1.8HD
1.8HD
    BIVAR
    插件
    发光二极管/LED 红色 插件
1.8HD 数据手册
1.8mm Package Discrete LED RED 1.8HX ♦ ♦ ♦ ♦ ♦ ♦ 1.8mm Small Footprint Package RoHS Compliant Water Clear (C) and Diffused (D) Lenses Available in a Shouldered Lead Frame style Ideal for Status Indication and Display Recommended for Bivar H-381C and H-485C holder assemblies Bivar 1.8mm Package LED may be used in almost any Application where smaller indication lights are required. Bivar offers water clear LED lens for maximum light output and diffused LED lens for uniform light output, The Shouldered Lead frame LED has a built in strain relief feature which is ideal for Right Angle Holder assemblies that require lead bends. Part Number 1.8HC 1.8HD Material Emitted Color Peak. Wavelength λp(nm) TYP. GaAsP/GaP RED 625nm Lens Appearance Viewing Angle Water Clear 35° Red Diffused 50° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Part Number Designation 1.8 X X LED Dome, mm Lens Appearance Emitted Color ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 1 of 4 3mm (T1) Package Discrete LEDs 1.8mm Package Discrete LED AMBER RED Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 80 mW Forward Current ( DC ) Peak Forward Current 30 mA 1 150 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 2 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 1.8HC 1.8HD / 2.0 2.8 / 20 Notes: 1. Tolerance of forward voltage : ±0.05V. / Reverse Dominant Current Wavelength (nm)2 (μA) MAX 100 Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 30 / 35 / / / / 20 / 50 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 2 of 4 3mm (T1) Package Discrete LEDs 1.8mm Package Discrete LED AMBER RED Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° Iv 10° 20° 30° 1.0 40° 35° 50° 50° 0.5 60° 70° 80° λ(nm) 0.0 550 600 650 700 750 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA 90° 0.5 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Iv Iv (%) 1000 50 40 100 30 20 10 10 .01 1.2 Vf (V) 1.6 2.0 2.4 1 2.8 3.0 10 100 1000 Fig. 4 Relative Luminous Intensity (%) vs. Forward Current Fig. 3 Relative Intensity (10mA) vs. Forward Voltage 50 If (mA) 1 If(mA) 400 Iv (%) 200 40 100 30 20 50 10 20 T (°C) 0 0 20 40 60 80 100 Fig. 5 Forward Current vs. Temperature 10 T (°C) -20 0 20 40 60 80 100 Fig. 6 Relative Intensity (%) vs. Temperature @ 20 mA Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 3 of 4 3mm (T1) Package Discrete LEDs 1.8mm Package Discrete LED AMBER RED Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 03/08 Page Page 4 4 of of 4 4
1.8HD 价格&库存
很抱歉,暂时无法提供与“1.8HD”相匹配的价格&库存,您可以联系我们找货
