions
Flanged “3SXX-F” LED
Standard “3SXX” LED
Shouldered Lead “3SXX-S” LED
Standard Lead Only
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision B 04/09
Page 2 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
GREEN,
Bright
YELLOW,Super
Super
Bright
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
85 mW
Forward Current ( DC )
30 mA
Peak Forward Current 1
150 mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 20 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
50
35
3SYT-F
50
3SYC
50
30
30
40
3SYT
50
30
3SYC-S
50
30
30
40
50
30
3SYC-F
3SYD-F
3SYD
3SYD-S
2.0
2.0
2.0
2.8
2.8
2.8
3SYT-S
Notes: 1. Tolerance of forward voltage : ±0.05V.
100
100
100
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 04/09
Page 3 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
GREEN,
Bright
YELLOW,Super
Super
Bright
Typical Electrical / Optical Characteristics
0°
10°
20°
30°
Iv
1.0
40°
20°
30°
35°
50°
40°
0.5
60°
70°
80°
λ(nm)
0.0
500
550
600
650
90°
0.5
700
Fig. 1 Relative Luminous Intensity vs. Wavelength
@ 20mA
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
If (mA)
Iv
1000
3.0
100
2.0
10
1.0
1
0.1
1.0
2.0
3.0
4.0
5.0
Vf (V)
Fig. 3 Forward Current vs. Forward Voltage
0.0
1.1
10
100
If (mA)
1000
Fig. 4 Relative Luminous Intensity vs. Forward Current
Normalize @ 20 mA
Vf (V)
1.2
1
Iv
3.0
2.0
1.0
0.9
0.8
T (°C)
-40
80
Fig. 5 Forward Voltage vs. Temperature
1.0
0.0
T (°C)
-40
80
Fig. 6 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision B 04/09
Page 4 of 5
3mm
LEDs
3mm (T1)
(T1) Package
Package Discrete
Discrete LED
LED
AMBER
AMBER,
GREEN,
Bright
YELLOW,Super
Super
Bright
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A B
01/16/08
Revision
04/09
Page
Page 4
5 of
of 4
5
