5GC
5GC
    BIVAR
    径向
    LED GREEN CLEAR 5MM ROUND T/H
5GC 数据手册
5mm 5mm (T1 (T1 ¾) ¾) Package Package Discrete Discrete LED LED GREEN GREEN 5GX-X ♦ ♦ ♦ ♦ ♦ Industry Standard 5mm (T1 ¾) Package RoHS Compliant Water Clear (C), Diffused (D), and Tinted (T) Lenses Available in Flange (F) and Standard (Blank) Lead Frame styles Ideal for Status Indication and Display Bivar 5mm T1 ¾ Package LED may be used in almost any application. Bivar offers water clear LED lens for maximum light output, diffused LED lens for uniform light output, and tinted lens to identify the color of the LED. The Flange LED is ideal for Panel Mount Clip & Ring assemblies and the Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends. Part Number Viewing Angle 5GC-F Water Clear 35° 5GD-F Green Diffused 40° Green Tinted 35° Water Clear 35° 5GD Green Diffused 45° 5GT Green Tinted 35° 5GC GaP/GaP Emitted Color Peak. Wavelength λp(nm) TYP. Lens Appearance 5GT-F Material GREEN 568nm Part Number Designation 5 X X - X LED Body, mm Emitted Color Lead Frame & Body Style i.e. -F, Blank for Standard Lens Appearance ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 1 of 5 5mm 3mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER GREEN Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 2 of 5 5mm 3mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER GREEN Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 80 mW Forward Current ( DC ) 30 mA Peak Forward Current 1 150 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX Reverse Dominant Current Wavelength (nm)2 (μA) MAX Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 40 / 35 / / / / 25 / 40 5GT-F / / / / 40 / 35 5GC / / / / 40 / 35 / / / / 25 / 45 / / / / 40 / 35 5GC-F 5GD-F 5GD / / 2.1 2.1 2.8 2.8 / / 20 20 5GT Notes: 1. Tolerance of forward voltage : ±0.05V. / / 100 100 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 3 of 5 5mm 3mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER GREEN Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° 10° 20° 30° Iv 1.0 40° 35° 50° 40° 45° 0.5 60° 70° 80° 0.0 500 λ(nm) 550 600 650 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA 90° 0.5 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram If (mA) Iv 1000 3.0 100 2.0 10 1.0 1 0.1 1.0 Vf (V) 2.0 3.0 4.0 5.0 Fig. 3 Forward Current vs. Forward Voltage 0.0 1 10 100 1000 If (mA) Fig. 4 Relative Luminous Intensity vs. Forward Current Normalize @ 20 mA Vf (V) Iv 3.0 1.2 1.1 2.0 1.0 1.0 0.9 0.8 T (°C) -40 0 40 80 Fig. 5 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 6 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 4 of 5 5mm 3mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER GREEN Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 03/08 Page Page 4 5 of of 4 5
很抱歉,暂时无法提供与“5GC”相匹配的价格&库存,您可以联系我们找货
5GC
    • 1+2.279961+0.28250
    • 10+1.8969210+0.23504
    • 100+1.51389100+0.18758
    • 250+1.36798250+0.16950
    • 500+1.29502500+0.16046
    • 1000+1.176461000+0.14577
    • 2000+1.067022000+0.13221
    • 4000+1.003184000+0.12430
    5GC
    • 100+0.94064100+0.11655
    • 400+0.90480400+0.11211
    • 1000+0.882411000+0.10934
    • 2500+0.860012500+0.10656
    • 4000+0.826864000+0.10246
    5GC
    • 100+1.73764100+0.21531
