R4YD
R4YD
    BIVAR
    插件
    发光二极管/LED 插件
R4YD 数据手册
Rectangular Package Discrete LED YELLOW, 2 x 4 mm R4YX ♦ ♦ ♦ ♦ ♦ Rectangular Package RoHS Compliant Water Clear (C), Diffused (D), and Tinted (T) Lenses Available in Standard Lead Frame style Ideal for Status Indication and Bar Graph Displays Bivar Rectangular 2 x 4mm Package LED may be used in almost any application and is ideal for creating bar graph displays when arranged in linear LED arrays. Bivar offers water clear LED lens for maximum light output, diffused LED lens for uniform light output, and tinted lens to identify the color of the LED. The Standard Lead frame LED is ideal for vertical spacer assemblies and Right Angle Holder assemblies that require lead bends. Part Number Material Emitted Color Peak. Wavelength λp(nm) TYP. R4YC R4YD GaAsP/GaP YELLOW 590nm R4YT Lens Appearance Viewing Angle Water Clear 100° Yellow Diffused 120° Yellow Tinted 100° Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Part Number Designation R 4 X X LED Body, mm Lens Appearance Emitted Color ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 07/08 Page 1 of 4 3mm (T1) Package Discrete LEDs Rectangular Package Discrete LED AMBER YELLOW, 2 x 4 mm Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 85 mW Forward Current ( DC ) 30 mA Peak Forward Current 1 150 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX Reverse Dominant Current Wavelength (nm)2 (μA) MAX R4YC R4YD / 2.0 2.6 / 20 R4YT Notes: 1. Tolerance of forward voltage : ±0.05V. / 100 Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 8 / 100 / / / / 6 / 120 / / / / 8 / 100 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 07/08 Page 2 of 4 3mm (T1) Package Discrete LEDs Rectangular Package Discrete LED AMBER YELLOW, 2 x 4 mm Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° 10° 20° Iv 30° 100° 120° 1.0 40° 50° 0.5 60° 70° 80° 0.0 500 λ(nm) 550 600 650 90° 0.5 700 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram If (mA) Iv 1000 3.0 100 2.0 10 1.0 1 0.1 1.0 2.0 3.0 4.0 5.0 Vf (V) Fig. 3 Forward Current vs. Forward Voltage 0.0 1 10 If (mA) 100 1000 Fig. 4 Relative Luminous Intensity vs. Forward Current Normalize @ 20 mA Vf (V) Iv 1.2 3.0 1.1 2.0 1.0 1.0 0.9 0.8 -40 T (°C) 0 40 80 Fig. 5 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 6 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 07/08 Page 3 of 4 3mm (T1) Package Discrete LEDs Rectangular Package Discrete LED AMBER YELLOW, 2 x 4 mm Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 07/08 Page Page 4 4 of of 4 4
很抱歉,暂时无法提供与“R4YD”相匹配的价格&库存,您可以联系我们找货
