5GDL
5GDL
    BIVAR
    插件
    发光二极管/LED 翠绿色 插件 5mcd
5GDL 数据手册
5mm 3mm (T1 Package Package Discrete Discrete LED LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER AMBER, TURQUOISE, BLUE, GREEN, Low Ultra Low Ultra Super Current Bright Current Ultra Bright Bright Bright GREEN, Low Current B 5GDL-X ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard 5mm (T1 ¾) Package RoHS Compliant Diffused Lens Available in Flange (F) and Standard (Blank) Lead Frame styles 2 mA Low Operating Current Ideal for Status Indication and Display Bivar 5mm T1 ¾ Package 2 mA Low Current LED is special binned at 2 mA and is ideal for those applications where lower power budget is required such as solar panel or battery-powered portable devices. Bivar offers diffused LED lens for uniform light output. The Flanged LED is ideal for Panel Mount Clip & Ring assemblies and the Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends. Part Number 5GDL-F 5GDL Material Emitted Color Peak. Wavelength λp(nm) TYP. GaP/GaP GREEN 568nm Lens Appearance Viewing Angle Green Diffused 40° Green Diffused 45° Part Number Designation 5 X X L -X LED Body, mm Emitted Color Lens Appearance Lead Frame & Body Style i.e. -F, Blank for Standard Low Current ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 1 of 5 3mm 5mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER TURQUOISE, GREEN, YELLOW, AMBER, BLUE, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright GREEN, Low Current Outline Dimensions Flanged “5XXL-F” LED Standard “5XXL” LED Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 2 of 5 3mm 5mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER TURQUOISE, GREEN, YELLOW, AMBER, BLUE, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright GREEN, Low Current Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 10 mW Forward Current ( DC ) Peak Forward Current 7 mA 1 / mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 2 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX 5GDL-F 5GDL / 2.1 2.6 / 2 Notes: 1. Tolerance of forward voltage : ±0.05V. / Reverse Dominant Current Wavelength (nm)2 (μA) MAX 100 Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 4 / 40 / / / / 5 / 45 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 3 of 5 3mm 5mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER TURQUOISE, GREEN, YELLOW, AMBER, BLUE, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright GREEN, Low Current Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° Iv 10° 20° 30° 1.0 40° 40° 50° 45° 0.5 60° 70° 80° λ(nm) 0.0 500 550 600 650 90° 0.5 Fig. 1 Relative Luminous Intensity vs. Wavelength 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram Vf (V) Iv 1.2 3.0 1.1 2.0 1.0 1.0 0.9 0.8 T (°C) -40 0 40 80 Fig. 3 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 4 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 4 of 5 3mm 5mm (T1 Package Package Discrete Discrete LED LEDs LED 5mm (T1) (T1 ¾) ¾) Package Discrete LED AMBER TURQUOISE, GREEN, YELLOW, AMBER, BLUE, Low Ultra Low Ultra Super Low Current Bright Current Ultra Bright Current Bright Bright GREEN, Low Current Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 03/08 Page 5 4 of of 5 4 Page
很抱歉,暂时无法提供与“5GDL”相匹配的价格&库存,您可以联系我们找货
5GDL
    • 1+2.296051+0.29719
    • 10+1.9119210+0.24747
    • 100+1.52779100+0.19775
    • 250+1.37938250+0.17854
    • 500+1.30080500+0.16837
    • 1000+1.187311000+0.15368
    • 2000+1.073822000+0.13899
    • 4000+0.995254000+0.12882
    5GDL
    • 100+1.68444100+0.21803
    5GDL
      • 1+2.13568
      • 10+1.77754
      • 100+1.42059
      • 250+1.28284
      • 500+1.20978
      • 1000+1.10437
      • 2000+0.99897
      • 4000+0.92590
