1.8HCL
1.8HCL
    BIVAR
    1.8mm个离散LED
    发光二极管/LED 径向
1.8HCL 数据手册
1.8mm Package Discrete LED RED, Low Current 1.8HXL ♦ ♦ ♦ ♦ ♦ ♦ ♦ 1.8mm Small Footprint Package RoHS Compliant Water Clear (C) and Diffused (D) Lenses Available in a Shouldered Lead Frame style 2 mA Low Operating Current Ideal for Status Indication and Display Recommended for Bivar H-381C and H-485C holder assemblies Bivar 1.8mm Package 2 mA Low Current LED is special binned at 2 mA and is ideal for those applications where lower power budget and smaller indication lighting are required such as solar panel or battery-powered portable devices. Bivar offers water clear LED lens for maximum light output and diffused LED lens for uniform light output, The Shouldered Lead frame LED has a built in strain relief feature which is ideal for Right Angle Holder assemblies that require lead bends. Part Number 1.8HCL 1.8HDL Material Emitted Color Peak. Wavelength λp(nm) TYP. GaAsP/GaP RED 625nm Lens Appearance Viewing Angle Water Clear 35° Red Diffused 50° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Part Number Designation 1.8 X X L LED Dome, mm Low Current Emitted Color Lens Appearance ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 1 of 4 3mm (T1) Package Discrete LEDs 1.8mm Package Discrete LED AMBER RED, Low Current Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 10 mW Forward Current ( DC ) Peak Forward Current 7 mA 1 / mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 2 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 1.8HCL 1.8HDL / 2.0 2.6 / 2 Notes: 1. Tolerance of forward voltage : ±0.05V. / Reverse Dominant Current Wavelength (nm)2 (μA) MAX 100 Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 4.5 / 35 / / / / 2 / 50 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 2 of 4 3mm (T1) Package Discrete LEDs 1.8mm Package Discrete LED AMBER RED, Low Current Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Iv 0° 1.0 10° 20° 30° 40° 35° 50° 50° 0.5 60° 70° 80° λ(nm) 0.0 550 600 650 700 750 Fig. 1 Relative Luminous Intensity vs. Wavelength 90° 0.5 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Iv Iv (%) 1000 50 40 100 30 20 10 10 .01 1.2 Vf (V) 1.6 2.0 2.4 2.8 3.0 1 Fig. 3 Relative Intensity vs. Forward Voltage 400 If (mA) 1 10 100 1000 Fig. 4 Relative Luminous Intensity (%) vs. Forward Current Iv (%) 200 100 50 20 10 T (°C) -20 0 20 40 60 80 100 Fig. 5 Relative Intensity (%) vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 3 of 4 3mm (T1) Package Discrete LEDs 1.8mm Package Discrete LED AMBER RED, Low Current Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 03/08 Page Page 4 4 of of 4 4
1.8HCL 价格&库存
很抱歉,暂时无法提供与“1.8HCL”相匹配的价格&库存,您可以联系我们找货
