5mm
3mm
(T1
Package
Package
Discrete
Discrete
LED
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
AMBER,
GREEN,
TURQUOISE,
BLUE,
RED,
Low
Ultra
Ultra
Super
Current
Current
Bright
Ultra
Bright
Bright
Bright
RED, Low
Low
Current
B
5HDL-X
Industry Standard 5mm (T1 ¾) Package
RoHS Compliant
Diffused Lens
Available in Flange (F) and Standard (Blank) Lead Frame
styles
2 mA Low Operating Current
Ideal for Status Indication and Display
Bivar 5mm T1 ¾ Package 2 mA Low Current LED is special binned at 2 mA and is ideal for those applications where lower power budget is required such as solar panel or battery-powered portable devices. Bivar offers diffused LED lens for uniform light output. The Flanged LED is ideal for Panel
Mount Clip & Ring assemblies and the Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends.
Part Number
5HDL-F
5HDL
Material
Emitted Color
Peak. Wavelength
λp(nm) TYP.
GaAsP/GaP
RED
625nm
Lens Appearance
Viewing Angle
Red Diffused
40°
Red Diffused
45°
Part Number Designation
5 X X L -X
LED Body, mm
Emitted Color
Lens Appearance
Lead Frame & Body Style
i.e. -F, Blank for Standard
Low Current
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Moisture
Sensitivity
Levels 1
Bivar reserves the right to make changes at any time without notice.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision A 03/08
Page 1 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
TURQUOISE,
YELLOW,
AMBER,
BLUE,
GREEN,
Low
Ultra
Low
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
RED, Low
Current
Outline Dimensions
Flanged “5XXL-F” LED
Standard “5XXL” LED
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
Bivar reserves the right to Bivar
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
notice. the best product possible.
Revision A 03/08
Page 2 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
TURQUOISE,
YELLOW,
AMBER,
BLUE,
GREEN,
Low
Ultra
Low
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
RED, Low
Current
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Power Dissipation
10 mW
Forward Current ( DC )
Peak Forward Current
7 mA
1
/ mA
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +85°C
Storage Temperature Range
-30 ~ +100°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical / Optical Characteristics
TA = 25°C & I F = 2 mA unless otherwise noted
Part Number
Forward
Voltage (V)1
Recommend
Forward
Current (mA)
MIN TYP MAX MIN TYP MAX
5HDL-F
5HDL
2.0
2.6
2
Notes: 1. Tolerance of forward voltage : ±0.05V.
Reverse
Dominant
Current
Wavelength (nm)2
(μA)
MAX
100
Luminous
Intensity Iv (mcd)
Viewing
Angle
2Ө½
(deg)
MIN
TYP
MAX
MIN
TYP
MAX
TYP
5
40
5
45
2. Tolerance of dominant wavelength : ±1.0nm.
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 03/08
Page 3 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
TURQUOISE,
YELLOW,
AMBER,
BLUE,
GREEN,
Low
Ultra
Low
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
RED, Low
Current
Typical Electrical / Optical Characteristics
0°
Iv
10°
20°
30°
1.0
40°
40°
50°
45°
0.5
60°
70°
80°
90°
0.5
λ(nm)
0.0
550 600
650 700 750
Fig. 1 Relative Luminous Intensity vs. Wavelength
0.3
0.1
0.2
0.4
0.6
Fig. 2 Directivity Radiation Diagram
Iv
Iv (%)
1000
50
40
100
30
10
.01
1.2
Vf (V)
1.6
2.0 2.4
1
2.8 3.0
Fig. 3 Relative Intensity vs. Forward Voltage
400
If (mA)
1
10
100
1000
Fig. 4 Relative Luminous Intensity (%) vs.
Forward Current
Iv (%)
200
100
50
T (°C)
-20
0 20 40
60
80 100
Fig. 5 Relative Intensity (%) vs. Temperature
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Revision A 03/08
Page 4 of 5
3mm
5mm
(T1
Package
Package
Discrete
Discrete
LED
LEDs
LED
5mm (T1)
(T1 ¾)
¾)
Package
Discrete
LED
AMBER
TURQUOISE,
YELLOW,
AMBER,
BLUE,
GREEN,
Low
Ultra
Low
Ultra
Super
Low
Current
Bright
Current
Ultra
Bright
Current
Bright
Bright
RED, Low
Current
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
AntiStatic Poly Bag with Desiccant
(500 pcs Max. per Bag)
make reserves
changes the
at any
time
in order
to improve
design
and to supply
right
to make
changes
at any
time without
Bivar,
Bivar, Inc.
Inc. —
—4
4 Thomas,
Thomas, Irvine,
Irvine, California
California 92618,
92618, U.S.A.
U.S.A.
Phone:
Phone: (949)
(949) 951-8808
951-8808 Fax:
Fax: (949)
(949) 951-3974
951-3974 E-mail:
Web: www.bivar.com
www.bivar.com
Rev. A A
01/16/08
Revision
03/08
Page 5
4 of
of 5
4
Page
