3YT-201-S
3YT-201-S
    BIVAR
    径向
    LEDYELLOWCLEAR3MMROUNDT/H
3YT-201-S 数据手册
3mm 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, BLUE, AMBER, GREEN, YELLOW, Low Ultra 5V 12V Ultra Super Low Extended Current Bright Ultra Bright Current Bright Bright Profile YELLOW, Extended Profile B 3YX-201-X ♦ ♦ ♦ ♦ ♦ Industry Standard 3mm (T1) Package RoHS Compliant Water Clear (C), Diffused (D), and Tinted (T) Lenses Available in a Shouldered (S) Lead Frame Style Ideal for Status Indication and Display Bivar 3mm T1 Package Extended Profile LED may be used in almost any application and provides additional protrusion for those applications with thicker face plates. Bivar offers water clear LED lens for maximum light output, diffused LED lens for uniform light output, and tinted lens to identify the color of the LED. The Shouldered Lead frame LED is ideal for vertical spacer assemblies without lead bends and also has a built in strain relief feature which is ideal for right angle holder assemblies that require lead bends. Part Number Material Emitted Color Peak. Wavelength λp(nm) TYP. 3YC-201-S 3YD-201-S GaAsP/Gap YELLOW 590nm 3YT-201-S Lens Appearance Viewing Angle Water Clear 20° Yellow Diffused 35° Yellow Tinted 20° Part Number Designation 3 X X-2 0 1 - X LED Body, mm Emitted Color Lens Appearance Lead Frame & Body Style i.e. -S, Shouldered Extended Profile ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 1 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, YELLOW, AMBER, BLUE, GREEN, Low Ultra Extended Low 5V 12V Extended Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Profile Bright YELLOW, Extended Profile Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 2 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, YELLOW, AMBER, BLUE, GREEN, Low Ultra Extended Low 5V 12V Extended Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Profile Bright YELLOW, Extended Profile Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 85 mW Forward Current ( DC ) Peak Forward Current 30 mA 1 150 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX Reverse Dominant Current Wavelength (nm)2 (μA) MAX 3YC-201-S 3YD-201-S / 2.0 2.8 / 20 / 100 3YT-201-S Notes: 1. Tolerance of forward voltage : ±0.05V. Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 40 / 20 / / / / 20 / 35 / / / / 40 / 20 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 3 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, YELLOW, AMBER, BLUE, GREEN, Low Ultra Extended Low 5V 12V Extended Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Profile Bright YELLOW, Extended Profile Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° Iv 10° 20° 30° 1.0 40° 20° 50° 35° 0.5 60° 70° 80° 0.0 500 90° λ(nm) 550 600 650 0.5 700 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA If (mA) Iv 1000 3.0 100 2.0 10 1.0 1 0.1 1.0 2.0 3.0 4.0 5.0 Vf (V) Fig. 3 Forward Current vs. Forward Voltage 0.0 1 10 If (mA) 100 1000 Fig. 4 Relative Luminous Intensity vs. Forward Current Normalize @ 20 mA Vf (V) Iv 1.2 3.0 1.1 2.0 1.0 1.0 0.9 0.8 -40 T (°C) 0 40 80 Fig. 5 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 6 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 Web: www.bivar.com Revision C 06/15 Page 4 of 5 3mm LEDs 3mm (T1) (T1) Package Package Discrete Discrete LED LED AMBER TURQUOISE, YELLOW, AMBER, BLUE, GREEN, Low Ultra Extended Low 5V 12V Extended Ultra Super Low Current Bright Current Ultra Bright Current Bright Profile Profile Bright YELLOW, Extended Profile Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan Anti-Static Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 Web: E-mail: bivar@bivar.com Web: www.bivar.com Phone: (949) www.bivar.com Rev. A C 01/16/08 Revision 06/15 Page Page 4 5 of of 4 5
3YT-201-S 价格&库存
很抱歉,暂时无法提供与“3YT-201-S”相匹配的价格&库存,您可以联系我们找货
3YT-201-S
    • 1+3.36960
    • 200+1.35000
    • 500+1.30680
    • 1000+1.28520
