1.8mm Package Discrete LED
GREEN, Low Current
1.8GXL
1.8mm Small Footprint Package
RoHS Compliant
Water Clear (C) and Diffused (D) Lenses
Available in a Shouldered Lead Frame style
2 mA Low Operating Current
Ideal for Status Indication and Display
Recommended for Bivar H-381C and H-485C holder
assemblies
Bivar 1.8mm Package 2 mA Low Current LED is special binned at 2 mA and is ideal for those applications where lower power budget and smaller indication lighting are required such as solar panel or battery-powered portable devices. Bivar offers water clear LED lens for maximum light output and diffused LED lens for uniform light output, The Shouldered Lead frame LED has a built in strain relief
feature which is ideal for Right Angle Holder assemblies that require lead bends.
Part Number
1.8GCL
1.8GDL
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
GaP/GaP
GREEN
568nm
Lens Appearance
Viewing Angle
Water Clear
35°
Green Diffused
50°
Outline Dimensions
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Part Number Designation
1.8 X X L
LED Dome, mm
Low Current
Emitted Color
Lens Appearance
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision A 03/08
Page 1 of 4
3mm
(T1)
Package
Discrete
LEDs
1.8mm
Package
Discrete
LED
AMBER
GREEN, Low Current
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
10 mW
Forward Current ( DC )
Peak Forward Current
7 mA
1
/ mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb )
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
2
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 2 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
1.8GCL
1.8GDL
2.1
2.6
2
Notes: 1. Tolerance of forward voltage : ±0.05V.
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
100
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
4.5
35
2
50
2. Tolerance of dominant wavelength : ±1.0nm.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision A 03/08
Page 2 of 4
3mm
(T1)
Package
Discrete
LEDs
1.8mm
Package
Discrete
LED
AMBER
GREEN, Low Current
Typical Electrical / Optical Characteristics
0°
Iv
10°
20°
30°
1.0
40°
35°
50°
50°
0.5
60°
70°
80°
λ(nm)
0.0
500
550
600
Fig. 1 Relative Luminous Intensity vs. Wavelength
1.2
90°
0.5
650
Vf (V)
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
3.0
1.1
0.3
Iv
2.0
1.0
1.0
0.9
0.8
T (°C)
-40
80
Fig. 3 Forward Voltage vs. Temperature
0.0
T (°C)
-40
80
Fig. 4 Relative Luminous Intensity vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 03/08
Page 3 of 4
3mm
(T1)
Package
Discrete
LEDs
1.8mm
Package
Discrete
LED
AMBER
GREEN, Low Current
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A A
01/16/08
Revision
03/08
Page
Page 4
4 of
of 4
4
很抱歉,暂时无法提供与“1.8GDL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.296051+0.29719
- 10+1.9119210+0.24747
- 100+1.52779100+0.19775
- 250+1.37938250+0.17854
- 500+1.30080500+0.16837
- 1000+1.187311000+0.15368
- 2000+1.073822000+0.13899
- 4000+0.995254000+0.12882
- 国内价格 香港价格
- 100+1.68444100+0.21803
- 国内价格
- 1+2.13208
- 10+1.77514
- 100+1.41820
- 250+1.28045
- 500+1.20738
- 1000+1.10198
- 2000+0.99657
- 4000+0.92350
