5AD
5AD
    BIVAR
    插件
    发光二极管/LED 琥珀色 插件 25mcd
5AD 数据手册
5mm 5mm (T1 (T1 ¾) ¾) Package Package Discrete Discrete LED LED AMBER AMBER 5AX-X ♦ ♦ ♦ ♦ ♦ Industry Standard 5mm (T1 ¾) Package RoHS Compliant Water Clear (C), Diffused (D), and Tinted (T) Lenses Available in Flange (F) and Standard (Blank) Lead Frame styles Ideal for Status Indication and Display Bivar 5mm T1 ¾ Package LED may be used in almost any application. Bivar offers water clear LED lens for maximum light output, diffused LED lens for uniform light output, and tinted lens to identify the color of the LED. The Flange LED is ideal for Panel Mount Clip & Ring assemblies and the Standard Lead frame LED is ideal for vertical spacer assemblies without lead bends. Part Number Viewing Angle 5AC-F Water Clear 35° 5AD-F Amber Diffused 40° Amber Tinted 35° Water Clear 35° 5AD Amber Diffused 45° 5AT Amber Tinted 35° 5AC Emitted Color Peak. Wavelength λp(nm) TYP. Lens Appearance 5AT-F Material GaAsP/GaP AMBER 605nm Part Number Designation 5 X X - X LED Body, mm Emitted Color Lead Frame & Body Style i.e. -F, Blank for Standard Lens Appearance ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Levels 1 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 1 of 5 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER AMBER Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. 3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted. 4. Epoxy meniscus may extend to 0.060" max. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 2 of 5 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER AMBER Absolute Maximum Ratings TA = 25°C unless otherwise noted Power Dissipation 80 mW Forward Current ( DC ) 30 mA Peak Forward Current 1 150 mA Reverse Voltage 5V Operating Temperature Range -25 ~ +85°C Storage Temperature Range -30 ~ +100°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number Forward Voltage (V)1 Recommend Forward Current (mA) MIN TYP MAX MIN TYP MAX Reverse Dominant Current Wavelength (nm)2 (μA) MAX Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX TYP / / / / 40 / 35 / / / / 25 / 40 5AT-F / / / / 40 / 35 5AC / / / / 40 / 35 / / / / 25 / 45 / / / / 40 / 35 5AC-F 5AD-F 5AD / / 2.0 2.0 2.8 2.8 / / 20 20 5AT Notes: 1. Tolerance of forward voltage : ±0.05V. / / 100 100 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 3 of 5 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER AMBER Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted 0° Iv 10° 20° 30° 1.0 40° 35° 50° 40° 45° 0.5 60° 70° 80° 0.0 550 λ(nm) 600 650 700 750 90° 0.5 Fig. 1 Relative Luminous Intensity vs. Wavelength @ 20mA 0.3 0.1 0.2 0.4 0.6 Fig. 2 Directivity Radiation Diagram If (mA) Iv 1000 3.0 100 2.0 10 1.0 1 0.1 1.0 2.0 3.0 4.0 5.0 Vf (V) Fig. 3 Forward Current vs. Forward Voltage 0.0 1 10 100 1000 If (mA) Fig. 4 Relative Luminous Intensity vs. Forward Current Normalize @ 20 mA Vf (V) Iv 1.2 3.0 1.1 2.0 1.0 1.0 0.9 0.8 -40 T (°C) 0 40 80 Fig. 5 Forward Voltage vs. Temperature 0.0 T (°C) -40 0 40 80 Fig. 6 Relative Luminous Intensity vs. Temperature Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/08 Page 4 of 5 3mm Package Discrete LED LEDs 5mm (T1) (T1 ¾) Package Discrete LED AMBER AMBER Recommended Soldering Conditions Recommended Lead Free Wave Soldering Profile Preheat Temperature: 100ºC Max. Peak Temperature: 260ºC Max. Preheat Time: 20 ~ 50 Seconds Solder Time Above 217ºC: 5 Seconds Max. Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source. Packaging and Labeling Plan AntiStatic Poly Bag with Desiccant (500 pcs Max. per Bag) Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 03/08 Page Page 4 5 of of 4 5
很抱歉,暂时无法提供与“5AD”相匹配的价格&库存,您可以联系我们找货
5AD
    • 1+2.985581+0.38420
    • 10+2.4938410+0.32092
    • 100+1.99332100+0.25651
    • 250+1.79135250+0.23052
    • 500+1.69476500+0.21809
    • 1000+1.545481000+0.19888
    • 2000+1.396202000+0.17967
    • 4000+1.290834000+0.16611
